[AG-TECH] Ubuntu 11.04/64 Jabber problem ?
Philippe d'Anfray
Philippe.d-Anfray at cea.fr
Thu May 19 02:37:04 CDT 2011
Bonjour,
The diagnosis is confirmed ! probably we'd better run our own jabber
server too
Merci, bien cordialement
Philippe
Le 19/05/2011 00:26, Christoph Willing a écrit :
> On 19/05/2011, at 2:17 AM, D'ANFRAY Philippe wrote:
>> We upgraded our machines to Ubuntu 11.04 (and AG accordingly) but
>> there seems to be a problem with
>> Jabber. (We tried to reinstall everything and suppress the
>> .Accessgrid3 directory "a tous hasard(s)") but we still have this
>> message in the log
>> 05/18/11 17:57:44 140653651658528 JabberClient JabberClient.py:65
>> DEBUG currentRoom inside sendMessage(): ''
>> 05/18/11 17:57:44 140653651658528 JabberClient JabberClient.py:69
>> ERROR No venue is selected
>> and on the screen. This only happen with 11.04, 10.10 still works
>> correctly
> This may be related to a known problem (bugzilla #1949), where client
> systems running python2.7 (Ubuntu 11.04, Fedora 14) have no jabber or
> media services when connected to the ANL venue server. It _may_ be
> that even when connected a different venue server that nevertheless
> "uses" the ANL server for jabber connection, then the media services
> will work OK but jabber is broken in the way you describe.
> Could I suggest (to help confirm the diagnosis) that you first
> _restart_ your 11.04 venue client and then connect to the APAG venue
> server (which runs its own jabber server) at:
> https://vv3.ap-accessgrid.org:8000/Venues/default
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110519/36c62e61/attachment.vcf>
