[AG-TECH] Natty and AG
Lev Lafayette lev at vpac.org
Fri Apr 29 00:39:47 CDT 2011
Following the instructions given at:
http://www.vislab.uq.edu.au/research/accessgrid/software/debian/natty.html
.. I end up with broken packages.
lev at isocracy:~$ sudo apt-get install accessgrid3.2
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 accessgrid3.2 : Depends: agcommon but it is not installable
                 Depends: ag-vic2.8ucl but it is not installable
                 Depends: ag-rat but it is not installable
                 Depends: quickbridge but it is not installable
                 Depends: vpcscreen but it is not installable
E: Broken packages
Lev Lafayette, Systems Administrator, Victorian Partnership for Advanced Computing, lev at vpac.org
"If you are sending a reply to a message or a posting be sure you summarize the original at the top of the message, or include just enough text of the original to give a context. This will make sure readers understand when they start to read your response."  RFC 1855
110 Victoria Street                                        phone:   03 9925 4909
Carlton South, Victoria 3053,  Australia          mobile:  0432 255 208
More information about the ag-tech mailing list
