[AG-TECH] Vanishing Bridges (again)
Philippe d'Anfray Philippe.d-Anfray at cea.fr
Thu Nov 25 05:23:19 CST 2010
Bonjour
The exact version is 3.2-3, I have also noticed  the problem with the
/etc/hosts
in fact it makes the bridge unreachable as the host name stored in the
registry is
localhost6... (here the "faulty" line has been commented out before the
tests and
the file has not been changed so far)
127.0.0.1    localhost.localdomain    localhost
# ::1    aristotest4    localhost6.localdomain6    localhost6
129.104.48.106  aristotest4 aristotest4.polytechnique.fr
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
ff02::3 ip6-allhosts
Cordialement
Philippe
> Could you confirm exactly which up to date version of accessgrid3.2 is
> installed please? It will be something like 3.2-1, 3.2-2, ...
> One other possible factor I've noticed while doing various tests, is
> that NetworkManager on Ubuntu modifies /etc/hosts at each boot (maybe
> even more often?) and this can make the bridge invisible. Could you
> send the contents of /etc/hosts at the time the bridge becomes invisible?
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20101125/ed4f0f61/attachment.vcf>
More information about the ag-tech mailing list
