[AG-TECH] Re : Manage Certificates from VenueClient (Time data doesn't match format)
Jesus Cea Oliva
jesus.cea at uca.es
Sun Mar 14 19:32:36 CDT 2010
Thank you very much for your reply! :-)
I'll fix the problem like Marcelino suggested.
And, thanks again for your reply about control access, I supose that users must use a certificate individual, but I dont know how the Administrator knows the DN, I mean, I thought that the established procedure was using a tool or "hide option" that lists all user connected on the Venue Server and then to administrate the access.
It would be a good idea to make a program/tool that can be used for this purpose, or modify Venue Manager and, when I click on "Add Person" I could write the DN or select an user from a list of connected users.
Anyway, thanks for your help. I apologize for the inconvenience.
Greetings!
El dia 15 mar 2010 00:06, Christoph Willing <c.willing at uq.edu.au> escribió:
> Jesus,
> We have seen this problem previously and have already implemented a fix (similar to the one suggested by Marcelino below) but its obviously an incomplete fix - so thanks for reporting the problem.
> I've changed my system language setting to Spanish and I can replicate your problem. I found that I can manage my certificates by running CertificateManager3.py from a shell - maybe you could do that until a proper fix is implemented
> chris
> On 15/03/2010, at 6:41 AM, <Marcolino.Pires at ac-paris.fr> wrote:
>> Hi
>> I have front several times this problem, the solution is to add somthing like this in the AccessGrid python file causing the problem
>> import locale
>> locale.setlocale(locale.LC_ALL, 'C')
>> I can't tell you the exact file because I do not access an AccessGrid client right now
>> Best regards
>> Marcolino PIRES
>> Téléphone : 01 44 62 45 73
>> Rectorat de l'académie de Paris
>> CAPTI - Bureau 382
>> 94, avenue Gambetta
>> 75984 PARIS CEDEX 20
>> ----- Message d'origine -----
>> De: Jesus Cea Oliva <jesus.cea at uca.es>
>> Date: Dimanche, Mars 14, 2010 5:31 pm
>> Objet: [AG-TECH] Manage Certificates from VenueClient problems on Ubuntu Karmic (Time data doesn't match format), and Control Access
>> À: ag-tech at mcs.anl.gov
>>> Hi list.
>>> I've a problem on Venue Client, on Ubuntu machines, when I click on
>>> "Tools->Manage Certificates ...". No appears any screen, so, on Debug
>>> Mode, I see this error:
>>> "ValueError: time data 'Apr 21 00:52:18 2007 GMT' does not match
>>> format '%b %d %H:%M:%S %Y %Z'"
>>> This is the traceback:
>>> /usr/lib/python2.6/dist-packages/twisted/internet/_sslverify.py:5:
>>> DeprecationWarning: the md5 module is deprecated; use hashlib instead
>>> import itertools, md5
>>> /usr/lib/pymodules/python2.6/ZSI/resolvers.py:6: DeprecationWarning:
>>> the multifile module has been deprecated since Python 2.5
>>> import multifile, mimetools, urllib
>>> Traceback (most recent call last):
>>> File
>>> "/usr/lib/pymodules/python2.6/AccessGrid3/AccessGrid/Security/wxgui/ CertificateManagerWXGUI.py",
>>> line 176, in <lambda>
>>> lambda event, win=win, self=self: self.OnShowNew(event, win))
>>> File
>>> line 237, in OnShowNew
>>> self.certificateManager, self)
>>> File
>>> "/usr/lib/pymodules/python2.6/AccessGrid3/AccessGrid/Security/wxgui/ CertificateManagerDialog.py",
>>> line 25, in __init__
>>> self.identBrowser = IdentityBrowser(self.notebook, -1, self.certMgr)
>>> File
>>> "/usr/lib/pymodules/python2.6/AccessGrid3/AccessGrid/Security/wxgui/ IdentityBrowser.py",
>>> line 57, in __init__
>>> CertificateBrowserBase.__init__(self, parent, id, certMgr)
>>> File
>>> "/usr/lib/pymodules/python2.6/AccessGrid3/AccessGrid/Security/wxgui/ CertificateBrowserBase.py",
>>> line 27, in __init__
>>> self.Load()
>>> File
>>> line 86, in Load
>>> data, columnStrings = self._FormatCert(cert)
>>> File
>>> line 286, in _FormatCert
>>> valid = self.certMgr.CheckValidity(cert)
>>> File
>>> "/usr/lib/pymodules/python2.6/AccessGrid3/AccessGrid/Security/ CertificateManager.py",
>>> line 375, in CheckValidity
>>> if self.VerifyCertificatePath(cert):
>>> File
>>> line 405, in VerifyCertificatePath
>>> issuers = filter(lambda x: not x.IsExpired(), issuers)
>>> File
>>> line 405, in <lambda>
>>> File
>>> "/usr/lib/pymodules/python2.6/AccessGrid3/AccessGrid/Security/ CertificateRepository.py",
>>> line 1340, in IsExpired
>>> return self.cert.IsExpired()
>>> File
>>> line 1526, in IsExpired
>>> return IsExpired(self.cert)
>>> File
>>> "/usr/lib/pymodules/python2.6/AccessGrid3/AccessGrid/Security/ Utilities.py",
>>> line 52, in IsExpired
>>> before_tuple = time.strptime(str(before_time),format)
>>> File "/usr/lib/python2.6/_strptime.py", line 454, in _strptime_time
>>> return _strptime(data_string, format)[0]
>>> File "/usr/lib/python2.6/_strptime.py", line 325, in _strptime
>>> (data_string, format))
>>> ValueError: time data 'Apr 21 00:52:18 2007 GMT' does not match format
>>> On Windows I haven't this problem, and, on both systems, I can execute
>>> CertificateManager3.py without problems, only I have this error from
>>> VenueClient option. What can I do to solve?
>>> Other question, exists some document about control access? I would
>>> like to create venues and restrict access. I know that it can do using
>>> Venue Manager, the Security tab in each Venue. But, I don't know how
>>> add persons, I see a "Distinguish name", but, how I can know the DN of
>>> a Participant? Is necesary that the participant enter on a venue for
>>> restrict/permit the access?, or exists some solution to
>>> restrict/permit a Participant without enter on a Venue?.
>>> Thank you for your time. I apologize for the inconvenience.
>>> Greetings!
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100315/3a2b25ef/attachment.htm>
