[AG-TECH] Re : Manage Certificates from VenueClient (Time data doesn't match format)
Christoph Willing
c.willing at uq.edu.au
Sun Mar 14 18:06:02 CDT 2010
Jesus,
We have seen this problem previously and have already implemented a
fix (similar to the one suggested by Marcelino below) but its
obviously an incomplete fix - so thanks for reporting the problem.
I've changed my system language setting to Spanish and I can replicate
your problem. I found that I can manage my certificates by running
CertificateManager3.py from a shell - maybe you could do that until a
proper fix is implemented
chris
On 15/03/2010, at 6:41 AM, <Marcolino.Pires at ac-paris.fr> wrote:
> Hi
> I have front several times this problem, the solution is to add
> somthing like this in the AccessGrid python file causing the problem
> import locale
> locale.setlocale(locale.LC_ALL, 'C')
> I can't tell you the exact file because I do not access an
> AccessGrid client right now
> Best regards
> Marcolino PIRES
> Téléphone : 01 44 62 45 73
> Rectorat de l'académie de Paris
> CAPTI - Bureau 382
> 94, avenue Gambetta
> 75984 PARIS CEDEX 20
> ----- Message d'origine -----
> De: Jesus Cea Oliva <jesus.cea at uca.es>
> Date: Dimanche, Mars 14, 2010 5:31 pm
> Objet: [AG-TECH] Manage Certificates from VenueClient problems on
> Ubuntu Karmic (Time data doesn't match format), and Control Access
> À: ag-tech at mcs.anl.gov
>> Hi list.
>> I've a problem on Venue Client, on Ubuntu machines, when I click on
>> "Tools->Manage Certificates ...". No appears any screen, so, on Debug
>> Mode, I see this error:
>> "ValueError: time data 'Apr 21 00:52:18 2007 GMT' does not match
>> format '%b %d %H:%M:%S %Y %Z'"
>> This is the traceback:
>> /usr/lib/python2.6/dist-packages/twisted/internet/_sslverify.py:5:
>> DeprecationWarning: the md5 module is deprecated; use hashlib instead
>> import itertools, md5
>> /usr/lib/pymodules/python2.6/ZSI/resolvers.py:6: DeprecationWarning:
>> the multifile module has been deprecated since Python 2.5
>> import multifile, mimetools, urllib
>> Traceback (most recent call last):
>> File
>> "/usr/lib/pymodules/python2.6/AccessGrid3/AccessGrid/Security/wxgui/
>> CertificateManagerWXGUI.py",
>> line 176, in <lambda>
>> lambda event, win=win, self=self: self.OnShowNew(event, win))
>> File
>> line 237, in OnShowNew
>> self.certificateManager, self)
>> File
>> CertificateManagerDialog.py",
>> line 25, in __init__
>> self.identBrowser = IdentityBrowser(self.notebook, -1,
>> self.certMgr)
>> File
>> IdentityBrowser.py",
>> line 57, in __init__
>> CertificateBrowserBase.__init__(self, parent, id, certMgr)
>> File
>> CertificateBrowserBase.py",
>> line 27, in __init__
>> self.Load()
>> File
>> line 86, in Load
>> data, columnStrings = self._FormatCert(cert)
>> File
>> line 286, in _FormatCert
>> valid = self.certMgr.CheckValidity(cert)
>> File
>> CertificateManager.py",
>> line 375, in CheckValidity
>> if self.VerifyCertificatePath(cert):
>> File
>> line 405, in VerifyCertificatePath
>> issuers = filter(lambda x: not x.IsExpired(), issuers)
>> File
>> line 405, in <lambda>
>> File
>> CertificateRepository.py",
>> line 1340, in IsExpired
>> return self.cert.IsExpired()
>> File
>> line 1526, in IsExpired
>> return IsExpired(self.cert)
>> File
>> Utilities.py",
>> line 52, in IsExpired
>> before_tuple = time.strptime(str(before_time),format)
>> File "/usr/lib/python2.6/_strptime.py", line 454, in _strptime_time
>> return _strptime(data_string, format)[0]
>> File "/usr/lib/python2.6/_strptime.py", line 325, in _strptime
>> (data_string, format))
>> format
>> On Windows I haven't this problem, and, on both systems, I can
>> execute
>> CertificateManager3.py without problems, only I have this error from
>> VenueClient option. What can I do to solve?
>> Other question, exists some document about control access? I would
>> like to create venues and restrict access. I know that it can do
>> using
>> Venue Manager, the Security tab in each Venue. But, I don't know how
>> add persons, I see a "Distinguish name", but, how I can know the DN
>> of
>> a Participant? Is necesary that the participant enter on a venue for
>> restrict/permit the access?, or exists some solution to
>> restrict/permit a Participant without enter on a Venue?.
>> Thank you for your time. I apologize for the inconvenience.
>> Greetings!
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
