[AG-TECH] Bridge question.
Todd Zimmerman
todd.zimmerman at ubc.ca
Fri Jan 22 14:01:21 CST 2010
On 10/06/2009 01:20 PM, Christoph Willing wrote:
> On 07/10/2009, at 5:46 AM, Jimmy Miklavcic wrote:
>> We seem to have our bridge working now. It looks like a network
>> configuration problem on the machine itself. If someone could select
>> UTAH_CHPC, after you purge your bridge cache to refresh, as your
>> bridge, you should see the bridge address (155.101.28.50) at the
>> bottom of the main VIC window. You bridge list should see UTAH_CHPC as
>> enabled with a valid ping time.
> Jimmy,
> Looks good from here (at home) in Australia - ping time 1.1417...
> Could you share what aspect of network configuration you changed to
> allow the bridge to work? It would be good knowledge to have out there
> for people with similar problems in the future.
Just to follow up - I'm seening similar behaviour on a bridge here and
can't determine the cause. Can you forward what changes were made to fix
this?
Todd
