[AG-TECH] UBUNTU 9.10, VIC, webcam (driver pb ?)
Christoph Willing
c.willing at uq.edu.au
Sun Jan 3 07:43:14 CST 2010
On 30/12/2009, at 10:58 PM, muhammad akl wrote:
> Hi Chris ,
> it seems that not only phillipe who faced this problem, as am facing
> it with some usb webcam here, a4tech and labtec.
We don't have these cameras on hand to test and debug. Could you
locate these devices in the output of the command:
sudo lspci -v
and send the result please ? (not the whole output, just the lines
referring to these devices)
> I'm using the latest versions of accessgrid
It is the version of vic which is important - could you check that you
have the latest version of vic (which fixed Philipppe's problem). More
specifically, ensure that you have installed:
ag-vic2.8ucl, version 1.4-0ubuntu6
chris
> , and the problem still not solved, also am working on ubuntu 9.10 ,
> with Nvidia graphic card.The cameras are working fine with other
> softwares like cheesa, but when it comes to accessgrid , i see the
> exact pic in phillipe's attachment , so what would cause the problem
> here ?
> Regards
> Muhammad
> On Wed, Dec 9, 2009 at 4:07 PM, Philippe d'Anfray <Philippe.d-Anfray at cea.fr
> > wrote:
> Great ! I tested successfully all our webcams
> Merci Philippe
> Christoph Willing a écrit :
> > We have a new vic with a fix for the webcam issue (thanks to Doug
> > Kosovich of UQVislab). It has been only lightly tested so please
> > report any problems with it.
> > If the UQVislab repo is enabled on your system (as it probably is,
> if
> > you're running AG in Ubuntu), the new vic package can be installed
> > with the commands:
> > sudo apt-get update
> > sudo apt-get upgrade
> > or you could use Synaptic or the Update Manager if you prefer a gui.
> > Please note that for Ubuntu users this fix is only required for 9.10
> > (Karmic Koala), due to the recency of the kernel version it uses.
> > There is no new ag-vic package available nor needed for earlier
> Ubuntu
> > releases.
> > chris
> > On 07/12/2009, at 6:44 PM, Philippe d'Anfray wrote:
> >> Bonjour
> >> Ouf ! I'm not the only one... :-) I was thinking of "going
> back" to
> >> ubuntu 9.04
> >> now it seems to be the only thing to do for the time being.
> >> Merci
> >> Philippe
> >>> We've now been able to replicate your problem with another
> webcam that
> >>> is usually "well behaved". At the moment it looks related to the
> >>> kernel version since a particular version of vic that works fine
> with
> >>> this webcam and kernel series 2.6.29 does not work with the 2.6.31
> >>> series kernel.
> >>> Maybe vic will need some modification to adapt to the newer
> kernels.
> >>> We'll let you know when there is some progress. Until then, the
> only
> >>> immediate solutions I can think of are:
> >>> 1. revert to an earlier version of your distro (which contains an
> >>> earlier kernel version), e.g. karmic->jaunty
> >>> or
> >>> 2. install an earlier kernel version, e.g. 2.6.31.* -> 2.6.29.6
> >> <Philippe_d-Anfray.vcf>
> > Christoph Willing +61 7 3365 8316
> > QCIF Access Grid Manager
> > University of Queensland
