[AG-TECH] problem when creating venue
K. N. Jyothi
jyothink at cdac.in
Thu Sep 17 23:43:57 CDT 2009
Forwarded From: jyothink at cdac.in
> Hi
> I am facing few problems with creating venue through venue management
> tool and also with text chat.
> The set up we configured is in this way :
> The accessgrid3 is installed on system1 and system2 running on windows
> operating system. On system1 venue server is running and clients are
> system1 and system2,who contacted the venue server and participated in the
> default venue lobby.The video and audio services are working fine.we are
> using the user certificates and CA files issued by Globus simple CA which
> is set by us only locally here.
> Actual Problem : When i am trying to create venue using venue management
> tool, its showing an error " Unable to contact the venue server".After
> viewing the log file I came to know the error which is "SSLError:
> certificate verify failed".You can see the log file of venue management
> attached with the mail.I explored in may ways , but couldnt find the
> solution.
> Can you kindly help me out in this issues.
> Thanks in advance.
> With regards
> Nava Jyothi K
> Member Technical Staff
> C-DAC,India
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090918/5e90c0d1/attachment.obj>
