[AG-TECH] DVTS/ExtendedVideoProducer freezes
Michael Miller
mimiller at ncsa.uiuc.edu
Mon Mar 30 09:26:29 CDT 2009
Andrew,
If you can open a command prompt, try:
taskkill /F /PID XXXXX
where XXXXX is the process ID gleaned from the task manager.
Hope this helps,
myk
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
----- Original Message -----
To: ag-tech at mcs.anl.gov
Sent: Wednesday, March 25, 2009 2:02:09 PM GMT -06:00 US/Canada Central
Subject: [AG-TECH] DVTS/ExtendedVideoProducer freezes
On a couple of our Windows machines I've been seeing DVTS (running as an ExtendedVideoProducer) hard freeze in certain situations. Usually whenever the firewire connection drops out (ie, the preview window just shows the last frame and trying to connect in an ExtendedVideoConsumer only shows a black screen), and I try to disable the Producer service, the copy of DVTS associated with the Producer service will hard freeze, necessitating a reboot since trying to close it in task manager (normal 'end task' or doing end process tree) doesn't work. Has anyone ever seen this before and/or know how to definitively hard kill a process in Windows?
--Andrew
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090330/59fb8174/attachment.htm>
