[AG-TECH] InterPlay: Anartomy connection Information.
Jimmy Miklavcic
jimmy.miklavcic at utah.edu
Sat Mar 28 14:54:12 CDT 2009
For those who might connect to the InterPlay performances this weekend and next, here's the information needed for doing so.
You will need HITLabNZ's HD-Vic (<http://www.hitlabnz.org/wiki/Access_Grid_-_HD>http://www.hitlabnz.org/wiki/Access_Grid_-_HD<http://www.hitlabnz.org/wiki/Access_Grid_-_HD) or>) or the H.264 Consumer service. The multicast address and port for HD-Vic vic is 224.2.215.62/62002. Make sure you use the -t 127 option. So, in a command window connect to the unzipped folder "vic_hdmi_1.1_beta" and run "vic -t 127 224.2.215.62/62006". Please do not send video or audio until the Q&A at the end of the performance. Look for the CHPC Digital Mix window, that's the primary video. We are performing in the Theatre of the ArtGrid Venue (https://artgridvs.chpc.utah.edu:8000/Venues/default).
You should update RAT from the AGtk 3.2 beta release and set the sampling rate to 48KHz, stereo. You won't hear us until you do. You'll find those settings in RAT's option menu. In the Category drop down menu, select Audio. You'll then see where to make the sampling rate changes. The multicast address for audio is 224.2.164.85/56438, TTL 127.
Mexico City joined us last night and that's pretty cool. If anyone does connect, please let us know how many people are at your site. We'd like to increase our remote audience. If there are any other questions, I'll be in email contact until 16:30 MDT today.
Jimmy Miklavcic
Multimedia Specialist
Jimmy.Miklavcic at utah.edu<mailto:Jimmy.Miklavcic at utah.edu>
UNIVERSITY OF UTAH
CTR FOR HIGH PERFORM COMPUTING
155 SOUTH 1452 EAST RM 405
SALT LAKE CITY, UT 84112-0190
Office: 801.585.9335
Fax: 801.585.5366
http://www.anotherlanguage.org<http://www.anotherlanguage.org/>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090328/582e51ea/attachment.htm>
Name: Blank Bkgrd.gif
Type: image/gif
Desc: Blank Bkgrd.gif
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090328/582e51ea/attachment.gif>
