[AG-TECH] AG 3.2 on OSX
Jason Bell
j.bell at cqu.edu.au
Mon Mar 23 22:39:54 CDT 2009
G'day Tyler
I am using the built-in isight on my iMAC (3GHz Inter Core 2 - OS X 10.5.6) and using a VideoService and it works fine.
I might add that I haven't really tried using a Video Consumer and Video Producer, so I cannot confirm if this is a particular issue.
In regards to Audio, if you don't already know, the Audio on the mac is quite terrible and I believe that there is effort currently underway to try and fix this. But in the time being, you might want to check out http://www.accessgrid.org/node/1792, as there are some tips to help make audio work a little better.
Cheers,
Jason.
-----Original Message-----
Sent: Sunday, 22 March 2009 07:56 AM
To: tyler.heaton
Cc: ag-tech at lists.mcs.anl.gov
Subject: Re: [AG-TECH] AG 3.2 on OSX
Tyler,
i've been running 3.2 beta on my macbook pro for quite a while.
after some software updates a couple of months ago, my
VideoProducerService/VideoConsumerSerice configuration would no longer
show me my USB camera video stream. rather than checking the logs
and trying to figure out what was going wrong, i opted to try
removing the vid producer and consumer and added a VideoService.
i could see my video stream again. that's the configuration i'm
still running. i guess i should have filed a bug report. sorry, Tom.
if you haven't tried VideoService already, you might wanna give it a go.
it works for me.
--fred
On Fri, Mar 20, 2009 at 04:14PM, John I. Quebedeaux, Jr wrote:
> Multicast or unicast? I¹m assuming you¹re running 10.5.6 (soon to be 10.5.7)
> on the MBP....
> Check if the camera light came on, just because you don¹t see the vic window
> with anything in it at all doesn¹t mean it¹s not transmitting because of a
> problem with the vic showing up properly... Which is a known problem I
> believe.... You doing just videoservice? Or videoconsumer and videoproducer?
> I tend to prefer videoconsumer and videoproducer...
> You may not see your outgoing video, easiest way to check that is to bring
> up another AG session on another machine and check if your video is actually
> getting out and back to the other node. I do this all the time to test
> multicast put one machine on multicast with a source, then put another
> machine on unicast pick a bridge and see if multicast is working from my
> source to that bridge. It¹s a easy way to check out without trying to figure
> out beacons and such and you don¹t even have to ask anyone if your video is
> getting out.
> Hope that helps... wonder if it¹s been fixed but not repackaged for the Mac
> yet... Also, .. You said the RAT is working fine? I doubt that, run audio
> for... 15 minutes... Between the mac and another node and see what
> happens...
> -John Q.
> John I. Quebedeaux, Jr.; Louisiana State University
> Computer Manager LBRN; 131 Life Sciences Bldg.
> e-mail: johnq at lsu.edu; web: http://lbrn.lsu.edu
> phone: 225-578-0062 / fax: 225-578-2597
> From: "tyler.heaton" <tyler.heaton at uleth.ca>
> Date: Fri, 20 Mar 2009 14:38:54 -0600
> To: <ag-tech at lists.mcs.anl.gov>
> Subject: [AG-TECH] AG 3.2 on OSX
> I have installed AG 3.2 on my MacBook Pro. The venue server and RAT are
> working fine, but I am not able to get the Video services to work. Does
> anyone have experience working with AG on Mac and using built in USB
> cameras?
> Tyler Heaton, Educational Technology Specialist
> CRDC, University of Lethbridge
> Office: (403) 380.1856
> Cell: (403) 359-4041
> Email, iChat, AIM: tyler.heaton at uleth.ca
