[AG-TECH] Video capture card Advice request
Jason Bell
j.bell at cqu.edu.au
Mon Jun 29 01:05:45 CDT 2009
Khanh
I suspect your issue is that you tried to "store" the configuration
without selecting the "Set as default" option, or you tried to save as
the default (system) config, which requires "root" permissions. I have
submitted a bug report to get this issue fixed, see
http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1777.
My advice is to try saving your configuration as a different name, such
as standard, select the "Set as default" option and everything should
work fine.
On a side note, saving multiple configurations is extremely handy. I
generally have a number of config's saved, such as:
* Standard;
* Standard + VPCScreen;
* Single Camera;
* Triple Cameras;
* Low Bandwidth;
* Audio Only;
This highlights a few common configurations I use. Using Tools ->
Configurations -> [Config Name] allows the easy switching between one
config to another.
Hope this helps.
Cheers,
Jason.
Sent: Monday, 29 June 2009 11:30 AM
To: Jason Bell
Cc: Douglas Kosovic; ag-tech at lists.mcs.anl.gov
Subject: Re: [AG-TECH] Video capture card Advice request
Hi Jason,
We happened to configure AG in a same way as Doug's suggestion, however,
it did not work.
The problem is the saved configuration did not loaded .
We encountered a different problem with the FC10 when replaced the
TripleheadToGo by dual graphics cards and have not fixed them yet.
However, the same systems when booted into Windows XP working well.
Regards
Khanh
Khanh Ly
Computer Support Officer
Western Australian Supercomputer Program (WASP)
The University of Western Australia
On 24/06/2009, at 12:40 PM, Jason Bell wrote:
G'day Khanh
Did the suggestion Doug make help?
As I use a number of IVC-200 video cards without any problems on Fedora
10.
Jason.
-----Original Message-----
From: Douglas Kosovic [mailto:douglask at itee.uq.edu.au]
Sent: Tuesday, 12 May 2009 06:33 PM
To: Khanh ly; ag-tech at lists.mcs.anl.gov
Hi Khanh,
We are looking to replace the 4-cameras inputs IEI-IVC 200 cards.
They are running well on the windows XP machine. However, they
gave
poor quality on the Fedora 10 system. Even worse, we must
configure
the video to transmit PAL signal (using H.261) every time we
start
Access Grid.
I suspect you haven't configured the Video Producer Service to use PAL
and saved the configuration. Or maybe you are setting it to PAL
directly in VIC, which it'll forget the next time VIC is started. See
the following on how to configure a Video Producer:
http://www.accessgrid.org/node/1770
you might also like to increase the bandwidth and quality sliders to see
if that makes any difference.
Cheers,
Doug
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090629/0d16ad3c/attachment.htm>
