[AG-TECH] Bridge Registry Problem?
Adam Carter
adam at epcc.ed.ac.uk
Thu Jun 25 05:10:29 CDT 2009
Hi Chris (cc list),
Thanks for your reply. I can see now the difference between the web
service that returns the bridge list and the list of bridges itself, so
the fact that the list only has one entry no longer worries me.
However, is it possible that bridges are trying to add their entry to
the Argonne server, failing for some reason (possibly due to the way
that the server at Argonne has been configured?), and then not launching
properly themselves because of this? This would explain the behaviour
that I've had reported to me that bridges will not go back up when
they've gone down... If others who are using a bridge have not noticed
the problem, then I guess it's some other problem with the bridge, but I
thought I'd check first. I see that Michael M has restarted his bridge,
apparently with no problems, so I assume that it's something at the
other end...
Cheers,
Adam
Christoph Willing wrote:
> On 16/06/2009, at 11:07 PM, Adam Carter wrote:
>> Hi,
>> Recently I've noticed that a couple of unicast bridges I've tried to
>> contact have been unavailable. When I spoke to Michael Braitmaier in
>> Stuttgart he said that his bridge server was not restarting because
>> it couldn't access the peers.txt list on the Argonne Server. Checking
>> in the Venue Client in my list of bridge servers, nearly all of them
>> show up as unreachable. I can still connect to those which are still
>> up and running at their original addresses, but I suspect this is
>> also related to the peers file. When I put the peers file url into a
>> browser it shows only one entry, namely that of Argonne. Is this
>> deliberate, or an oversight?
> Adam,
> The peers.txt will normally contain just a single entry consisting of
> the name of a machine and the port at which a particular web service
> is running. Bridges register with that web service when they start up
> and, when queried the right way, that web service returns the list of
> bridges that have registered.
> In short, the minimal content of peers.txt is not the reason why some
> bridges end up being unreachable.
> chris
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
