[AG-TECH] Venue Server not starting fully
Michael Miller
mimiller at ncsa.uiuc.edu
Mon Jun 1 08:28:52 CDT 2009
Ian,
Check the ports that the venue server uses, 8000 main, 8002, 8004, 8006, event/data/text, I'm not sure all these are currently in use, i.e. I think the text port got dropped when ANL switched to jabber. But check these and any other ports in use. There's a doc on the AccessGrid website here:
http://www.accessgrid.org/node/1816
http://www.accessgrid.org/agdp/guide/ports/1.03/index.html
http://www.accessgrid.org/node/898
hope this helps
myk
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
----- Original Message -----
From: "Ian Dennell" <Ian.Dennell at manchester.ac.uk>
To: ag-tech at mcs.anl.gov
Sent: Friday, May 29, 2009 6:08:58 AM GMT -06:00 US/Canada Central
Subject: [AG-TECH] Venue Server not starting fully
Hi
When restarting the Venue server, it runs and works, but nothing gets logged in the log files (I need data from ServerUsage.csv) after it starts up. The following lines are the only things logged...
05/28/09 01:31:03 46912496279184 Toolkit VenueServer:154 INFO Network error running server; an application is already running on one of the ports required
05/29/09 01:31:03 46912496279184 Toolkit Config.py:613 ERROR Error setting hostname.
Traceback (most recent call last):
File "/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/Config.py", line 607, in SetHostname
sock.bind((hostname, 0))
File "<string>", line 1, in bind
error: (99, 'Cannot assign requested address')
05/29/09 01:31:03 46912496279184 Toolkit Config.py:625 DEBUG retrieved local IP address 195.194.48.209
05/29/09 01:31:03 46912496279184 Toolkit Toolkit.py:116 DEBUG Initializing AG Toolkit version 3.1
05/29/09 01:31:03 46912496279184 Toolkit Toolkit.py:117 INFO Command and arguments: ['/usr/bin/VenueServer']
05/29/09 01:31:03 46912496279184 VenueClient Preferences.py:188 DEBUG Preferences.LoadPreferences: open file
05/29/09 01:31:03 46912496279184 Toolkit Toolkit.py:166 INFO Logfile Name: VenueServer.log
05/29/09 01:31:03 46912496279184 Toolkit Toolkit.py:691 INFO Service init: have profile None
05/29/09 01:31:03 46912496279184 Toolkit Toolkit.py:716 INFO Service Initialization Complete.
05/29/09 01:31:03 46912496279184 Toolkit VenueServer:102 INFO VenueServer running using hostname: 195.194.48.209
05/29/09 01:31:03 46912496279184 Toolkit VenueServer:105 INFO Running in secure mode
05/29/09 01:31:03 46912496279184 CertificateManager CertificateManager.py:212 DEBUG Opened repository /home/ag/.AccessGrid3/Config/certRepo
05/29/09 01:31:03 46912496279184 Toolkit Toolkit.py:472 INFO Initialized certificate manager.
05/29/09 01:31:03 46912496279184 CertificateManager CertificateManager.py:575 DEBUG Configuring standard environment
05/29/09 01:31:03 46912496279184 CertificateManager CertificateManager.py:625 DEBUG Using default identity /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/sam.ag.manchester.ac.uk
05/29/09 01:31:03 46912496279184 Toolkit Toolkit.py:262 INFO Using unencrypted certificate: /home/ag/.AccessGrid3/Config/certRepo/certificates/0aca0320bf5686131b801e980d0a7c9a/21badf8e152b49d4a9ac0c92c8da27cf/cert.pem /home/ag/.AccessGrid3/Config/certRepo/privatekeys/b73a897d7e32e163e95a24cc4a93d98d.pem
05/29/09 01:31:03 46912496279184 Toolkit VenueServer:154 INFO Network error running server; an application is already running on one of the ports required
Does anybody know a fix or what's running to prevent the venue server running fully?
Cheers
Ian Dennell
Access Grid Support Centre
Research Computing Services
Room 73A, Devonshire House
University of Manchester M13 9PL
United Kingdom
t: +44 (0)161 275 0684
e: support at agsc.ja.net
w: http://www.manchester.ac.uk
http://www.ja.net/agsc
