[AG-TECH] sending dv/hdv via accessgrid all in one
Gurcharan S. Khanna gurcharan.khanna at rit.edu
Sun Jul 19 07:40:10 CDT 2009
muhammad,
3.2-Beta! I wish I had noticed that earlier! Yes, definitely stay away
from that.
There are known problems both with DVTS (and H264) in the beta.
Now that you've discovered that, I have to say I have never seen the kind of
artifacts that you show us in your DVTS image.
I'm connected to your sever now but I guess you must have turned off your
stream. I will check it again later.
Also, you should check trying to receive an external stream as well. If
you go
to the RIT Venue at
https://vv3.mcs.anl.gov:8000/Venues/8cdd226521d429b68e7e8c0158a6a663
there should be several DVTS streams available.
As John said in an earlier email, make sure multicast is working (there are
independent ways to test that). But it looks like something in your machine
or local network possibly.
-gurcharan
muhammad akl wrote:
> hi Gurcharan, John
> Firstly appreciated your help both , I think now the problem has taken
> another curve , i mean i've downgraded AccessGrid version from
> 3.2-Beta to AccessGrid 3.1 stable release ( also using the
> easyinstaller package) , and as i previously did , i've configured
> AccessGrid on the sender Pc to use the ExtendedVideoProducerService
> and again i can see my video signal fine without any problem
> Now at the receiver Pc , I've configured it to use the
> ExtendedVideoConsumerService and now it pops up the DVTS screen and I
> can see the stream sent by my sender pc , and did as Gurcharan said ,
> that I clicked on each of those text lines and the DVTS window was
> brought up with the following problem within it :
> http://muhammad.akl.googlepages.com/19072009367.jpg
> As you can see the video is corrupted and is not clear , what can
> cause this problem ?
> my AccessGrid Server url is https://ag0.mans.edu.eg
> <https://ag0.mans.edu.eg/>
> Our Bridge Name : Mansoura University
> Regards
> Muhammad
> On Sun, Jul 19, 2009 at 2:08 AM, John I. Quebedeaux, Jr <johnq at lsu.edu
> <mailto:johnq at lsu.edu>> wrote:
>     Muhammad, on Monday I can put up a DVTS stream into a lobby (let
>     me know which you’re playing in, there are several these days –
>     Louisiana has their own for example) and see what’s up.
>     Confirm you have multicast working...
>     It’s not clear from you on the display (receiver) machine if DVTS
>     is starting, if you’re getting errors, etc. Is it starting but not
>     showing anything? Can you confirm the multicast addresses
>     involved? Are you getting “video” but it’s black for example?
>     Thanks,
>     John Q.
>     John I. Quebedeaux, Jr.; Louisiana State University
>     Computer Manager LBRN; 131 Life Sciences Bldg.
>     e-mail: johnq at lsu.edu <http://johnq@lsu.edu/>; web:
>     http://lbrn.lsu.edu <http://lbrn.lsu.edu/>
>     phone: 225-578-0062 / fax: 225-578-2597
>     *From: *muhammad akl <muhammad.akl at gmail.com
>     <http://muhammad.akl@gmail.com/>>
>     *Date: *Sat, 18 Jul 2009 19:39:16 +0300
>     *To: *Gurcharan Khanna <gurcharan.khanna at rit.edu
>     <http://gurcharan.khanna@rit.edu/>>
>     *Cc: *<ag-tech at mcs.anl.gov <http://ag-tech@mcs.anl.gov/>>
>     *Subject: *Re: [AG-TECH] sending dv/hdv via accessgrid all in one
>     hi Gurcharan,
>     well, the problem mainly is that i'm unable to receive my video
>     signal at the receiver side , which actually i can see it via DVTS
>     program at the sending side
>     let's explain my setup in more details , i've two pcs their specs
>     as follows :
>     Sender PC
>     OS : Windows XP SP3
>     AccessGrid Ver : 3.2 Beta version ( All in one Installer made by
>     http://www.hitlabnz.org/wiki/Access_Grid_-_Easy_Installer)
>     Processor: Intel core 2 duo 2.3 GHZ
>     Ram : 2 GB
>     VGA Card : Nvidia 8400 GS ( Driver installed via nvidia website )
>     Ethernet Type : Gigabit ethernet
>     Firewire ports : External Pci card has two IEEE-1394 ports
>     Input Camera : Sony DCR-TRV285E
>     Receiver PC
>     OS : Windows XP SP3
>     Processor : intel pentium D 3.4 GHZ
>     Ram : 512 MB
>     Ethernet type : fast ethernet
>     Now , The sender Pc is configured to Start sending Digital Video
>     via ExtendedVideoServiceProducer Option which is found in the
>     AccessGrid node management menu , that i've included during the
>     installation of AccessGrid , And at this time i can see my video
>     signal via DVTS program
>     At the Receiver Side , I've started AccessGrid and configured It
>     to use The ExtendedVideoConsumerService from AccessGrid node
>     Management menu by adding a new service , and at this time i can
>     not see anything , and no error messages appeared
>     does my setup lacks something that's i've fogotten to do , or does
>     i need much horse power for my PCS ?
>     if though , what are the necessary steps to be done to be able to
>     send and/or receive dv/hdv on windows xp ?
>     Regards
>     Muhammad
>     On Sat, Jul 18, 2009 at 5:31 PM, Gurcharan S. Khanna
>     <gurcharan.khanna at rit.edu <http://gurcharan.khanna@rit.edu/>> wrote:
>         hi,
>         we use it constantly. can you give us more details about your
>         problem?
>         e.g., specific error messages?
>         -gurcharan
>         muhammad akl wrote:
>             hello,
>              I've just installed the recent all in one accessgrid
>             package on windows xp , the installation process went fine ,
>             and i've added the extended video services during the
>             installation as I want to start sedning dv/hdv video via
>             firewire cameras ,
>             after i've joined the lobby , i've configured the
>             ExtendedVideoProducerService , and I can see my video fine
>             via the DVTS program ,
>             but the problem that i'm unable to receive it via
>             ExtendedVideoConsumerService ,I've tried several times to
>             enable and disable the service with no luck
>              Anyone had a previous experience on how to get dv/hdv
>             video on windows xp using this all in one (which includes
>             the DVTS ) ?
>              also anyone tried the enhanced vic that was made by
>             vislab team (chris willing ) on windows xp and successed
>             to integrate it with accessgrid ?
>         Gurcharan S. Khanna, Ph.D.
>         Director of Research Computing
>         Office of the Vice President for Research
>         http://rc.rit.edu <http://rc.rit.edu/> <http://rc.rit.edu/>
>         Assistant Research Professor, Ph.D. Program
>         Golisano College of Computing and Information Sciences
>         http://people.rit.edu/gskpop
>         Director, Interactive Collaboration Environments Laboratory,
>         Center for the Advancing the Study of Cyberinfrastructure
>         http://icelab.rit.edu <http://icelab.rit.edu/>
>         Rochester Institute of Technology
>         1 Lomb Memorial Drive
>         Rochester, New York 14623-5603
>         Phone: 585-475-7504  ~  Cell: 585-451-8370
>         Email: gurcharan.khanna at rit.edu <http://gurcharan.khanna@rit.edu/>
http://rc.rit.edu
More information about the ag-tech mailing list
