[AG-TECH] Problem in Adding Venue and Work around
N. Satyanarayana
nanduris at cdac.in
Sun Jan 4 05:07:38 CST 2009
Micahel,
Thank you for your patience and prompt response.
1) When I tried to add new venue using Venue Management option I got a
popup message saying Could not connect to venue server. When I went thru
log I saw SSL certificate validity failed message. Then I found the
trusted CA certificates file names in .AccessGrid3/Config/trustedCACerts
directory were different from the one I had in my globus trusted
certificates folder.
For example, 92ac10ac.signing_policy file is being stored in
AccessGrid3/Config/trustedCACerts directory while importing trusted CA,
as 92ac10acl.signing_policy. I do not know how this letter 'l' is getting
appended to the file name.
Then I changed the file name to actual file name directly in
AccessGrid3/Config/trustedCACerts. Then I could connect to venue server
and add new venue to the node. Pl let me know whether it is a bug in the
software and the temporary work around tried in this regard can be taken
for granted.
2) I am facing problem in organizing two way video transmission between
two PCs in my lab using AccessGrid.
I have installed AccessGrid 3.1 along with Globus 4.0.8 on two PCs. In one
system I started Venue Server and then Venue Client after generating user
certificate using globus and subsequently importing it into AccessGrid
using Certificate Management option.
In second system I started Venue Client after importing user certificate
signed by simpleCA from system one.
Later I attached web cameras to both the systems and wanted to transmit
video between these two and enabled Video Producer and Video Consumer
services in both the systems. Both have joined default venue only ie.,
Venue Server Lobby.
But I am not able to send video data between these two systems and I am
always getting Waiting for Video message only.
Pl. let me know how to resolve this issue. My actual idea is two organize
virtual class room between 2 to 3 sites using AccessGrid in different
locations in India.
Thank you,
Satya
On Sat, Jan 3, 2009, Michael Miller <mimiller at ncsa.uiuc.edu> said:
> Satya,
> The venue server will run without certificates on either the client or server. You will only need them if you want to create ACLs for a venue to set permissions for various actions.
> Hope this helps
> Michael Miller
> NCSA
> "If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
> From: "Satyanarayana" <nanduris at cdac.in>
> To: ag-tech at mcs.anl.gov
> Cc: agdev-ca at mcs.anl.gov
> Sent: Wednesday, December 31, 2008 10:33:33 PM GMT -06:00 US/Canada Central
> Subject: [AG-TECH] Venue Server Certificate
> Hi,
> I want to install my own venue server at my premises and create venue clients. When I have gone through the documentation I understood that to install venue server I need to get Server Certificate. I would like to whether this step is essential to start my own venue server or is there any methodology using which I can start my own venue server and manage venue clients. Pl. let me know reason behind imposing registration of new Venue Server installations at central site by asking to send request for VenueServer certificate.
> Thank You,
> Regards,
> Satya
> N. Satyanarayana
> Sr. Staff Scientist
> C-DAC
> Hyderabad
N. Satyanarayana
Senior Staff Scientist
C-DAC
Hyderabad
