[AG-TECH] Strange Windows XP RAT issue
Michael Miller
mimiller at ncsa.uiuc.edu
Mon Feb 16 11:32:51 CST 2009
Enrique,
Not sure how to fix it, perhaps the talk on/off settings in the AudioService config?
As for the command line, you could add the command at the end of the target field of the AG shortcut properties dialog box. Just separate it from the AG command with a ; and the shortcut should run both commands.
Let me know how it goes.
myk
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
----- Original Message -----
From: "Enrique Terrazas" <Enrique.Terrazas at ucsf.edu>
To: "ag-tech mailing list" <ag-tech at mcs.anl.gov>
Sent: Friday, February 13, 2009 3:55:19 PM GMT -06:00 US/Canada Central
Subject: [AG-TECH] Strange Windows XP RAT issue
I have a Dell Optiplex 960 running Windows XP set up as an AG client,
and I'm running an AG Venue server and Bridge on the Windows XP
platform. The Optiplex has an interesting dual use rear port: it can
be used with a microphone or line in device, and there is a software
setting to enable microphone use (see attached - the "Select" box
should be checked to get usable microphone input). I have a clear one
echo canceling microphone plugged into this rear port. When RAT
initializes, the software switch that enables microphone use gets
disabled (the "Select" box becomes de-selected), and the microphone
does not work. I have come up with a command line solution to enable
the select box, but it is somewhat of a pain to train all users to run
this command line solution on this particular PC.
1. Any ideas why this would occur, and more importantly, how to stop
it from happening?
2. If no to #1, where can I insert the command line code so that the
command line is run each time after RAT initializes (so that it is
transparent to the users)?
Thanks for your help.
Enrique Terrazas
[image/jpeg:Picture 1.JPG]
Enrique Terrazas, MD, MS
Director, Laboratory Medicine Residency Program
Director, NCPL Laboratories
Chief, Laboratory Information Systems
HS Associate Clinical Professor
University of California, San Francisco
Clinical Laboratories, Box 0100
4-8931, 415.514.8931(voice)
3-4826, 415.353.4826(fax)
415.443.0913(pager)
CONFIDENTIALITY NOTICE: The information contained in this
transmission, including any enclosed files, is confidential and
intended solely for the addressee. If you are not the intended
recipient, you are hereby notified that any distribution, copying,
disclosure and use of, the contents of this transmission is strictly
prohibited. If you have received this communication in error, please
notify the sender immediately by reply email and permanently delete
this message, enclosures and all copies.
