[AG-TECH] UBUNTU 9.10, VIC, webcam (driver pb ?)
muhammad akl muhammad.akl at gmail.com
Wed Dec 30 06:58:19 CST 2009
Hi Chris ,
it seems that not only phillipe who faced this problem, as am facing it with
some usb webcam here, a4tech and labtec.
I'm using the latest versions of accessgrid , and the problem still not
solved, also am working on ubuntu 9.10 , with Nvidia graphic card.The
cameras are working fine with other softwares like cheesa, but when it comes
to accessgrid , i see the exact pic in phillipe's attachment , so what would
cause the problem here ?
Regards
Muhammad
On Wed, Dec 9, 2009 at 4:07 PM, Philippe d'Anfray
<Philippe.d-Anfray at cea.fr>wrote:
> Great ! I tested  successfully all our webcams
> Merci  Philippe
> Christoph Willing a écrit :
> > We have a new vic with a fix for the webcam issue (thanks to Doug
> > Kosovich of UQVislab). It has been only lightly tested so please
> > report any problems with it.
> > If the UQVislab repo is enabled on your system (as it probably is, if
> > you're running AG in Ubuntu), the new vic package can be installed
> > with the commands:
> >     sudo apt-get update
> >     sudo apt-get upgrade
> > or you could use Synaptic or the Update Manager if you prefer a gui.
> > Please note that for Ubuntu users this fix is only required for 9.10
> > (Karmic Koala), due to the recency of the kernel version it uses.
> > There is no new ag-vic package available nor needed for earlier Ubuntu
> > releases.
> > chris
> > On 07/12/2009, at 6:44 PM, Philippe d'Anfray wrote:
> >> Bonjour
> >> Ouf ! I'm not the only one... :-)   I was thinking of "going back" to
> >> ubuntu 9.04
> >> now it seems to be the only thing to do for the  time being.
> >> Merci
> >> Philippe
> >>> We've now been able to replicate your problem with another webcam that
> >>> is usually "well behaved". At the moment it looks related to the
> >>> kernel version since a particular version of vic that works fine with
> >>> this webcam and kernel series 2.6.29 does not work with the 2.6.31
> >>> series kernel.
> >>> Maybe vic will need some modification to adapt to the newer kernels.
> >>> We'll let you know when there is some progress. Until then, the only
> >>> immediate solutions I can think of are:
> >>>  1. revert to an earlier version of your distro (which contains an
> >>> earlier kernel version), e.g. karmic->jaunty
> >>> or
> >>>  2. install an earlier kernel version, e.g. 2.6.31.* -> 2.6.29.6
> >> <Philippe_d-Anfray.vcf>
> > Christoph Willing                       +61 7 3365 8316
> > QCIF Access Grid Manager
> > University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20091230/34d71704/attachment.htm>
More information about the ag-tech mailing list
