[AG-TECH] HDMI VIC system useage on Windows
Jimmy Miklavcic
jimmy.miklavcic at utah.edu
Fri Apr 17 17:17:24 CDT 2009
Derek, I recently built a new AG System with two Core Duo Quad systems. I have three Blackmagic Intensity Pro cards in the capture machine and a display machine with two Nvidia 9800XT graphics cards. I tried putting a fourth Intensity pro card in the display machine but it was a bit much.
On the capture system, we used the H.264 codec at 720/30p and with three vics, the system was running above 75% across all four processors. The display machine, in our case, decoding around 15 incoming streams, all using H.264 or Mpeg-4, was running around 25% across all four CPUs. We did run audio on a third machine, 48KHz, stereo. But I don't see any reason for not running rat on your display machine.
We also discovered the the H.264 consumer service also pick up all the streams but we just ran the HDMI-Vic manually. We did nothing special with the venue server.
Good luck. If you want to test your system with mine, let me know.
Jimmy
Jimmy Miklavcic
Multimedia Specialist
Jimmy.Miklavcic at utah.edu<mailto:Jimmy.Miklavcic at utah.edu>
UNIVERSITY OF UTAH
CTR FOR HIGH PERFORM COMPUTING
155 SOUTH 1452 EAST RM 405
SALT LAKE CITY, UT 84112-0190
Office: 801.585.9335
Fax: 801.585.5366
http://www.anotherlanguage.org<http://www.anotherlanguage.org/>
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Vine, Derek A
Sent: Friday, April 17, 2009 3:27 PM
To: ag-tech
Subject: [AG-TECH] HDMI VIC system useage on Windows
For those of you who are or have used the HDMI VIC on Windows, could you please provide your capture hardware, system specs and the resource usage to both capture and display?
What I am really getting down to is will a system be able to support three HD cameras for capture and up to 9 HD streams to display? My plan is to use 2 workstations each with 2 QC Intel Xeon processors, one for capture and the other for display and sound.
Finally, do we need to make any special considerations as far as our Venue Server to support these streams?
Any information that can be provided is greatly appreciated.
Thank you,
Derek Vine
Communication Network Specialist
The University of South Dakota
414 East Clark Street
Vermillion, SD 57069
(605) 677-8215
dvine at usd.edu<mailto:ceddn at usd.edu>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090417/a814b19b/attachment.htm>
