[AG-TECH] RAT KDE4 Issues
Piers O'Hanlon
p.ohanlon at cs.ucl.ac.uk
Tue Sep 30 05:10:06 CDT 2008
Hi Todd,
Sorry to hear you're having trouble with RAT on KDE4. Just to double
check what output do you get when you run "sudo iptables -L -n"? Also
presumably other audio application run ok in KDE? Does vic run ok and
connect to external sessions?
Piers.
2008/9/25 Zimmerman, Todd <todd.zimmerman at ubc.ca>:
> Hi All,
> Just wondering if anyone has RAT working under KDE4. It seemed to be
> working under Gnome (Fedora9) but since switching to KDE4 I get
> nothing.
> When starting from the command line, I get a series of the following
> in /var/log/messages:
> Sep 25 10:25:23 kernel: 5:1:1: usb_set_interface failed
> No GUI shows up (firewall is off, selinux is permissive), until finally
> I get the following output on the command line:
> RAT v4.4.01: Failed to rendezvous with UI - Likely firewall/VPN issue
> RAT v4.4.01: UI failed mbus.go rendezvous with controller
> All rat processes die except the rat-4.4.01-media process which requires
> a kill.
> If I leave rat media on long enough I get:
> ALSA lib pcm_direct.c:975:(snd1_pcm_direct_initialize_slave) unable to
> install hw params
> ALSA lib pcm_dmix.c:1020:(snd_pcm_dmix_open) unable to initialize slave
> Any thoughts? (other than switch to gnome ;-))
> Collaboration & Visualization Specialist
> UBC Okanagan - web.ubc.ca
> WestGrid - www.westgrid.ca
> Ph. 250-807-9979
> Todd Zimmerman - todd.zimmerman at ubc.ca
