[AG-TECH] VenueClient crashes
Christoph Willing
c.willing at uq.edu.au
Sun Oct 19 07:10:55 CDT 2008
On 19/10/2008, at 4:51 PM, muhammad akl wrote:
> hey all,
> I'm just using AccessGrid some days ago , using ubuntu 8.04 hardy .
> I followed the instruction at Vislab site and got everything
> successfully installed.
> The first time i started VenueClient , everything worked fine
> without any problem , but when i tried to configure it to use my
> digital camera (another problem will talk abt it later ) i had no
> luck to see the camera when chose DVidoservice
Muhammad,
Firstly (and unrelated to the error you're seeing), the DVideoService
is quite specialised and may not be the service you really expect. I
suggest you try the SimpleHDVideoService which does DV or HDV and
behaves a bit more like the normal VideoService that you'd be used to.
> then i closed the application and when tried to start it again, it
> suddenly disappear . I used VenueClient (Debug) and got these errors :
[snip]
> Traceback (most recent call last):
> File "/usr/bin/VenueClient3.py", line 136, in main
> nodeConfigName=nodeConfig)
> File "/var/lib/python-support/python2.5/AccessGrid3/AccessGrid/
> VenueClient.py", line 266, in __init__
> if int(self.preferences.GetPreference(Preferences.MULTICAST)):
> ValueError: invalid literal for int() with base 10: 'False'
I think this error may be fixed by editing your ~/AccessGrid3/Config/
preferences file; find the line beginning with "multicast" and change
its value "False" to "0" (thats a zero, with no quotation marks).
chris
Christoph Willing +617 3365 8350
QCIF Access Grid Manager
University of Queensland
