[AG-TECH] No Services in new AG3.1 install
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Thu Oct 9 12:56:18 CDT 2008
Does this mean that AGTk 3.2 doesn't support distributed nodes i.e.
those run on multiple machines?
Andrew :)
Research Computing Services,
Kilburn Building,
University of Manchester,
Oxford Road,
Manchester,
M13 9PL,
UK
Tel: +44(0)161-275 0685
Email: Andrew.Rowley at manchester.ac.uk
Quoting "Thomas D. Uram" <turam at mcs.anl.gov>:
> Bonjour does not figure in this problem.
> In AG3.1, the services launch and then register with the service
> manager. This is failing for your user. Common reasons for this
> failure are related to the hostname not resolving properly (unlikely in
> this case, unless the IP address being used is somehow incorrect) and
> firewall configuration. I'd check the latter. I'm curious to know how
> this turns out.
> fyi, in AG 3.2, the core services are run inside the VenueClient
> process, so no network communication occurs between the components, and
> this problem would not occur.
> Tom
> On 10/9/08 11:13 AM, George Estes wrote:
>> Does it make a difference? I thought Bonjour was optional?
>> ----- Original Message -----
>> From: "Tom Coffin" <tcoffin at ncsa.uiuc.edu>
>> To: "George Estes" <gestes at ncsa.uiuc.edu>
>> Sent: Thursday, October 9, 2008 10:46:30 AM GMT -06:00 US/Canada Central
>> Subject: Re: [AG-TECH] No Services in new AG3.1 install
>> did they install Bonjour?
>> George Estes wrote:
>>> Hello,
>>> I have a new AG user at a local high school installing AG3.1.
>>> When he runs the Venue Client on a Windows XP machine the client
>>> doen't load the default services, AudioService and
>>> VideoConsumerService and when he tries to add a Service he get an
>>> error. The school is behind a firewall and uses a proxy server.
>>> Any thoughts on what the problem might be would be very helpful.
>>> Here is a portion of the Venue Client log file...
>>> 10/07/08 12:40:05 1384 ServiceDiscovery servicediscovery.py:62
>>> INFO Required bonjour libs not found; service discovery disabled
>>> 10/07/08 12:40:26 1384 Toolkit config.py:625 DEBUG retrieved
>>> local IP address 172.16.10.135
>>> 10/07/08 12:40:26 1384 Toolkit toolkit.py:116 DEBUG
>>> Initializing AG Toolkit version 3.1 10/07/08 12:40:26 1384 Toolkit
>>> toolkit.py:117 INFO Command and arguments: ['C:\\Program
>>> Files\\AGTk-3\\bin\\VenueClient3.py']
>>> 10/07/08 12:40:26 1384 VenueClient preferences.py:188 DEBUG
>>> Preferences.LoadPreferences: open file
>>> 10/07/08 12:40:26 1384 Toolkit toolkit.py:166 INFO Logfile
>>> 10/07/08 12:40:26 1384 Toolkit venueclient3.py:137 INFO wx
>>> version is: 2.6.3.3
>>> 10/07/08 12:40:27 1384 VenueClient venueclient.py:529 DEBUG
>>> __StartWebService: service manager:
>>> http://172.16.10.135:11000/ServiceManager
>>> 10/07/08 12:40:27 1384 VenueClient venueclient.py:543 DEBUG
>>> __StartWebService: node service:
>>> http://172.16.10.135:11000/NodeService
>>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:640 INFO
>>> NodeService.GetConfigurations
>>> 10/07/08 12:40:27 1384 VenueClient venueclient.py:270 DEBUG
>>> Loading node configuration:
>>> <AccessGrid.Descriptions.NodeConfigDescription instance at
>>> 0x01FF65F8>
>>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:379 INFO
>>> NodeService.LoadConfiguration
>>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:398 INFO
>>> Trying to load node configuration from: C:\Program
>>> Files\AGTk-3\Config\nodeConfig\default
>>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:406 DEBUG
>>> section: node
>>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:408 DEBUG
>>> servicemanagers : servicemanager0
>>> section: service1
>>> packageName : VideoConsumerService.zip
>>> section: service0
>>> packageName : AudioService.zip
>>> serviceConfig : serviceconfig0
>>> section: servicemanager0
>>> url : 10/07/08 12:40:27 1384 NodeService
>>> agnodeservice.py:408 DEBUG builtin : 1
>>> services : service0 service1
>>> name : 10/07/08 12:40:27 1384 NodeService
>>> agnodeservice.py:406 DEBUG section: serviceconfig0
>>> Force AC97 : False
>>> Silence Suppression : Off
>>> Output Gain : 50
>>> Talk : Off
>>> Input Gain : 50
>>> 10/07/08 12:40:27 1384 NodeService agnodeservice.py:483 DEBUG
>>> using builtin service manager at
>>> 10/07/08 12:40:27 2272 ServiceManager agservicemanager.py:210
>>> INFO AGServiceManager.RemoveServices
>>> 10/07/08 12:40:27 3228 ServiceManager agservicemanager.py:103
>>> INFO AGServiceManager.AddService
>>> 10/07/08 12:40:27 3228 ServiceManager agservicemanager.py:132
>>> INFO Extracting service package to C:\Documents and
>>> Settings\administrator\Application
>>> Data\AccessGrid3\local_services\AudioService
>>> 10/07/08 12:40:27 3228 ServiceManager agservicemanager.py:378
>>> DEBUG Executing service AudioService
>>> 10/07/08 12:40:27 3228 ServiceManager agservicemanager.py:410
>>> INFO Running Service; options: ['C:\\Documents and
>>> Settings\\administrator\\Application
>>> Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py',
>>> '--port', 59743, '--serviceManagerUri',
>>> 'http://172.16.10.135:11000/ServiceManager', '--token',
>>> '0001000401687c0a20adc8195931c128']
>>> 10/07/08 12:40:27 3228 ProcessManager processmanager.py:62
>>> DEBUG Creating process: C:\Python24\pythonw.exe "C:\Documents and
>>> Data\AccessGrid3\local_services\AudioService\AudioService.py"
>>> --port 59743 --serviceManagerUri
>>> http://172.16.10.135:11000/ServiceManager --token
>>> 10/07/08 12:40:27 3228 ProcessManager processmanager.py:75
>>> DEBUG Create process returns: (<PyHANDLE:1028>, <PyHANDLE:1040>,
>>> 2212, 3524)
>>> 10/07/08 12:40:37 3228 ServiceManager agservicemanager.py:424
>>> INFO Service failed to register: 0001000401687c0a20adc8195931c128
>>> 10/07/08 12:40:37 3228 Hosting servicecontainer.py:17 ERROR
>>> Processing Failure
>>> exceptions:Exception
>>> Service failed to become reachable
>>> [trace: C:\Python24\lib\site-packages\ZSI\ServiceContainer.py:108:_Dispatch
>>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\interfaces\AGServiceManager_interface.py:960:soap_AddServiceByName
>>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py:97:AddServiceByName
>>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py:147:AddService
>>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py:425:__ExecuteService]
>>> 10/07/08 12:40:37 1384 NodeService agnodeservice.py:518 ERROR
>>> Exception adding service AudioService.zip
>>> Traceback (most recent call last):
>>> File
>>> "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGNodeService.py",
>>> line 515, in LoadConfiguration
>>> prefs.GetProfile())
>>> File
>>> "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\interfaces\AGServiceManager_client.py", line 60, in
>>> AddServiceByName
>>> response = self.binding.Receive(AddServiceByNameResponse.typecode)
>>> File "C:\Python24\lib\site-packages\ZSI\client.py", line 504, in Receive
>>> return _Binding.Receive(self, replytype, **kw)
>>> File "C:\Python24\lib\site-packages\ZSI\client.py", line 432, in Receive
>>> raise FaultException(msg)
>>> FaultException: Processing Failure
>>> 10/07/08 12:40:37 3864 ServiceManager agservicemanager.py:103
>>> 10/07/08 12:40:37 3864 ServiceManager agservicemanager.py:132
>>> Data\AccessGrid3\local_services\VideoConsumerService
>>> 10/07/08 12:40:37 3864 ServiceManager agservicemanager.py:378
>>> DEBUG Executing service VideoConsumerService
>>> 10/07/08 12:40:37 3864 ServiceManager agservicemanager.py:410
>>> Data\\AccessGrid3\\local_services\\VideoConsumerService\\VideoConsumerService.py', '--port', 51018, '--serviceManagerUri', 'http://172.16.10.135:11000/ServiceManager', '--token',
>>> '0001000401687c0a24b3d9e38373be44']
>>> 10/07/08 12:40:37 3864 ProcessManager processmanager.py:62
>>> Data\AccessGrid3\local_services\VideoConsumerService\VideoConsumerService.py" --port 51018 --serviceManagerUri http://172.16.10.135:11000/ServiceManager --token
>>> 10/07/08 12:40:37 3864 ProcessManager processmanager.py:75
>>> DEBUG Create process returns: (<PyHANDLE:12>, <PyHANDLE:1044>,
>>> 3832, 4080)
>>> 10/07/08 12:40:47 560 ServiceManager agservicemanager.py:234
>>> INFO Service registered: token,url =
>>> 0001000401687c0a20adc8195931c128,http://172.16.10.135:59743/Services/AudioService.0001000408a47c0a289309db6b1c8b07
>>> 10/07/08 12:40:47 3864 ServiceManager agservicemanager.py:422
>>> INFO Service registered: None 0001000401687c0a24b3d9e38373be44
>>> 10/07/08 12:40:47 3864 Hosting servicecontainer.py:17 ERROR
>>> Processing Failure
>>> exceptions:AttributeError
>>> 'NoneType' object has no attribute 'find'
>>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py:150:AddService
>>> C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\interfaces\AGService_client.py:210:SetPackageFile
>>> C:\Python24\lib\site-packages\ZSI\client.py:250:Send
>>> C:\Python24\lib\urlparse.py:50:urlparse
>>> C:\Python24\lib\urlparse.py:89:urlsplit]
>>> 10/07/08 12:40:47 1384 NodeService agnodeservice.py:518 ERROR
>>> Exception adding service VideoConsumerService.zip
>>> File
>>> prefs.GetProfile())
>>> File
>>> AddServiceByName
