[AG-TECH] Re: [AG-L] Lastest kernels (Fedora) causing issues with the AG Software
Christoph Willing
c.willing at uq.edu.au
Mon Jun 23 21:51:55 CDT 2008
On 24/06/2008, at 9:27 AM, Christoph Willing wrote:
> On 23/06/2008, at 11:58 AM, Jason Bell wrote:
>> Colleagues
>> This is just a quick email to warm about issues in regards to
>> updating
>> to the latest kernels in Fedora.
>> It has been found that using kernels 2.6.25.6-27.fc8 and
>> 2.6.25.4-10.fc8
>> (Fedora 8) has caused issues in regards to "multiple instances of vic
>> (producer and service) "locking up". Basically, only one of the
>> streams
>> will transmit, whilst the others will lock up.
> This isn't just a Fedora thing, I just had the same problem with
> another distro upgraded to 2.6.25.8 (although no vic lock ups in
> this case). Rather, its a kernel version (2.6.25) issue - in
> particular its interaction with python.
More info - I can replicate this bug with a clean install of 3.2 with
earlier kernel versions too. This means the problem is not a Linux
kernel version issue and, by extension, won't be limited to Linux but
will affect all platforms.
chris
> For those in a hurry, here's short fix until something more elegant
> is devised:
> 1. edit your ~/.AccessGrid/local_services/VideoService/
> VideoService.py (or VideoProducerService/VideoProducerService.py)
> to include a new import:
> from random import getrandbits
> 2. then search for "os.getpid()" and replace it with "getrandbits(16)"
> 3. now restart your VenueClient
> For those interested in the background to the problem, each time
> VideoService.py is run (i.e. for each video device) an individual
> temporary startup file is created containing various startup
> parameters including the video device name (/dev/video0 etc.). Each
> of these startup files should have a unique name, normally
> constructed using the process id of the current (VideoService.py)
> process using python's os.getpid() function. Previously this
> returned a new pid for each service, but for some reason it now
> (with kernel 2.6.25) returns the process id of the VenueClient
> itself. This means that each of the startup files now has the same
> name (in fact each new one overwites the previous one) resulting in
> all vics being started with the same startup file. Each vic then
> tries to open the single video device named in that startup file.
> Only the first vic to run succeeds in grabbing the video device,
> the others trying to grab it just cause problems.
> Replacing os.getpid() with getrandbits() ensures that each of the
> vic startup files has a unique name so that all vics can run as
> configured.
> chris
>> An interesting side effect is that you cannot manually "kill" the
>> locked
>> up "vic" process. Though xkill seems to work.
>> Additionally, if you add each stream manually (using configure node
>> service), rather than loading from a configuration, this appears
>> to work
>> fine.
>> Will keep you posted when through testing has been conducted and any
>> possible resolutions found.
>> Therefore, for now, I recommend not updating your kernel and/or
>> nvidia /
>> xorg drivers.
>> We are also investigating whether there are any issues with out
>> "Linux"
>> variants, but it appears that most other Linux distributions still
>> only
>> run 2.6.24.xxx kernel, rather than 2.6.25.xxx, which appears to be
>> the
>> problematic version.
>> Thanks for your time,
>> Jason.
>> Jason Bell, B.I.T. (Honours)
>> Research Systems Support Officer
>> Information Technology Division
>> Central Queensland University
>> Australian Research Collaboration Service
>> http://www.arcs.org.au/
>> E-mail : j.bell at cqu.edu.au
>> jason.bell at arcs.org.au
>> Work : +61 7 4930 9229
>> Mobile : 0409 630897
>> Postal : Building 19
>> Bruce Highway
>> Rockhampton, Queensland, Australia, 4702
>> Patience is a virtue.
>> But if I wanted Patience,
>> I would have become a Doctor.
>> accessgrid-l mailing list
>> accessgrid-l at lists.aarnet.edu.au
>> http://lists.aarnet.edu.au/mailman/listinfo/accessgrid-l
> Christoph Willing +617 3365 8350
> QCIF Access Grid Manager
> University of Queensland
