[AG-TECH] H.264 test.
Matthew Leszczenski
mxl9499 at rit.edu
Fri Jun 20 08:42:21 CDT 2008
Miguel,
RIT has at least 2 H264 streams going constantly, today I should be
adding another 1 or 2 to that to keep on unless there is a problem. This is
in the Argonne server, in the Rochester Institute of Technology main lobby.
Feel free to use this as a test venue if you need it, If I am not in a
meeting I will be listening in as well if you need anything.
Matthew Leszczenski
- Technical Assistant and Eagle Scout
- Undergraduate NSSA Major @ RIT
- Collaboration Technology Developer @ RIT Research Computing department
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Miguel Sáez
Sent: Friday, June 20, 2008 4:03 AM
To: AG-TECH list
Subject: [AG-TECH] H.264 test.
Hello,
I'm currently testing one of my Access Grid computers that might be the one
designed to work as display, to know if the hardware is good enough I need
to do an stress test, for it i would like to use H.264 so i can see if it
can handle more than four H.264 video flows at the same time.
Is there anyone able to do leave any H.264 video producers for a few hours,
if so just tell me the day, hour (preferibly close to UTC/GMT +2) and the
venue server where you're going to be.
Thanks a lot!
Miguel Ángel Sáez Llorente
Técnico de Comunicacións
Centro de Supercomputación de Galicia (CESGA) Avenida de Vigo, s/n (Campus
Sur)
15705 Santiago de Compostela - ESPAÑA
E-mail: msaez at cesga.es
Tel: +34 981 56 98 10 (ext. 246)
Fax: +34 981 59 46 16
Web: http://www.cesga.es/
