[AG-TECH]AG 3.2 beta 1 web broken link
Thomas D. Uram
turam at mcs.anl.gov
Thu Jul 24 17:57:16 CDT 2008
On 7/24/08 5:37 PM, Brad Knowles wrote:
> Brad Knowles wrote:
>> The audio service seems to be loaded when it comes up, but not the
>> video. I add that and save the configuration, then reboot the
>> application, and it comes back up again without the video. But the
>> USB Video class video device is the only thing I add.
> Of course, no sooner than I say this, and I decide to do a complete
> wipe and re-install of AG3.2b1 and all associated resources. Now
> everything seems to at least come up. The audio in rat is disabled by
> default, but that might actually be an intentional design choice. The
> video in vic now comes up as soon as I enter a venue, although the
> shape of the window had changed.
> My problem at the moment seems to be that there doesn't seem to be
> anyone around that I can find to test with, so I can't be sure my
> audio and video are transmitting correctly, or that I'm correctly
> receiving from them.
> Are there any venues with clients that are always on? Heck, even a
> plain webcam that was tied into the system would allow me to at least
> verify that I can receive data correctly....
You can use the Audio Reflector Venue on the APAG venue server, as
detailed in the "Using the Audio Reflector as a simple test" section on
this page:
http://www.accessgrid.org/node/354
>>> Very precisely, what were you doing when this happened? There does
>>> seem to be an issue with wxPython windows not becoming active, but I
>>> haven't seen this as persistently as you describe.
>> IIRC, that was primarily from the main venue client application, but
>> I saw somewhat similar problems from all the others.
> After the re-install, I tested this again. When the UI panes from rat
> or vic are frontmost and accepting user input, none of the OS menu
> options can be selected -- I'm guessing they don't have an associated
> menu to go along with them, so MacOS X dutifully switches to visible
> but non-selectable menus. After using command-tab to get to other
> programs (including either the AG launcher or the venue client), menu
> functions become available again.
fyi, When rat or vic are the active application on my mac (10.5), I have
File and Edit menus.
> I'll file a more detailed bug report a bit later.
