[AG-TECH]AG 3.2 beta 1 web broken link
Brad Knowles
bknowles at mail.utexas.edu
Thu Jul 24 17:14:01 CDT 2008
Thomas D. Uram wrote:
> What service(s) are loaded when it comes up? What services do you
> add/remove? Have you saved the configuration after adding/removing
> services?
The audio service seems to be loaded when it comes up, but not the video. I
add that and save the configuration, then reboot the application, and it
comes back up again without the video. But the USB Video class video device
is the only thing I add.
> Did you somehow determine that nothing was being transmitted? Have you
> tested audio with some remote person, or captured outgoing packets perhaps?
I haven't done testing with an external party, no. I'll try doing some
packet captures to see if anything is actually getting out or not.
> Very precisely, what were you doing when this happened? There does seem
> to be an issue with wxPython windows not becoming active, but I haven't
> seen this as persistently as you describe.
IIRC, that was primarily from the main venue client application, but I saw
somewhat similar problems from all the others.
> We certainly need better support for
> firewall traversal, including limiting the number and range of ports
> used. A clean description of your concerns will help. Putting that in
> a bug report will allow others to comment on their experiences, too.
When I file a bug report, I'll make sure to include slices from the firewall
log.
>> Do I need to create a screencast to show you guys everything that is
>> going wrong here?
> That might be helpful, but even it would need to be accompanied by some
> additional detail like log files, etc., to completely frame the problems.
I'll keep that in mind.
Brad Knowles <bknowles at mail.utexas.edu>
The University of Texas at Austin, Information Technology Services, ITS-Unix
