[AG-TECH] AG VenueClient/bajjer is an "Outsider" to Jabber/MU-Conference
Dinale, Justin
Justin.Dinale at dsto.defence.gov.au
Wed Jul 23 01:11:55 CDT 2008
Hi all,
Over the last few months I've been trying on and off to get AG working with Jabber on our intranet. I started off with Openfire, which as I can see from other posts (~April 2008) doesn't work with AG. But I would like to point out that AG does get to the stage of creating an account with Openfire, but is unable to join rooms (look at user list).
This week I used a virtual machine as a server, installing jabberd2 and mu-conference-0.7 to deal with messaging and conferencing. Gaim and Spark jabber clients were able to connect to the server, create rooms and send messages, but when I connected using AG I got the same behaviour as when using Openfire as a server:
AG was able to "connect", but no messages appear to be sent or received.
Looking through the mu-conference log file I was able to find the point the jabber server received the message sent from AG, which I have attached below:
Tue Jul 22 19:20:05 2008 MU-Conference: [conference.c:373 (_con_packets)] preprocessing packet <message xmlns='jabber:client' to='Jabber-Test(ag-server.dsto.defence.gov.au)@conference.dsto.defence.gov.au' type='groupchat' from='0a7bad1012d85487333f08e36863774f at jabber.dsto.defence.gov.au/default'><body>ertgswr</body></message>
Tue Jul 22 19:20:05 2008 MU-Conference: [conference.c:399 (_con_packets)] processing packet <message xmlns='jabber:client' to='Jabber-Test(ag-server.dsto.defence.gov.au)@conference.dsto.defence.gov.au' type='groupchat' from='0a7bad1012d85487333f08e36863774f at jabber.dsto.defence.gov.au/default'><body>ertgswr</body></message>
Tue Jul 22 19:20:05 2008 MU-Conference: [conference.c:468 (_con_packets)] 0a7bad1012d85487333f08e36863774f at jabber.dsto.defence.gov.au/default
Tue Jul 22 19:20:05 2008 MU-Conference: [conference.c:753 (_con_packets)] No cnu found for user
Tue Jul 22 19:20:05 2008 MU-Conference: [conference_room.c:772 (con_room_outsider)] handling request from outsider 0a7bad1012d85487333f08e36863774f at jabber.dsto.defence.gov.au/default to room jabber-test(ag-server.dsto.defence.gov.au)@conference.dsto.defence.gov.au
Tue Jul 22 19:20:05 2008 MU-Conference: [conference_room.c:784 (con_room_outsider)] Bouncing message from outsider
I got the similar error when using the python script from the link below:
http://www.accessgrid.org/developer/Jabber
I believe somehow bajjer/AG isn't actually entering and of the conferencing rooms, since it's being referred to as an "outsider".
Are there any plans for bajjer to be removed from AG, and use a different Jabber client?
If we're stuck with bajjer could someone please post the exact versions of linux distro (e.g. "Slackware 10.2" not just "Slackware"), jabberd14 and mu-conference they have on their functional server?
Cheers,
Justin Dinale
___________________________________________________________
Justin Dinale
Battlelab Engineer
Joint Operations Division
Defence Science and Technology Organisation
24 Fairbairn Ave, Fairbairn Business Park, Canberra ACT 2600
IMPORTANT: This email remains the property of the Australian Defence Organisation and is subject to the jurisdiction of section 70 of the CRIMES ACT 1914. If you have received this email in error, you are requested to contact the sender and delete the email.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080723/85e9f49d/attachment.htm>
