[AG-TECH] BTTV Capture & Mpeg / Large Video Size
Todd Zimmerman
toddz at sfu.ca
Wed Jul 9 15:50:04 CDT 2008
Hey All,
Not sure if it is a local configuration/driver issue or not, but I am having problems producing
'large' video sizes using my BTTV capture card. It's a WinTV PCI card with a Sony handycam plugged
into the s-video input.
I'm using vic-2.8ucl1.4.0beta
Here are my settings::
V4L2 (BT878), SVideo, NTSC, Mpeg4, Large. When I select 'Transmit', the stream 'info' still only
indicates 352x288. If I change the Signal to Auto (or PAL or SECAM) the picture goes green/pink
but the resolution moves to 704x576.
Is it _actually_ producing a larger video but the indication is wrong, or is it not capable of going
above 352x288??
I'd test V4L, but for some reason vic indicates it cannot open the device when trying to switch to v4l.
Any thoughts?
Todd
