[AG-TECH] Renaming service managers
Ryan McVeigh
rmcveigh at ucar.edu
Thu Jan 17 11:09:36 CST 2008
The problem has been fixed. We discovered that you have to be logged
in as the user that originally installed the software on that
machine. Once we logged on as that user communications between the
two cpu's started up again.
Thanks for your concern.
Ryan McVeigh
National Center for Atmospheric Research.
On Jan 17, 2008, at 9:45 AM, Thomas D. Uram wrote:
> Has this problem persisted for you? If so, restart the service
> manager components (first making sure that any existing ones have
> been killed), and try again. There is some local subnet host
> discovery (ala Bonjour) that could account for the problem you're
> seeing. Either way, if this is a bug I'd like to make sure it gets
> addressed.
> Tom
> On 1/10/08 5:04 PM, Ryan McVeigh wrote:
>> The hostnames properly resolve from the display machine in that
>> the host machine can find the other. But I'm not sure that the
>> configuration is being saved properly or that I'm loading the
>> newly saved node config. The only step I've attempted is changing
>> the configuration in the AG node management by starting from
>> scratch and when I go to fill in the new names in the Add Service
>> Manager Dialog box and hit OK the name shows up as it was before
>> within the node management window. Is there a step I am missing?
>> Thanks,
>> Ryan McVeigh
>> On Jan 10, 2008, at 3:54 PM, Thomas D. Uram wrote:
>>> I'm sure the AG software is not meddling with the hostnames, as
>>> it does no special caching of hostnames or anything. Two things
>>> come to mind:
>>> - Are you sure that the node configuration is being saved
>>> properly, using the new names? Are you sure you are loading the
>>> newly saved node configuration?
>>> - Do the new hostnames properly resolve from the display machine?
>>> Tom
>>> On 1/10/08 4:42 PM, Ryan McVeigh wrote:
>>>> Hey everyone,
>>>> Our network team changed our network to DHCP over the holidays
>>>> and changed the network names of our multi-node system. Now
>>>> neither pc can find each other within the Access Grid software.
>>>> If I try to create a new configuration in AG node management it
>>>> changes the name/IP to the name used prior to the network change.
>>>> How do you rename the service managers/computers within the AG
>>>> software so that they recognize each other?
>>>> Thanks,
>>>> Ryan McVeigh
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080117/fc88ecd3/attachment.htm>
