[AG-TECH] Logging level on the venueserver
Jon Johansson jon.johansson at ualberta.ca
Mon Feb 11 17:31:44 CST 2008
I'm running an AG 3.1 venueserver on Kubuntu. When the size
of the venueserver log hits 10 MB the server freezes.
Is there a command line switch to control the amount of logging?
I'm running as a non-root user so just setting the log file
to /dev/null won't work.
Jon.
~~   Jon I Johansson, Ph.D.              * Tel.: (780) 492-9304   ~~
~~   jon.johansson at ualberta.ca           * Fax.: (780) 492-1729   ~~
~~                                       * Office: G.S.B. 323C    ~~
~~   Programmer/Analyst          http://sciviz.aict.ualberta.ca   ~~
~~   Research Computing Support                                   ~~
~~   Room 352, General Services Building                          ~~
~~   Academic Information and Communication Technologies (AICT)   ~~
~~   University of Alberta                                        ~~
~~   Edmonton, Alberta, CANADA, T6G 2H1                           ~~
! "This  communication is intended for the use of the recipient to !
! which  it  is addressed, and may contain confidential, personal, !
! and/or  privileged  information.  Please contact  us immediately !
! if you are not the  intended  recipient  of  this communication. !
! If you are not the  intended  recipient  of  this communication, !
! do  not  copy,  distribute,   or   take   action  on   it.   Any !
! communication  received  in  error,  or subsequent reply, should !
! be deleted or destroyed."                                        !
More information about the ag-tech mailing list
