[AG-TECH] HD on AG
Vine, Derek A
Derek.Vine at usd.edu
Tue Dec 16 16:32:42 CST 2008
I should add that we plan on using Sony EVI HD1 cameras.
--Derek
-----Original Message-----
[mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Vine, Derek A
Sent: Tuesday, December 16, 2008 4:29 PM
To: Gurcharan S. Khanna; Luc Renambot
Cc: holub at ics.muni.cz; ag-tech
Subject: Re: [AG-TECH] HD on AG
So just for some clarity, if I wanted to have 3 or 4 HD video streams
from Windows XP or Vista, what type of cards are supported/recommended
and what changes need to be made to VIC?
Derek Vine
Communication Network Specialist
The University of South Dakota
414 East Clark Street
Vermillion, SD 57069
(605) 677-8215
dvine at usd.edu
[mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Gurcharan S.
Khanna
Sent: Monday, December 15, 2008 9:43 AM
To: Luc Renambot
Cc: holub at ics.muni.cz; ag-tech; Vine, Derek A
Luc,
Yes, UltraGrid does work on Macs, but not mine :-(
I've been working closely with Holub and team to get it working but it's
been a long struggle.
I think we'll get there but in the end, an integrated solution with AG
is really what
I'd like, so I'm eager to try that path, too.
-gurcharan
Luc Renambot wrote:
> On Dec 14, 2008, at 11:12 PM, Gurcharan S. Khanna wrote:
>> Doug,
>> Really? Wow. You mean I can get vic to do uncompressed HD just like
>> that?
>> I've spent months trying to get UltraGrid to work on Macs (I got it
>> working on
>> colleagues machines but not mine!). But the goal was always to
>> integrate it with
>> the AG later. If this could be done now..........hmmmmmm....that
>> would be the
>> answer I've been waiting for.
> I think the Ultragrid version from Csnet/ Masaryk univ. works on Mac:
> https://sitola.fi.muni.cz/igrid/index.php/UltraGrid
> Luc Renambot
> renambot at uic.edu Electronic Visualization Lab (M/C
152)
> EVL Phone (312) 996-3002 University of Illinois at Chicago
> EVL FAX (312) 413-7585 851 S. Morgan St. Room 1120 SEO
> http://www.evl.uic.edu/luc Chicago, IL 60607-7053
>> So, can somebody kind do this quickly and let me try it out? I could
>> eventually
>> get someone to do this but it would be from scratch in terms of their
>> experience
>> with this software.
>> If this works it would be so great and save so many hours of work for
>> me.
>> Anyone?
>> Thanks so much!
>> -gurcharan
>> Douglas Kosovic wrote:
>>> Hi,
>>>>>>> I, too, am extremely interested in vic supporting HD formats,
>>>>>>> (including uncompressed!) One of the issues is the encoding
>>>>>>> latency problem. Not sure there's a nice low latency encoding
>>>>>>> solution out there yet. Alternatively, we might look at cheap
>>>>>>> hardware encoders as the answer or HDMI cards to take the input
>>>>>>> from the camera.
>>>>>>> Can vic be made to take the output of, say, the BlackMagic
>>>>>>> Design HDMI card on a Mac?
>>> MacOS X UCL vic works out of the box with the BlackMagic Design HDMI
>>> capture card, but gets scalled down to 640x480 for the large capture
>>> option.
>>> A quick hack to add 1980x1080 support is to modify the following
>>> width & height lines in video/grabber-macosx.cpp :
>>> switch (decimate_) {
>>> case 1: // full-sized
>>> width_ = SP601_NTSC_WIDTH;
>>> height_ = SP601_NTSC_HEIGHT;
>>> to:
>>> width_ = 1920;
>>> height_ = 1080;
>>> Windows UCL vic on the other hand crashes with the BlackMagic Design
>>> HDMI capture card as it currently doesn't support the BlackMagic YUV
>>> colorspace.
>>> I wouldn't mind adding support for USB HD camcorders that support
>>> UVC (USB Video Class) H.264 streaming over USB, but I currently
>>> don't have access to one. Note: Not all USB based camcorders support
>>> UVC (e.g. Sony Hanycams).
>>>>>>> I am currently using AGDV under windows but would like to move
>>>>>>> to linux and use the HDV/DV linux vic for the DV part; i don't
>>>>>>> think it's encoding the HDV, just accepting it as input from the
>>>>>>> camera already encoded??? [chris?]
>>>>>> It is possible to just packetise the compressed data from a
>>>>>> camera, though as Chris points out it tends to have quite high
>>>>>> latency. That is why the ultragrid and derivatives used
>>>>>> uncompressed HD as their sources. VIC doesn't currently support
>>>>>> mpeg2 nor does support packetisation of an existing compressed
>>>>>> mpeg2 stream.
>>>>> wait, i thought chris' vic supported HDV, which i assume is mp4???
>>>> AFAIK most cameras support HDV - which is closely related to
MPEG-2:
>>>> http://en.wikipedia.org/wiki/HDV#HDV_720p
>>> Mostly just the DV firewire based camcorders, the harddisk USB based
>>> ones are now mostly AVCHD (MPEG-4 AVC/H.264).
>>>>> also, how hard/easy would it be for vic to support packetizing
>>>>> uncompressed HD?
>>>> Not that hard - one needs to read the [RTP and codec] specs and
>>>> code it up - or borrow someone else's....
>>>> Piers.
>>>>> -gurcharan
>>>>>> Piers
>>>>>>> My ideal would be to encode the presenter's laptop output and
>>>>>>> deliver that as just another video stream along side the
>>>>>>> presenter's video and the audience video and have autoplace lay
>>>>>>> them out nicely in a framed window, a la Adobe Connect or
>>>>>>> similar products, so the presenter, the slides, and additional
>>>>>>> commentary could be nicely recorded for later videoon demand
>>>>>>> playback.
>>>>>>> Just my opinion (and need),
>>>>>>> -gurcharan
>>>>>>> Piers O'Hanlon wrote:
>>>>>>>> Hi Derek,
>>>>>>>> In principle VIC should be able encode and decode HD video -
>>>>>>>> using one of the codecs that support such resolutions e.g.
>>>>>>>> H.264 or h261as.
>>>>>>>> One needs to modify some of the configuration code in VIC to
>>>>>>>> allow selection of larger resolutions (ie HD one needs
>>>>>>>> something from 720p (1024x720) upwards). And of course an HD
>>>>>>>> source is necessary. We don't currently have access to any HD
>>>>>>>> kit so haven't had a chance to work on it but anyone is welcome
>>>>>>>> to try!
>>>>>>>> Cheers,
>>>>>>>> Piers
>>>>>>>> 2008/10/22 Vine, Derek A <Derek.Vine at usd.edu>:
>>>>>>>>> Hello all,
>>>>>>>>> I am doing some research to spec. up a new AG room, and the
>>>>>>>>> group with the money is interested in HD video. I see that
>>>>>>>>> The University of Queensland has an HDV/DV VIC for Linux based
>>>>>>>>> systems already, but we would like to stay with Windows.
>>>>>>>>> I was just wondering what kind of time frame I can give them
>>>>>>>>> as to when HD will be supported in AG on Windows. In
>>>>>>>>> particular, an HD VIC that will take its video from a capture
>>>>>>>>> card with an HD-SDI input, like the one attached in the PDF.
>>> I didn't see the PDF, what colorspace does it support? If it's YUV
>>> 4:2:0, it would probably work with this vic:
>>> http://www.vislab.uq.edu.au/ag3/windows/vic-20081121.zip
>>> (which contained a fix for 480i DV white line artifacts)
>>> Anyway, I started working on adding support for more colorspaces to
>>> the Windows code a few weeks ago and I might get back to working on
>>> the code soon.
>>>>>>>>> Thank you in advance for your help.
>>>>>>>>> Derek Vine
>>>>>>>>> (605) 677-8215
>>>>>>>>> dvine at usd.edu
>> Gurcharan S. Khanna, Ph.D.
>> Director of Research Computing
>> Office of the Vice President for Research
>> http://rc.rit.edu
>> Assistant Research Professor, Ph.D. Program
>> Golisano College of Computing and Information Sciences
>> http://people.rit.edu/gskpop
>> Director, Interactive Collaboration Environments Laboratory,
>> Center for the Advancing the Study of Cyberinfrastructure
>> http://icelab.rit.edu
>> Rochester Institute of Technology
>> 1 Lomb Memorial Drive
>> Rochester, New York 14623-5603
>> Phone: 585-475-7504 ~ Cell: 585-451-8370
>> Email: gurcharan.khanna at rit.edu
>>> Hi,
>>>>>>> from the camera.
>>> option.
>>> to:
>>> width_ = 1920;
>>> height_ = 1080;
>>> colorspace.
>>>>>> mpeg2 stream.
MPEG-2:
>>>>> uncompressed HD?
>>>> Piers.
>>>>> -gurcharan
>>>>>> Piers
>>>>>>> playback.
>>>>>>> -gurcharan
>>>>>>>> Hi Derek,
>>>>>>>> H.264 or h261as.
>>>>>>>> to try!
>>>>>>>> Cheers,
>>>>>>>> Piers
>>>>>>>>> Hello all,
>>> the code soon.
>>>>>>>>> Derek Vine
>>>>>>>>> (605) 677-8215
>>>>>>>>> dvine at usd.edu
>> http://rc.rit.edu
http://rc.rit.edu
Founding Director, Interactive Collaboration Environments Laboratory
Center for Advancing the Study of Cyberinfrastructure
IT Collaboratory Bldg. 17, Room 3119
