[AG-TECH] video problem
Piers O'Hanlon
p.ohanlon at cs.ucl.ac.uk
Fri Aug 15 12:02:09 CDT 2008
Can you get a clear image if you select another input Port.. on the
Grabber - via the menu on the VideoProducer VIC? Or if you select a
different image size? Or if you try a different setting in the
Signal... item? Do you see the same problem with all cameras?
Piers.
2008/8/15 Fiona Bissett <fbiett at epcc.ed.ac.uk>:
> Hello,
> I'm trying to build a new node machine with the stable 3.1 release.
> The software builds correctly, but when I connect to a venue, the video
> just shows coloured bands
> rather than a clear picture.
> We're running the following hardware:
> XP SP2 pc.
> Matrox QID graphics card.
> Osprey 440 Capture Card.
> 3 Sony EVI-D31 cameras set to PAL/H261.
> Using the Osprey software, I can get a clear picture, but not via the AG
> toolkit.
> The setup works perfectly in 3.0.2. Does anyone have any ideas as to
> what I could tweak?
> Thanks,
> Fiona
> Fiona Bissett - Computing Support Officer
> EPCC,
> School of Physics,
> The University of Edinburgh,
> Room 3404,
> James Clerk Maxwell Building,
> Mayfield Road,
> Edinburgh. EH9 3JZ.
> Tel: +44 0131 650 7282
> Web: www.epcc.ed.ac.uk
> The University of Edinburgh is a charitable body, registered in
> Scotland, with registration number SC005336.
