[AG-TECH] VideoProducer refuses to initialize - urgent
Cortijo, David
dcortijo at bnl.gov
Fri Apr 25 09:46:08 CDT 2008
As an additional note to this - even if I try to use the Video machine as the Node Manager, I can't get the VideoProducerService to initialize properly. Also, I'm testing without any sort of firewall, so I doubt I'm losing communication between my machines.
-David
From: owner-ag-tech at mcs.anl.gov on behalf of Cortijo, David
Sent: Fri 4/25/2008 10:00 AM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] VideoProducer refuses to initialize - urgent
I've been working on a node that we had to upgrade from AG 2.1.2 to AG 3.1 this week to address problems talking to the node manager. At this point, it looks like I've got everything working except for the VideoProducer.
For some reason, when I try to add the VideoProducer service, I get the message "Add Service failed:VideoProducerService". My display machine/node manager can talk to the video producer machine just fine (I see messages generated in the Service Manager on the video machine).
I'm using 3 Conexant BtPCI WDM Video Capture cards. Is it possible that the VideoProducer process that tries to initialize just isn't seeing them correctly?
Below is what I see in ServiceManager.log on my Video machine when I initiate the service add from the Node Manager. Any insight on this would be helpful.
-David Cortijo
Brookhaven National Laboratory
04/25/08 09:58:15 3444 ServiceManager agservicemanager.py:103 INFO AGServiceManager.AddService
04/25/08 09:58:16 3444 ServiceManager agservicemanager.py:343 INFO Installed service version: 3.8, package version: 3.8
04/25/08 09:58:16 3444 ServiceManager agservicemanager.py:378 DEBUG Executing service VideoProducerService
04/25/08 09:58:16 3444 ServiceManager agservicemanager.py:410 INFO Running Service; options: ['C:\\Documents and Settings\\Richard Horwitz\\Application Data\\AccessGrid3\\local_services\\VideoProducerService\\VideoProducerService.py', '--port', 55023, '--serviceManagerUri', 'http://130.199.3.53:11000/ServiceManager', '--token', '82c7033508f826fcdb238234dea493fd']
04/25/08 09:58:16 3444 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Python24\python.exe "C:\Documents and Settings\Richard Horwitz\Application Data\AccessGrid3\local_services\VideoProducerService\VideoProducerService.py" --port 55023 --serviceManagerUri http://130.199.3.53:11000/ServiceManager --token 82c7033508f826fcdb238234dea493fd
04/25/08 09:58:16 3444 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:940>, <PyHANDLE:948>, 3456, 3452)
04/25/08 09:58:26 3444 ServiceManager agservicemanager.py:424 INFO Service failed to register: 82c7033508f826fcdb238234dea493fd
04/25/08 09:58:26 3444 Hosting servicecontainer.py:17 ERROR Processing Failure
exceptions:Exception
Service failed to become reachable
[trace: C:\Python24\lib\site-packages\ZSI\ServiceContainer.py:108:_Dispatch
C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\interfaces\AGServiceManager_interface.py:943:soap_AddService
C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py:147:AddService
C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGServiceManager.py:425:__ExecuteService]
