[AG-TECH] Audio Problems
Douglas Kosovic
douglask at itee.uq.edu.au
Wed Apr 23 06:13:24 CDT 2008
Hi Chris,
> I am running agtk 3.1 on Fedora core 7. I have been having problems just
> recently with feedback because the audio from the room is being routed
> straight back through the line-in to the amplifier. If I open the
> volume control panel and mute the line-in playback the problem goes away
> but then if I touch the slider in the rat it unmutes and the problem is
> back. I would have thought that if you hit talk in the rat that the
> playback would be muted. Any clues to why this is happening?
With your symptoms, I suspect you have either AC'97 or Intel HD onboard
audio. If so, you should enable force AC'97, see bottom of this page:
http://www.accessgrid.org/node/786
Cheers,
Doug
