[AG-TECH] Any more H.264 news?
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Mon Apr 21 05:32:06 CDT 2008
Generator Microsoft Word 11 (filtered medium) Hi,
I have tried firewire capture on windows and get similar results - I just get a kind of set of lines (see attached image).
I have a feeling that this is due to vic assuming that the camera source is a standard size (e.g. 352x288) when it isn' t. It looks like it is picking up an image from the camera (it changes when I move around in front of the camera) but it is only using some of that image (I think).
This was using a Sony MiniDV camera.
Andrew :)
--------------------------------------------------------- Andrew G D Rowley Senior Development Officer Research Computing Services The University of Manchester Kilburn Building, Oxford Road Manchester, M13 9PL t : +44 (0) 161 275 0685 e : Andrew.Rowley at manchester.ac.uk w : www.manchester.ac.uk/researchcomputing ---------------------------------------------------------
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Andrew Ford Sent: 18 April 2008 21:21 To: Douglas Kosovic Cc: ag-tech Subject: Re: [AG-TECH] Any more H.264 news?
On Wed, Apr 16, 2008 at 8:54 PM, Douglas Kosovic <douglask at itee.uq.edu.au> wrote:
UQ Vislab vic doesn't do any transcoding from DV (or HDV) firewire devices to other codecs, so if the codebase was merged as it stands now, it wouldn't do what you are trying to do anyway.
Well, doing raw DV without transcoding would be fine (if it were on both platforms), since we can spare the bandwidth - that's what we're already doing via the ExtendedVideo services on Windows, but we'd like to be able to move on to something more cross-platform.
Have you tried using DV4Linux so that your Camcorder can be seen as a V4L device? I haven't tried it myself.
Interesting, I'll have to try that out. Would vic theoretically be able to transmit 640 (or 720)x480 video from a V4L device?
As for the flashing verticle line artifacts on Windows, I don't seem them, but I was using a quad-core 2.6GHz Xeon.
We've seen it here on a couple of different systems - a Dell w/ a dual-core + hyperthreading 3.46Ghz CPU, and Suns with 2x dual-core 2.2Ghz Opterons - so I doubt it's CPU-related. Can anyone else chime in if they've tried the firewire capture on Windows? --Andrew
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080421/e85ae460/attachment.htm>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20080421/e85ae460/attachment.jpg>
