[AG-TECH] Computing Seminar - Stochastic Control of Heterogeneous Networks
Cindy Sievers
sievers at lanl.gov
Thu Apr 10 12:33:54 CDT 2008
Join us for a LANL Computing Seminar which will also be broadcast over the AG.
All sites welcome! Please RSVP to sievers at lanl.gov.
Please arrive in the venue at least 1/2/hour early for testing.
We will be using VNC, IP and password will be available in the venue chat.
Title: Stochastic Control of Heterogeneous Networks
When: Monday April 14th, 10am MDT, 1600-1730 UTC
Where: Mosaic Venue (off of the NCSA Lobby)
Speaker: Prof. Eytan Modiano (Massachusetts Institute of Technology)
Abstract:
In this talk we will describe algorithms for resource allocation in
heterogeneous
networks that include wirless, satellite and wired (e.g., optical)
sub-networks. We
consider a network with stochastic traffic and randomly varying channel
conditions.
In the first part of the talk we address the joint problem of flow control,
routing,
and scheduling in a heterogeneous network subject to quality of service
requirements. In particular, we will describe a dynamic control strategy that
maximizes the sum utility in the network, and can be used to achieve a wide
range of
service objectives. This scheduling algorithm is centralized in its nature and
requires the solution of a complex optimization problem. Hence, in the
second part
of the talk we will discuss distributed algorithms for solving the optimal
scheduling problem with low computation and communication complexity. In
particular, we will describe randomized algorithms for scheduling and
routing in a
wireless network that maximize network throughput with communication and
computation
requirements that are comparable to those of existing algorithms that can only
guarantee 50% throughput.
Bio:
Eytan Modiano received his B.S. degree in Electrical Engineering and Computer
Science from the University of Connecticut at Storrs in 1986 and his M.S.
and PhD
degrees, both in Electrical Engineering, from the University of Maryland,
College
Park, MD, in 1989 and 1992 respectively. He was a Naval Research
Laboratory Fellow
between 1987 and 1992 and a National Research Council Post Doctoral Fellow
during
1992-1993. Between 1993 and 1999 he was with MIT Lincoln Laboratory where
he was
the project leader for MIT Lincoln Laboratory's Next Generation Internet (NGI)
project. Since 1999 he has been on the faculty at MIT; where he is
presently an
Associate Professor. His research is on communication networks and
protocols with
emphasis on satellite, wireless, and optical networks.
He is currently an Associate Editor for IEEE Transactions on Information
Theory, The
International Journal of Satellite Communications, and for IEEE/ACM
Transactions on
Networking. He had served as a guest editor for IEEE JSAC special issue on WDM
network architectures; the Computer Networks Journal special issue on Broadband
Internet Access; the Journal of Communications and Networks special issue on
Wireless Ad-Hoc Networks; and for IEEE Journal of Lightwave Technology
special
issue on Optical Networks. He was the Technical Program co-chair
for Wiopt 2006,
IEEE Infocom 2007, and ACM MobiHoc 2007.
Cindy Sievers Los Alamos National Laboratory
sievers at lanl.gov Group CCS-1 MS B287
tel:505.665.6602 Advanced Computing
fax:505.665.4939 Los Alamos, NM 87544
