[AG-TECH] encrypted RAT session crashes
Kaizaad Bilimorya
kaizaad at sharcnet.ca
Tue Sep 25 15:05:02 CDT 2007
Hello,
AccessGrid Version: 3.0.2. (build 1)
MS Windows XP Professional Version 2002 SP 2
When connecting to our lobby this user's AccessGrid session works fine.
When entering any encrypted rooms RAT crashes (video works) and windows
gives the standard "report problem to Microsoft..."
Attached are the logs. The room is called "SiteLeaders". I have searched
the mailing lists and can not find any references to this type of error.
The user did install "Access Grid 3.1 beta1" before uninstalling and
dropping back to the current 3.0.2 version.
thanks
-k
09/25/07 15:13:42 5588 Toolkit config.py:563 ERROR Error setting hostname.
Traceback (most recent call last):
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Config.py", line 557, in SetHostname
sock.bind((hostname, 0))
File "<string>", line 1, in bind
gaierror: (7, 'getaddrinfo failed')
09/25/07 15:13:42 5588 Toolkit config.py:575 DEBUG retrieved local IP address 142.51.23.138
09/25/07 15:13:42 5588 Toolkit toolkit.py:111 DEBUG Initializing AG Toolkit version 3.0.2
09/25/07 15:13:42 5588 Toolkit toolkit.py:112 INFO Command and arguments: ['C:\\Program Files\\AGTk-3\\bin\\VenueClient3.py']
09/25/07 15:13:42 5588 VenueClient preferences.py:180 DEBUG Preferences.LoadPreferences: open file
09/25/07 15:13:42 5588 Toolkit toolkit.py:161 INFO Logfile Name: VenueClient.log
09/25/07 15:13:42 5588 Toolkit venueclient3.py:125 INFO wx version is: 2.6.2.1
09/25/07 15:13:42 5588 VenueClient venueclient.py:375 DEBUG __StartWebService: venueclient: http://142.51.23.138:11000/VenueClient
09/25/07 15:13:42 5588 VenueClient venueclient.py:386 DEBUG __StartWebService: service manager: http://142.51.23.138:11000/ServiceManager
09/25/07 15:13:42 5588 VenueClient venueclient.py:400 DEBUG __StartWebService: node service: http://142.51.23.138:11000/NodeService
09/25/07 15:13:42 5588 NodeService agnodeservice.py:635 INFO NodeService.GetConfigurations
09/25/07 15:13:42 5588 VenueClient venueclient.py:175 DEBUG Loading node configuration: <AccessGrid.Descriptions.NodeConfigDescription instance at 0x02CFC788>
09/25/07 15:13:42 5588 NodeService agnodeservice.py:375 INFO NodeService.LoadConfiguration
09/25/07 15:13:42 5588 NodeService agnodeservice.py:394 INFO Trying to load node configuration from: C:\Program Files\AGTk-3\Config\nodeConfig\default
09/25/07 15:13:42 5588 NodeService agnodeservice.py:402 DEBUG section: node
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG servicemanagers : servicemanager0
09/25/07 15:13:42 5588 NodeService agnodeservice.py:402 DEBUG section: service1
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG resource : resource1
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG serviceConfig : serviceconfig1
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG packageName : VideoService.zip
09/25/07 15:13:42 5588 NodeService agnodeservice.py:402 DEBUG section: service0
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG packageName : AudioService.zip
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG serviceConfig : serviceconfig0
09/25/07 15:13:42 5588 NodeService agnodeservice.py:402 DEBUG section: resource1
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG name : Logitech QuickCam Chat
09/25/07 15:13:42 5588 NodeService agnodeservice.py:402 DEBUG section: servicemanager0
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG services : service0 service1
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG builtin : 1
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG url :
09/25/07 15:13:42 5588 NodeService agnodeservice.py:402 DEBUG section: serviceconfig1
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Mute Sources : Off
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Frame Rate : 24
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Transmit on Startup : On
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Stream Name : Logitech QuickCam Chat
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Encoding : h261
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Standard : NTSC
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Bandwidth : 800
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Quality : 75
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Port : external-in
09/25/07 15:13:42 5588 NodeService agnodeservice.py:402 DEBUG section: serviceconfig0
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Use site id : On
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Silence Suppression : Off
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Output Gain : 50
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Talk : Off
09/25/07 15:13:42 5588 NodeService agnodeservice.py:404 DEBUG Input Gain : 50
09/25/07 15:13:42 5588 NodeService agnodeservice.py:479 DEBUG using builtin service manager at http://142.51.23.138:11000/ServiceManager
09/25/07 15:13:42 4028 ServiceManager agservicemanager.py:208 INFO AGServiceManager.RemoveServices
09/25/07 15:13:42 4332 ServiceManager agservicemanager.py:102 INFO AGServiceManager.AddService
09/25/07 15:13:42 4332 ServiceManager agservicemanager.py:339 INFO Installed service version: 3.7, package version: 3.4
09/25/07 15:13:42 4332 ServiceManager agservicemanager.py:374 DEBUG Executing service AudioService
09/25/07 15:13:42 4332 ServiceManager agservicemanager.py:406 INFO Running Service; options: ['C:\\Documents and Settings\\kpassi\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', 51529, '--serviceManagerUri', 'http://142.51.23.138:11000/ServiceManager', '--token', '8e33178a147c3968ae7586edebfdbdd4']
09/25/07 15:13:42 4332 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\AudioService.py" --port 51529 --serviceManagerUri http://142.51.23.138:11000/ServiceManager --token 8e33178a147c3968ae7586edebfdbdd4
09/25/07 15:13:43 4332 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:1180>, <PyHANDLE:1192>, 4740, 1268)
09/25/07 15:13:44 4332 ServiceManager agservicemanager.py:418 INFO Service registered: http://142.51.23.138:51529/Services/AudioService.8e33178a12843968aed75eaba471797c 8e33178a147c3968ae7586edebfdbdd4
09/25/07 15:13:44 2280 ServiceManager agservicemanager.py:102 INFO AGServiceManager.AddService
09/25/07 15:13:44 2280 ServiceManager agservicemanager.py:339 INFO Installed service version: 3.2, package version: 3.2
09/25/07 15:13:44 2280 ServiceManager agservicemanager.py:374 DEBUG Executing service VideoService
09/25/07 15:13:44 2280 ServiceManager agservicemanager.py:406 INFO Running Service; options: ['C:\\Documents and Settings\\kpassi\\Application Data\\AccessGrid3\\local_services\\VideoService\\VideoService.py', '--port', 54724, '--serviceManagerUri', 'http://142.51.23.138:11000/ServiceManager', '--token', '8e33178a147c3968aef7808832ee4e99']
09/25/07 15:13:44 2280 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\VideoService\VideoService.py" --port 54724 --serviceManagerUri http://142.51.23.138:11000/ServiceManager --token 8e33178a147c3968aef7808832ee4e99
09/25/07 15:13:44 2280 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:1088>, <PyHANDLE:1076>, 1304, 4256)
09/25/07 15:13:45 2280 ServiceManager agservicemanager.py:418 INFO Service registered: http://142.51.23.138:54724/Services/VideoService.8e33178a05183968af693315a9190b2a 8e33178a147c3968aef7808832ee4e99
09/25/07 15:13:45 5588 VenueClient venueclient.py:242 DEBUG get bridges from registry
09/25/07 15:13:45 5588 VenueClient venueclient.py:256 DEBUG set bridges in prefs
09/25/07 15:13:45 5588 VenueClient venueclient.py:265 DEBUG connect to bridge
09/25/07 15:13:46 5588 VenueClient venueclient.py:269 DEBUG exiting loadbridges
09/25/07 15:13:46 5588 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:13:46 5588 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:13:46 5160 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:13:46 5588 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:13:46 5588 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:13:46 5588 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 8000, 1, producer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1]
09/25/07 15:13:46 4208 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:13:46 5644 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:13:46 5588 NodeService agnodeservice.py:635 INFO NodeService.GetConfigurations
09/25/07 15:13:56 5588 VenueClientController venueclientcontroller.py:288 DEBUG UseBridgeCB called: bridge=SHARCNET (agbs.sharcnet.ca:20000)
09/25/07 15:13:56 5588 VenueClient venueclient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
09/25/07 15:13:56 5588 VenueClient venueclient.py:1195 DEBUG Setting node service streams
09/25/07 15:13:56 5588 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:13:56 5588 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:13:56 1940 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:13:57 5588 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:13:57 5588 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 8000, 1, producer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1]
09/25/07 15:13:57 5588 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a05183968af30071b3232d866, H261, 90000, 1, producer, video, 8e33178a05183968af30071b3232d866, H261, 90000, 1]
09/25/07 15:14:00 5588 VenueClientController venueclientcontroller.py:435 DEBUG VenueClientController calling Venue.EnterVenue
09/25/07 15:14:00 5588 VenueClient venueclient.py:1015 DEBUG EnterVenue; url=https://agvs.sharcnet.ca:8000/Venues/default
09/25/07 15:14:00 5588 NodeService agnodeservice.py:658 INFO NodeService.GetCapabilities
09/25/07 15:14:00 5588 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:14:00 1840 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:14:00 5588 VenueClient venueclient.py:1049 DEBUG calling __EnterVenue
09/25/07 15:14:00 5588 VenueClient venueclient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
09/25/07 15:14:01 5588 VenueClient venueclient.py:808 DEBUG after Venue.Enter
09/25/07 15:14:01 5588 VenueClient venueclient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
09/25/07 15:14:01 5588 VenueClient venueclient.py:812 DEBUG EnterVenue: done Venue.getstate
09/25/07 15:14:01 5588 VenueClient venueclient.py:835 DEBUG Setting isInVenue flag.
09/25/07 15:14:01 4892 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190747641
09/25/07 15:14:01 5588 VenueClient venueclient.py:1051 DEBUG after __EnterVenue
09/25/07 15:14:01 5588 VenueClient venueclientui.py:2586 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agvs.sharcnet.ca:8000/Venues/default
09/25/07 15:14:01 5588 VenueClient venueclientui.py:2699 DEBUG Entered venue
09/25/07 15:14:01 5588 VenueClientController venueclientcontroller.py:437 DEBUG VenueClientController after Venue.EnterVenue
09/25/07 15:14:02 5588 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kalpdrum Passi (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:14:02 4892 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:14:02 4892 JabberClient jabberclient.py:33 INFO Connecting to Jabber Server 'jabber.mcs.anl.gov' ...
09/25/07 15:14:02 4892 bajjer.io io.py:100 DEBUG RECV: <?xml version='1.0'?><stream:stream xmlns:stream='http://etherx.jabber.org/streams' id='46F95DFD' xmlns='jabber:client' from='jabber.mcs.anl.gov'>
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:65 DEBUG feed parser initialized
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:72 DEBUG start <{http://etherx.jabber.org/streams}stream> level=0
09/25/07 15:14:02 4892 JabberClient jabberclient.py:168 INFO Registering the user '42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' in jabber server ...
09/25/07 15:14:02 4892 bajjer.io io.py:122 DEBUG SEND: <iq type="get"><query xmlns="jabber:iq:register" /></iq>
09/25/07 15:14:02 4892 bajjer.io io.py:161 DEBUG RECV: <iq type='result'><query xmlns='jabber:iq:register'><password/><password/>
<instructions>Choose a username and password to register with this server.</instructions>
<name/>
<email/>
<username/></query></iq>
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}iq> level=1
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}query> level=2
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}password> level=3
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}password> level=3
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}instructions> level=3
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}instructions> level=3
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}name> level=3
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}name> level=3
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}email> level=3
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}email> level=3
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}username> level=3
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}username> level=3
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}query> level=2
09/25/07 15:14:02 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}iq> level=1
09/25/07 15:14:02 4892 bajjer.io io.py:122 DEBUG SEND: <iq type="set"><query xmlns="jabber:iq:register"><username>42611a03611e3968b7fd3eb7e3a23041</username><password>42611a03611e3968b7fd3eb7e3a23041</password></query></iq>
09/25/07 15:14:02 4892 bajjer.io io.py:161 DEBUG RECV: <iq type='result'/>
09/25/07 15:14:02 5588 GroupMsgClient groupmsgclient.py:112 INFO Connected. Connection ID: 42611a03611e3968b7fd3eb7e3a23041
09/25/07 15:14:02 5588 EventClient insecurevenueeventclient.py:60 INFO BaseVenueEventClient made connection.
09/25/07 15:14:03 4892 JabberClient jabberclient.py:177 INFO Attempting to log in as 42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default ...
09/25/07 15:14:03 4892 bajjer.io io.py:122 DEBUG SEND: <iq type="get"><query xmlns="jabber:iq:auth"><username>42611a03611e3968b7fd3eb7e3a23041</username></query></iq>
09/25/07 15:14:03 4892 bajjer.io io.py:161 DEBUG RECV: <iq type='result'><query xmlns='jabber:iq:auth'><username>42611a03611e3968b7fd3eb7e3a23041</username><digest/><password/><resource/></query></iq>
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}iq> level=1
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}query> level=2
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}username> level=3
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}username> level=3
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}digest> level=3
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}digest> level=3
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}password> level=3
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}password> level=3
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}resource> level=3
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}resource> level=3
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}query> level=2
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}iq> level=1
09/25/07 15:14:03 4892 bajjer.stream stream.py:326 DEBUG Recv: <gov.lbl.dsd.bajjer.stanza.Iq object at 0x02D2B910>
09/25/07 15:14:03 4892 bajjer.stream stream.py:342 DEBUG performing 'digest' authentication
09/25/07 15:14:03 4892 bajjer.io io.py:122 DEBUG SEND: <iq type="set"><query xmlns="jabber:iq:auth"><resource>default</resource><username>42611a03611e3968b7fd3eb7e3a23041</username><digest>bd321ce428581868735ead6795656809362dd355</digest></query></iq>
09/25/07 15:14:03 4892 bajjer.io io.py:161 DEBUG RECV: <iq type='result' id='pthsock_client_auth_ID'/>
09/25/07 15:14:03 4892 bajjer.stream stream.py:351 DEBUG Authorization succeeded
09/25/07 15:14:03 4892 bajjer.io io.py:122 DEBUG SEND: <iq from="42611a03611e3968b7fd3eb7e3a23041" type="get"><query xmlns="jabber:iq:roster" /></iq>
09/25/07 15:14:03 4892 bajjer.io io.py:161 DEBUG RECV: <iq from='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='result'><query xmlns='jabber:iq:roster'/></iq>
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:roster}query> level=2
09/25/07 15:14:03 4892 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:roster}query> level=2
09/25/07 15:14:03 4892 bajjer.io io.py:122 DEBUG SEND: <presence />
09/25/07 15:14:03 4892 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'available'...
09/25/07 15:14:03 4892 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="available"><x /></presence>
09/25/07 15:14:03 4892 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address 224.2.210.59/55452
09/25/07 15:14:03 4892 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:14:03 4892 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:14:03 4892 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50096
09/25/07 15:14:03 4892 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50040
09/25/07 15:14:03 3292 bajjer.io io.py:161 DEBUG RECV: <message from='jabber.mcs.anl.gov' to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov'>
<subject>Welcome!</subject>
<body>Welcome to the Access Grid Jabber server @ jabber.mcs.anl.gov -- we hope you enjoy this service! For information about how to use Jabber, visit the Jabber User's Guide at http://jabbermanual.jabberstudio.org/</body>
<x xmlns='jabber:x:delay' from='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov' stamp='20070925T19:14:05'>Offline Storage</x></message>
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}subject> level=2
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}subject> level=2
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:14:03 3292 JabberClient jabberclient.py:133 DEBUG jabber.mcs.anl.go: Welcome to the Access Grid Jabber server @ jabber.mcs.anl.gov -- we hope you enjoy this service! For information about how to use Jabber, visit the Jabber User's Guide at http://jabbermanual.jabberstudio.org/
09/25/07 15:14:03 3292 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:14:03 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:14:03 3292 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is available (None / None)
09/25/07 15:14:03 3292 VenueClient venueclientui.py:2308 DEBUG add user: Kalpdrum Passi
09/25/07 15:14:03 3292 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>sharcnet-venue-server-lobby(agvs.sharcnet.ca)</body></message>
09/25/07 15:14:04 4892 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50116
09/25/07 15:14:04 4892 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:14:04 4892 VenueClient venueclient.py:951 INFO Beacon being reconfigured, stopping running beacon
09/25/07 15:14:04 4892 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address agbs.sharcnet.ca/50040
09/25/07 15:14:04 4892 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:14:04 4892 VenueClient venueclient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
09/25/07 15:14:04 4892 VenueClient venueclient.py:1195 DEBUG Setting node service streams
09/25/07 15:14:04 4892 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:14:04 4892 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:14:04 4588 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:14:04 3292 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: sharcnet-venue-server-lobby(agvs.sharcnet.ca)
09/25/07 15:14:04 3292 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:14:04 3292 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><x/><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya' stamp='20070925T17:57:59'/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:14:04 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:14:04 4892 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:14:04 3292 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
09/25/07 15:14:04 3292 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya is available (None / None)
09/25/07 15:14:04 5588 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kaizaad Bilimorya (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:14:04 4892 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 8000, 1, producer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1]
09/25/07 15:14:04 4892 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 8000, 1, producer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1]) to service: http://142.51.23.138:51529/Services/AudioService.8e33178a12843968aed75eaba471797c
09/25/07 15:14:04 3292 VenueClient venueclientui.py:2308 DEBUG add user: Kaizaad Bilimorya
09/25/07 15:14:04 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>no rat?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:44'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:04 4892 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a05183968af30071b3232d866, H261, 90000, 1, producer, video, 8e33178a05183968af30071b3232d866, H261, 90000, 1]
09/25/07 15:14:04 4892 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, video, 42611a040f043962becd9b9c9e410277, H261, 90000, 1, producer, video, 42611a040f043962becd9b9c9e410277, H261, 90000, 1]) to service: http://142.51.23.138:54724/Services/VideoService.8e33178a05183968af693315a9190b2a
09/25/07 15:14:04 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>no</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:49'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:04 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I can't do much, have an hour-glass in my VenueClient config</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:04 5800 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:14:04 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>killall -9 python</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:37'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:04 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>dave in the room?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:54'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:04 4892 VenueClient venueclient.py:914 DEBUG Updating client profile cache.
09/25/07 15:14:04 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>how did you know?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:51:02'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:04 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>Say something</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:52:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:04 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>hello?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:56:30'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:04 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>We can hear you</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:10'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:05 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>can you hear us?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:05 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:14:05 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:14:05 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:14:05 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:14:05 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:14:05 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:14:05 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I don't have a mic</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:58:41'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:05 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I am coming down</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:23'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:05 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>They are all encrypted except the nonEncrypted</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:51'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:05 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>did you go away. I can't see you in the lobby</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:12:59'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:05 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>can you hear me</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:14:19'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:05 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>ttps://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:49:20'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:05 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>https://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:02:56'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:05 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>:\Documents and Settings\Your_Windows_Login\Application Data\AccessGrid3\</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:06:16'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:14:05 3292 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default'><body>Kalpdrum Passi has joined this session</body></message>
09/25/07 15:14:06 3292 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: Kalpdrum Passi has joined this session
09/25/07 15:14:28 5588 VenueClient venueclient.py:1132 INFO ExitVenue
09/25/07 15:14:28 5588 VenueClient venueclient.py:1173 INFO ExitVenue: Stopping node services
09/25/07 15:14:28 5588 NodeService agnodeservice.py:301 INFO NodeService.StopServices
09/25/07 15:14:28 2512 ServiceManager agservicemanager.py:225 INFO AGServiceManager.StopServices
09/25/07 15:14:29 5588 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:14:29 5588 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:14:29 508 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:14:29 5588 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:14:29 5588 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 8000, 1, producer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1]
09/25/07 15:14:29 5588 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a05183968af30071b3232d866, H261, 90000, 1, producer, video, 8e33178a05183968af30071b3232d866, H261, 90000, 1]
09/25/07 15:14:29 5588 VenueClient venueclient.py:1103 DEBUG ExitVenue: Stop event client obj
09/25/07 15:14:29 5588 VenueClient venueclient.py:1105 DEBUG ExitVenue: Remove event client reference
09/25/07 15:14:29 5588 VenueClient venueclient.py:1110 INFO ExitVenue: Stopping text client
09/25/07 15:14:29 5588 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'unavailable'...
09/25/07 15:14:29 5588 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="unavailable"><x /></presence>
09/25/07 15:14:29 5588 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:14:29 5588 VenueClientController venueclientcontroller.py:435 DEBUG VenueClientController calling Venue.EnterVenue
09/25/07 15:14:29 5588 VenueClient venueclient.py:1015 DEBUG EnterVenue; url=https://agvs.sharcnet.ca:8000/Venues/42611c8c20f11b5ccbcfc6b3dc40f3032e
09/25/07 15:14:29 5588 NodeService agnodeservice.py:658 INFO NodeService.GetCapabilities
09/25/07 15:14:29 1684 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:14:29 3292 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='unavailable' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='none'/></x></presence>
09/25/07 15:14:29 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:14:29 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:14:29 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:14:29 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:14:29 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:14:29 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:14:29 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:14:29 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:14:29 3292 JabberClient jabberclient.py:148 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is unavailable (None / None)
09/25/07 15:14:29 5588 VenueClient venueclient.py:1049 DEBUG calling __EnterVenue
09/25/07 15:14:29 5588 VenueClient venueclient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
09/25/07 15:14:29 3292 VenueClient venueclientui.py:2322 DEBUG remove user: Kalpdrum Passi
09/25/07 15:14:29 4308 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:14:30 5588 VenueClient venueclient.py:808 DEBUG after Venue.Enter
09/25/07 15:14:30 5588 VenueClient venueclient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
09/25/07 15:14:30 5588 VenueClient venueclient.py:812 DEBUG EnterVenue: done Venue.getstate
09/25/07 15:14:30 5588 VenueClient venueclient.py:835 DEBUG Setting isInVenue flag.
09/25/07 15:14:30 4128 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190747670
09/25/07 15:14:30 5588 VenueClient venueclient.py:1051 DEBUG after __EnterVenue
09/25/07 15:14:30 5588 VenueClient venueclientui.py:2586 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agvs.sharcnet.ca:8000/Venues/42611c8c20f11b5ccbcfc6b3dc40f3032e
09/25/07 15:14:30 5588 VenueClient venueclientui.py:2699 DEBUG Entered venue
09/25/07 15:14:30 5588 VenueClientController venueclientcontroller.py:437 DEBUG VenueClientController after Venue.EnterVenue
09/25/07 15:14:30 5588 VenueClient venueclientui.py:3349 DEBUG ContentListPanel.RemoveParticipant: Remove participant
09/25/07 15:14:30 5588 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant UoGuelph-SHARCNET (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:14:30 5588 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kalpdrum Passi (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:14:31 4128 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:14:31 4128 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'available'...
09/25/07 15:14:31 4128 bajjer.io io.py:122 DEBUG SEND: <presence to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="available"><x /></presence>
09/25/07 15:14:31 4128 VenueClient venueclient.py:951 INFO Beacon being reconfigured, stopping running beacon
09/25/07 15:14:31 4128 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:14:31 4128 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address 224.2.188.74/64628
09/25/07 15:14:31 4128 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:14:31 4128 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:14:31 4128 VenueClient venueclient.py:1264 ERROR VenueClient.UpdateStream: Failed to connect to bridge SHARCNET
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\VenueClient.py", line 1259, in UpdateStream
stream.location = qbc.JoinBridge(stream.networkLocations[0])
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\QuickBridgeClient.py", line 34, in JoinBridge
l = self.serverProxy.JoinBridge(multicastNetworkLocation)
File "C:\Python23\lib\xmlrpclib.py", line 1032, in __call__
return self.__send(self.__name, args)
File "C:\Python23\lib\xmlrpclib.py", line 1319, in __request
verbose=self.__verbose
File "C:\Python23\lib\xmlrpclib.py", line 1083, in request
return self._parse_response(h.getfile(), sock)
File "C:\Python23\lib\xmlrpclib.py", line 1222, in _parse_response
return u.close()
File "C:\Python23\lib\xmlrpclib.py", line 745, in close
raise Fault(**self._stack[0])
Fault: <Fault 1: 'AccessGrid.NetworkAddressAllocator.NoFreePortsError:'>
09/25/07 15:14:31 4128 VenueClient venueclient.py:902 DEBUG UpdateNodeService: Couldn't update stream with transport/provider info
09/25/07 15:14:31 4128 VenueClient venueclient.py:914 DEBUG Updating client profile cache.
09/25/07 15:14:31 3292 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:14:31 3292 JabberClient jabberclient.py:145 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is available (None / None)
09/25/07 15:14:31 3292 VenueClient venueclientui.py:2308 DEBUG add user: Kalpdrum Passi
09/25/07 15:14:31 3292 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>siteleaders(agvs.sharcnet.ca)</body></message>
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:14:31 3292 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: siteleaders(agvs.sharcnet.ca)
09/25/07 15:14:31 3292 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
09/25/07 15:14:31 3292 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><x/><x xmlns='jabber:x:delay' from='SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET' stamp='20070925T19:13:21'/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='owner' role='moderator'/></x></presence>
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:14:31 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:14:31 5588 EventClient insecurevenueeventclient.py:77 INFO BaseVenueEventClient lost connection.
09/25/07 15:14:31 3292 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
09/25/07 15:14:31 3292 JabberClient jabberclient.py:145 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET is available (None / None)
09/25/07 15:14:31 5588 GroupMsgClient groupmsgclient.py:112 INFO Connected. Connection ID: 42611a03611e3968c342a02616390921
09/25/07 15:14:31 5588 EventClient insecurevenueeventclient.py:60 INFO BaseVenueEventClient made connection.
09/25/07 15:14:31 3292 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:14:31 3292 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default'><body>Kalpdrum Passi has joined this session</body></message>
09/25/07 15:14:31 3292 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: Kalpdrum Passi has joined this session
09/25/07 15:15:07 1456 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190747707
09/25/07 15:15:07 1456 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:15:33 5588 VenueClient venueclient.py:1132 INFO ExitVenue
09/25/07 15:15:33 5588 VenueClient venueclient.py:1173 INFO ExitVenue: Stopping node services
09/25/07 15:15:33 5588 NodeService agnodeservice.py:301 INFO NodeService.StopServices
09/25/07 15:15:33 4120 ServiceManager agservicemanager.py:225 INFO AGServiceManager.StopServices
09/25/07 15:15:33 5588 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:15:33 5588 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:15:33 5704 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:15:33 5588 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:15:33 5588 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 8000, 1, producer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1]
09/25/07 15:15:33 5588 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a05183968af30071b3232d866, H261, 90000, 1, producer, video, 8e33178a05183968af30071b3232d866, H261, 90000, 1]
09/25/07 15:15:33 5588 VenueClient venueclient.py:1103 DEBUG ExitVenue: Stop event client obj
09/25/07 15:15:33 5588 VenueClient venueclient.py:1105 DEBUG ExitVenue: Remove event client reference
09/25/07 15:15:33 5588 VenueClient venueclient.py:1110 INFO ExitVenue: Stopping text client
09/25/07 15:15:33 5588 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'unavailable'...
09/25/07 15:15:33 5588 bajjer.io io.py:122 DEBUG SEND: <presence to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="unavailable"><x /></presence>
09/25/07 15:15:33 5588 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:15:33 5588 VenueClientController venueclientcontroller.py:435 DEBUG VenueClientController calling Venue.EnterVenue
09/25/07 15:15:33 5588 VenueClient venueclient.py:1015 DEBUG EnterVenue; url=https://agvs.sharcnet.ca:8000/Venues/42611c8c1fd71b5cc961de7d32e40d5f6b
09/25/07 15:15:33 5588 NodeService agnodeservice.py:658 INFO NodeService.GetCapabilities
09/25/07 15:15:33 5556 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:15:33 3292 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='unavailable' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='none'/></x></presence>
09/25/07 15:15:33 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:15:33 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:15:33 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:15:33 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:15:33 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:15:33 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:15:33 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:15:33 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:15:33 3292 JabberClient jabberclient.py:148 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is unavailable (None / None)
09/25/07 15:15:33 5588 VenueClient venueclient.py:1049 DEBUG calling __EnterVenue
09/25/07 15:15:33 5588 VenueClient venueclient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
09/25/07 15:15:33 3292 VenueClient venueclientui.py:2322 DEBUG remove user: Kalpdrum Passi
09/25/07 15:15:34 5588 VenueClient venueclient.py:808 DEBUG after Venue.Enter
09/25/07 15:15:34 5588 VenueClient venueclient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
09/25/07 15:15:34 5588 VenueClient venueclient.py:812 DEBUG EnterVenue: done Venue.getstate
09/25/07 15:15:34 4380 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:15:34 5588 VenueClient venueclient.py:835 DEBUG Setting isInVenue flag.
09/25/07 15:15:34 4844 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190747734
09/25/07 15:15:34 5588 VenueClient venueclient.py:1051 DEBUG after __EnterVenue
09/25/07 15:15:34 5588 VenueClient venueclientui.py:2586 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agvs.sharcnet.ca:8000/Venues/42611c8c1fd71b5cc961de7d32e40d5f6b
09/25/07 15:15:34 5588 VenueClient venueclientui.py:2699 DEBUG Entered venue
09/25/07 15:15:34 5588 VenueClientController venueclientcontroller.py:437 DEBUG VenueClientController after Venue.EnterVenue
09/25/07 15:15:34 5588 VenueClient venueclientui.py:3349 DEBUG ContentListPanel.RemoveParticipant: Remove participant
09/25/07 15:15:34 5588 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kalpdrum Passi (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:15:34 4844 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:15:34 4844 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'available'...
09/25/07 15:15:34 4844 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="available"><x /></presence>
09/25/07 15:15:34 4844 VenueClient venueclient.py:951 INFO Beacon being reconfigured, stopping running beacon
09/25/07 15:15:34 4844 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:15:34 4844 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address 224.2.180.63/51542
09/25/07 15:15:35 4844 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:15:35 4844 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:15:35 4844 VenueClient venueclient.py:1264 ERROR VenueClient.UpdateStream: Failed to connect to bridge SHARCNET
return u.close()
09/25/07 15:15:35 4844 VenueClient venueclient.py:902 DEBUG UpdateNodeService: Couldn't update stream with transport/provider info
09/25/07 15:15:35 4844 VenueClient venueclient.py:914 DEBUG Updating client profile cache.
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:15:35 3292 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is available (None / None)
09/25/07 15:15:35 3292 VenueClient venueclientui.py:2308 DEBUG add user: Kalpdrum Passi
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>sharcnet-venue-server-lobby(agvs.sharcnet.ca)</body></message>
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:15:35 5588 EventClient insecurevenueeventclient.py:77 INFO BaseVenueEventClient lost connection.
09/25/07 15:15:35 3292 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: sharcnet-venue-server-lobby(agvs.sharcnet.ca)
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><x/><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya' stamp='20070925T17:57:59'/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:15:35 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:15:35 5588 GroupMsgClient groupmsgclient.py:112 INFO Connected. Connection ID: 42611a03611e3968dc3cda93a018e9c6
09/25/07 15:15:35 5588 EventClient insecurevenueeventclient.py:60 INFO BaseVenueEventClient made connection.
09/25/07 15:15:35 3292 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
09/25/07 15:15:35 3292 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya is available (None / None)
09/25/07 15:15:35 5588 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kaizaad Bilimorya (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:15:35 3292 VenueClient venueclientui.py:2308 DEBUG add user: Kaizaad Bilimorya
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>no rat?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:44'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>no</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:49'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I can't do much, have an hour-glass in my VenueClient config</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>killall -9 python</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:37'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>dave in the room?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:54'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>how did you know?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:51:02'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>Say something</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:52:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>hello?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:56:30'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>We can hear you</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:10'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>can you hear us?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:35 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I don't have a mic</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:58:41'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:36 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I am coming down</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:23'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:36 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:15:36 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:15:36 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:15:36 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:15:36 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:15:36 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:15:36 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>They are all encrypted except the nonEncrypted</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:51'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:36 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>did you go away. I can't see you in the lobby</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:12:59'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:36 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>can you hear me</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:14:19'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:36 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>ttps://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:49:20'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:36 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>https://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:02:56'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:36 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>:\Documents and Settings\Your_Windows_Login\Application Data\AccessGrid3\</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:06:16'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:15:36 3292 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default'><body>Kalpdrum Passi has joined this session</body></message>
09/25/07 15:15:37 3292 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: Kalpdrum Passi has joined this session
09/25/07 15:16:10 3112 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190747770
09/25/07 15:16:11 3112 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:16:39 5588 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:16:39 5588 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:16:39 5588 bajjer.io io.py:122 DEBUG SEND: <message to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>i cannot see the video or the audio</body></message>
09/25/07 15:16:39 3292 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i cannot see the video or the audio</body></message>
09/25/07 15:16:39 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:16:39 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:16:39 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:16:39 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:16:47 5780 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190747807
09/25/07 15:16:47 5780 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:16:59 5588 VenueClient venueclientui.py:1300 DEBUG VenueClientFrame.ManageNodeCB: open node management
09/25/07 15:16:59 5588 VenueClient venueclientui.py:1301 DEBUG nodeservice url: <AccessGrid.AGNodeService.AGNodeService instance at 0x02CFC5A8>
09/25/07 15:16:59 5588 NodeService agnodeservice.py:248 INFO NodeService.GetServiceManagers
09/25/07 15:16:59 5840 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:17:23 5220 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190747843
09/25/07 15:17:23 5220 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:17:25 5588 VenueClient venueclientui.py:2209 INFO --------- END VenueClient
09/25/07 15:17:25 5588 VenueClient venueclient.py:1132 INFO ExitVenue
09/25/07 15:17:25 5588 VenueClient venueclient.py:1173 INFO ExitVenue: Stopping node services
09/25/07 15:17:25 5588 NodeService agnodeservice.py:301 INFO NodeService.StopServices
09/25/07 15:17:25 5988 ServiceManager agservicemanager.py:225 INFO AGServiceManager.StopServices
09/25/07 15:17:25 5588 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:17:25 5588 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:17:25 244 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:17:26 5588 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:17:26 5588 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 8000, 1, producer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1]
09/25/07 15:17:26 5588 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a05183968af30071b3232d866, H261, 90000, 1, producer, video, 8e33178a05183968af30071b3232d866, H261, 90000, 1]
09/25/07 15:17:26 5588 VenueClient venueclient.py:1103 DEBUG ExitVenue: Stop event client obj
09/25/07 15:17:26 5588 VenueClient venueclient.py:1105 DEBUG ExitVenue: Remove event client reference
09/25/07 15:17:26 5588 VenueClient venueclient.py:1110 INFO ExitVenue: Stopping text client
09/25/07 15:17:26 5588 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'unavailable'...
09/25/07 15:17:26 5588 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="unavailable"><x /></presence>
09/25/07 15:17:26 5588 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:17:26 5588 ServiceManager agservicemanager.py:70 INFO AGServiceManager.Shutdown
09/25/07 15:17:26 5588 ServiceManager agservicemanager.py:71 INFO Remove services
09/25/07 15:17:26 5588 ServiceManager agservicemanager.py:208 INFO AGServiceManager.RemoveServices
09/25/07 15:17:26 5588 ServiceManager agservicemanager.py:162 INFO AGServiceManager.RemoveService
09/25/07 15:17:26 3292 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3968b7fd3eb7e3a23041 at jabber.mcs.anl.gov/default' type='unavailable' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='none'/></x></presence>
09/25/07 15:17:26 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:17:26 3292 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:17:26 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:17:26 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:17:26 3292 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:17:26 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:17:26 3292 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:17:26 3292 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:17:26 3292 JabberClient jabberclient.py:148 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is unavailable (None / None)
09/25/07 15:17:26 3292 VenueClient venueclientui.py:2322 DEBUG remove user: Kalpdrum Passi
09/25/07 15:17:26 5156 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:17:26 5588 ProcessManager processmanager.py:136 WARNING Couldn't terminate process <PyHANDLE:1180> cleanly (258)
09/25/07 15:17:27 5588 ProcessManager processmanager.py:136 WARNING Couldn't terminate process <PyHANDLE:1088> cleanly (258)
09/25/07 15:17:27 5588 ServiceManager agservicemanager.py:73 INFO Stop network interface
09/25/07 15:17:27 5588 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:17:34 4376 Toolkit config.py:563 ERROR Error setting hostname.
Traceback (most recent call last):
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Config.py", line 557, in SetHostname
sock.bind((hostname, 0))
File "<string>", line 1, in bind
gaierror: (7, 'getaddrinfo failed')
09/25/07 15:17:34 4376 Toolkit config.py:575 DEBUG retrieved local IP address 142.51.23.138
09/25/07 15:17:34 4376 Toolkit toolkit.py:111 DEBUG Initializing AG Toolkit version 3.0.2
09/25/07 15:17:34 4376 Toolkit toolkit.py:112 INFO Command and arguments: ['C:\\Program Files\\AGTk-3\\bin\\VenueClient3.py']
09/25/07 15:17:34 4376 VenueClient preferences.py:180 DEBUG Preferences.LoadPreferences: open file
09/25/07 15:17:34 4376 Toolkit toolkit.py:161 INFO Logfile Name: VenueClient.log
09/25/07 15:17:34 4376 Toolkit venueclient3.py:125 INFO wx version is: 2.6.2.1
09/25/07 15:17:34 4376 VenueClient venueclient.py:375 DEBUG __StartWebService: venueclient: http://142.51.23.138:11000/VenueClient
09/25/07 15:17:34 4376 VenueClient venueclient.py:386 DEBUG __StartWebService: service manager: http://142.51.23.138:11000/ServiceManager
09/25/07 15:17:34 4376 VenueClient venueclient.py:400 DEBUG __StartWebService: node service: http://142.51.23.138:11000/NodeService
09/25/07 15:17:34 4376 NodeService agnodeservice.py:635 INFO NodeService.GetConfigurations
09/25/07 15:17:34 4376 VenueClient venueclient.py:175 DEBUG Loading node configuration: <AccessGrid.Descriptions.NodeConfigDescription instance at 0x02CFC788>
09/25/07 15:17:34 4376 NodeService agnodeservice.py:375 INFO NodeService.LoadConfiguration
09/25/07 15:17:34 4376 NodeService agnodeservice.py:394 INFO Trying to load node configuration from: C:\Program Files\AGTk-3\Config\nodeConfig\default
09/25/07 15:17:34 4376 NodeService agnodeservice.py:402 DEBUG section: node
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG servicemanagers : servicemanager0
09/25/07 15:17:34 4376 NodeService agnodeservice.py:402 DEBUG section: service1
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG resource : resource1
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG serviceConfig : serviceconfig1
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG packageName : VideoService.zip
09/25/07 15:17:34 4376 NodeService agnodeservice.py:402 DEBUG section: service0
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG packageName : AudioService.zip
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG serviceConfig : serviceconfig0
09/25/07 15:17:34 4376 NodeService agnodeservice.py:402 DEBUG section: resource1
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG name : Logitech QuickCam Chat
09/25/07 15:17:34 4376 NodeService agnodeservice.py:402 DEBUG section: servicemanager0
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG services : service0 service1
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG builtin : 1
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG url :
09/25/07 15:17:34 4376 NodeService agnodeservice.py:402 DEBUG section: serviceconfig1
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Mute Sources : Off
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Frame Rate : 24
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Transmit on Startup : On
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Stream Name : Logitech QuickCam Chat
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Encoding : h261
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Standard : NTSC
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Bandwidth : 800
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Quality : 75
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Port : external-in
09/25/07 15:17:34 4376 NodeService agnodeservice.py:402 DEBUG section: serviceconfig0
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Use site id : On
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Silence Suppression : Off
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Output Gain : 50
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Talk : Off
09/25/07 15:17:34 4376 NodeService agnodeservice.py:404 DEBUG Input Gain : 50
09/25/07 15:17:34 4376 NodeService agnodeservice.py:479 DEBUG using builtin service manager at http://142.51.23.138:11000/ServiceManager
09/25/07 15:17:34 1956 ServiceManager agservicemanager.py:208 INFO AGServiceManager.RemoveServices
09/25/07 15:17:34 5760 ServiceManager agservicemanager.py:102 INFO AGServiceManager.AddService
09/25/07 15:17:34 5760 ServiceManager agservicemanager.py:339 INFO Installed service version: 3.7, package version: 3.4
09/25/07 15:17:34 5760 ServiceManager agservicemanager.py:374 DEBUG Executing service AudioService
09/25/07 15:17:34 5760 ServiceManager agservicemanager.py:406 INFO Running Service; options: ['C:\\Documents and Settings\\kpassi\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', 63525, '--serviceManagerUri', 'http://142.51.23.138:11000/ServiceManager', '--token', '8e33178a0648396908f6c6c4cd630043']
09/25/07 15:17:34 5760 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\AudioService.py" --port 63525 --serviceManagerUri http://142.51.23.138:11000/ServiceManager --token 8e33178a0648396908f6c6c4cd630043
09/25/07 15:17:34 5760 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:1180>, <PyHANDLE:1192>, 2368, 4288)
09/25/07 15:17:35 5760 ServiceManager agservicemanager.py:418 INFO Service registered: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1 8e33178a0648396908f6c6c4cd630043
09/25/07 15:17:35 252 ServiceManager agservicemanager.py:102 INFO AGServiceManager.AddService
09/25/07 15:17:35 252 ServiceManager agservicemanager.py:339 INFO Installed service version: 3.2, package version: 3.2
09/25/07 15:17:35 252 ServiceManager agservicemanager.py:374 DEBUG Executing service VideoService
09/25/07 15:17:35 252 ServiceManager agservicemanager.py:406 INFO Running Service; options: ['C:\\Documents and Settings\\kpassi\\Application Data\\AccessGrid3\\local_services\\VideoService\\VideoService.py', '--port', 61497, '--serviceManagerUri', 'http://142.51.23.138:11000/ServiceManager', '--token', '8e33178a0648396909738462d064ec28']
09/25/07 15:17:35 252 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Python23\pythonw.exe "C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\VideoService\VideoService.py" --port 61497 --serviceManagerUri http://142.51.23.138:11000/ServiceManager --token 8e33178a0648396909738462d064ec28
09/25/07 15:17:35 252 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:1088>, <PyHANDLE:1076>, 2792, 5968)
09/25/07 15:17:37 252 ServiceManager agservicemanager.py:418 INFO Service registered: http://142.51.23.138:61497/Services/VideoService.8e33178a0ae8396909e275db018ebd21 8e33178a0648396909738462d064ec28
09/25/07 15:17:37 4376 VenueClient venueclient.py:242 DEBUG get bridges from registry
09/25/07 15:17:37 4376 VenueClient venueclient.py:256 DEBUG set bridges in prefs
09/25/07 15:17:37 4376 VenueClient venueclient.py:265 DEBUG connect to bridge
09/25/07 15:17:37 4376 VenueClient venueclient.py:269 DEBUG exiting loadbridges
09/25/07 15:17:37 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:17:37 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:17:37 1684 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:17:37 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:17:37 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:17:37 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:17:37 2788 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:17:37 2280 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:17:38 4376 NodeService agnodeservice.py:635 INFO NodeService.GetConfigurations
09/25/07 15:17:48 4376 VenueClientController venueclientcontroller.py:288 DEBUG UseBridgeCB called: bridge=SHARCNET (agbs.sharcnet.ca:20000)
09/25/07 15:17:48 4376 VenueClient venueclient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
09/25/07 15:17:48 4376 VenueClient venueclient.py:1195 DEBUG Setting node service streams
09/25/07 15:17:48 4376 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:17:48 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:17:48 3612 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:17:48 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:17:49 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:17:49 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:17:49 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:17:50 4376 VenueClientController venueclientcontroller.py:435 DEBUG VenueClientController calling Venue.EnterVenue
09/25/07 15:17:50 4376 VenueClient venueclient.py:1015 DEBUG EnterVenue; url=https://agvs.sharcnet.ca:8000/Venues/default
09/25/07 15:17:50 4376 NodeService agnodeservice.py:658 INFO NodeService.GetCapabilities
09/25/07 15:17:50 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:17:50 5380 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:17:51 4376 VenueClient venueclient.py:1049 DEBUG calling __EnterVenue
09/25/07 15:17:51 4376 VenueClient venueclient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
09/25/07 15:17:51 4376 VenueClient venueclient.py:808 DEBUG after Venue.Enter
09/25/07 15:17:51 4376 VenueClient venueclient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
09/25/07 15:17:51 4376 VenueClient venueclient.py:812 DEBUG EnterVenue: done Venue.getstate
09/25/07 15:17:52 4376 VenueClient venueclient.py:835 DEBUG Setting isInVenue flag.
09/25/07 15:17:52 5900 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190747872
09/25/07 15:17:52 4376 VenueClient venueclient.py:1051 DEBUG after __EnterVenue
09/25/07 15:17:52 4376 VenueClient venueclientui.py:2586 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agvs.sharcnet.ca:8000/Venues/default
09/25/07 15:17:52 4376 VenueClient venueclientui.py:2699 DEBUG Entered venue
09/25/07 15:17:52 4376 VenueClientController venueclientcontroller.py:437 DEBUG VenueClientController after Venue.EnterVenue
09/25/07 15:17:52 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kalpdrum Passi (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:17:52 5900 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:17:52 5900 JabberClient jabberclient.py:33 INFO Connecting to Jabber Server 'jabber.mcs.anl.gov' ...
09/25/07 15:17:52 5900 bajjer.io io.py:100 DEBUG RECV: <?xml version='1.0'?><stream:stream xmlns:stream='http://etherx.jabber.org/streams' id='46F95EE3' xmlns='jabber:client' from='jabber.mcs.anl.gov'>
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:65 DEBUG feed parser initialized
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:72 DEBUG start <{http://etherx.jabber.org/streams}stream> level=0
09/25/07 15:17:52 5900 JabberClient jabberclient.py:168 INFO Registering the user '42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' in jabber server ...
09/25/07 15:17:52 5900 bajjer.io io.py:122 DEBUG SEND: <iq type="get"><query xmlns="jabber:iq:register" /></iq>
09/25/07 15:17:52 5900 bajjer.io io.py:161 DEBUG RECV: <iq type='result'><query xmlns='jabber:iq:register'><password/><password/>
<instructions>Choose a username and password to register with this server.</instructions>
<name/>
<email/>
<username/></query></iq>
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}iq> level=1
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}query> level=2
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}password> level=3
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}password> level=3
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}instructions> level=3
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}instructions> level=3
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}name> level=3
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}name> level=3
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}email> level=3
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}email> level=3
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:register}username> level=3
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}username> level=3
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:register}query> level=2
09/25/07 15:17:52 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}iq> level=1
09/25/07 15:17:52 5900 bajjer.io io.py:122 DEBUG SEND: <iq type="set"><query xmlns="jabber:iq:register"><username>42611a03611e3969120684ddd0b4b5df</username><password>42611a03611e3969120684ddd0b4b5df</password></query></iq>
09/25/07 15:17:52 4376 GroupMsgClient groupmsgclient.py:112 INFO Connected. Connection ID: 42611a03611e3969120684ddd0b4b5df
09/25/07 15:17:52 4376 EventClient insecurevenueeventclient.py:60 INFO BaseVenueEventClient made connection.
09/25/07 15:17:52 5900 bajjer.io io.py:161 DEBUG RECV: <iq type='result'/>
09/25/07 15:17:53 5900 JabberClient jabberclient.py:177 INFO Attempting to log in as 42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default ...
09/25/07 15:17:53 5900 bajjer.io io.py:122 DEBUG SEND: <iq type="get"><query xmlns="jabber:iq:auth"><username>42611a03611e3969120684ddd0b4b5df</username></query></iq>
09/25/07 15:17:54 5900 bajjer.io io.py:161 DEBUG RECV: <iq type='result'><query xmlns='jabber:iq:auth'><username>42611a03611e3969120684ddd0b4b5df</username><digest/><password/><resource/></query></iq>
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}iq> level=1
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}query> level=2
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}username> level=3
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}username> level=3
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}digest> level=3
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}digest> level=3
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}password> level=3
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}password> level=3
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:auth}resource> level=3
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}resource> level=3
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:auth}query> level=2
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}iq> level=1
09/25/07 15:17:54 5900 bajjer.stream stream.py:326 DEBUG Recv: <gov.lbl.dsd.bajjer.stanza.Iq object at 0x02DF32F0>
09/25/07 15:17:54 5900 bajjer.stream stream.py:342 DEBUG performing 'digest' authentication
09/25/07 15:17:54 5900 bajjer.io io.py:122 DEBUG SEND: <iq type="set"><query xmlns="jabber:iq:auth"><resource>default</resource><username>42611a03611e3969120684ddd0b4b5df</username><digest>995ea1e3daf13e122f6c413a9bea849875f0ff7c</digest></query></iq>
09/25/07 15:17:54 5900 bajjer.io io.py:161 DEBUG RECV: <iq type='result' id='pthsock_client_auth_ID'/>
09/25/07 15:17:54 5900 bajjer.stream stream.py:351 DEBUG Authorization succeeded
09/25/07 15:17:54 5900 bajjer.io io.py:122 DEBUG SEND: <iq from="42611a03611e3969120684ddd0b4b5df" type="get"><query xmlns="jabber:iq:roster" /></iq>
09/25/07 15:17:54 5900 bajjer.io io.py:161 DEBUG RECV: <iq from='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='result'><query xmlns='jabber:iq:roster'/></iq>
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:72 DEBUG start <{jabber:iq:roster}query> level=2
09/25/07 15:17:54 5900 bajjer.serialize serialize.py:86 DEBUG end <{jabber:iq:roster}query> level=2
09/25/07 15:17:54 5900 bajjer.io io.py:122 DEBUG SEND: <presence />
09/25/07 15:17:54 5900 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'available'...
09/25/07 15:17:54 5900 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="available"><x /></presence>
09/25/07 15:17:54 5900 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address 224.2.187.82/59698
09/25/07 15:17:54 5900 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:17:54 5900 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:17:54 5900 VenueClient venueclient.py:1264 ERROR VenueClient.UpdateStream: Failed to connect to bridge SHARCNET
return u.close()
09/25/07 15:17:54 5900 VenueClient venueclient.py:902 DEBUG UpdateNodeService: Couldn't update stream with transport/provider info
09/25/07 15:17:54 5900 VenueClient venueclient.py:914 DEBUG Updating client profile cache.
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message from='jabber.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov'>
<subject>Welcome!</subject>
<body>Welcome to the Access Grid Jabber server @ jabber.mcs.anl.gov -- we hope you enjoy this service! For information about how to use Jabber, visit the Jabber User's Guide at http://jabbermanual.jabberstudio.org/</body>
<x xmlns='jabber:x:delay' from='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov' stamp='20070925T19:17:55'>Offline Storage</x></message>
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}subject> level=2
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}subject> level=2
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:17:54 5428 JabberClient jabberclient.py:133 DEBUG jabber.mcs.anl.go: Welcome to the Access Grid Jabber server @ jabber.mcs.anl.gov -- we hope you enjoy this service! For information about how to use Jabber, visit the Jabber User's Guide at http://jabbermanual.jabberstudio.org/
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:17:54 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:17:54 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is available (None / None)
09/25/07 15:17:54 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kalpdrum Passi
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>sharcnet-venue-server-lobby(agvs.sharcnet.ca)</body></message>
09/25/07 15:17:54 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: sharcnet-venue-server-lobby(agvs.sharcnet.ca)
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><x/><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya' stamp='20070925T17:57:59'/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:17:54 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
09/25/07 15:17:54 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya is available (None / None)
09/25/07 15:17:54 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kaizaad Bilimorya (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:17:54 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kaizaad Bilimorya
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>no rat?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:44'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>no</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:49'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I can't do much, have an hour-glass in my VenueClient config</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>killall -9 python</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:37'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>dave in the room?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:54'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>how did you know?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:51:02'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>Say something</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:52:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>hello?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:56:30'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:54 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>We can hear you</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:10'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:55 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>can you hear us?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:55 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:17:55 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:17:55 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:17:55 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:17:55 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:17:55 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:17:55 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I don't have a mic</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:58:41'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:55 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I am coming down</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:23'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:55 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>They are all encrypted except the nonEncrypted</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:51'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:55 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>did you go away. I can't see you in the lobby</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:12:59'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:55 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>can you hear me</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:14:19'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:55 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>ttps://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:49:20'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:55 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>https://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:02:56'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:55 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>:\Documents and Settings\Your_Windows_Login\Application Data\AccessGrid3\</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:06:16'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:55 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i cannot see the video or the audio</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:16:42'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:17:55 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>Kalpdrum Passi has joined this session</body></message>
09/25/07 15:17:56 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: Kalpdrum Passi has joined this session
09/25/07 15:18:17 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:18:17 5616 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:18:18 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:18:18 5724 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:18:18 4376 VenueClient venueclient.py:1651 ERROR Error enabling video
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\VenueClient.py", line 1642, in SetVideoEnabled
AGServiceIW(service.uri).SetEnabled(enableFlag)
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\interfaces\AGService_client.py", line 183, in SetEnabled
response = self.binding.Receive(SetEnabledResponse.typecode)
File "C:\Python23\lib\site-packages\ZSI\client.py", line 418, in Receive
raise FaultException(msg)
FaultException: Processing Failure
exceptions:Exception
Failed to start service
[trace: C:\Python23\lib\site-packages\ZSI\ServiceContainer.py:107:_Dispatch
C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\interfaces\AGService_interface.py:1212:soap_SetEnabled
C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\AGService.py:224:SetEnabled
C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\VideoService\VideoService.py:350:Start]
09/25/07 15:18:25 4376 VenueClient venueclient.py:548 DEBUG AddUserEvent: Got Add User Event
09/25/07 15:18:25 4376 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:18:25 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant UoGuelph-SHARCNET (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:18:26 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:18:26 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET is available (None / None)
09/25/07 15:18:26 5428 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:18:26 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>UoGuelph-SHARCNET has joined this session</body></message>
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:18:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:18:26 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: UoGuelph-SHARCNET has joined this session
09/25/07 15:18:28 5812 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190747908
09/25/07 15:18:28 5812 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:18:58 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>check that you are using the sharcnet bridge</body></message>
09/25/07 15:18:58 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:18:58 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:18:58 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:18:58 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:19:04 4860 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190747944
09/25/07 15:19:05 4860 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:19:40 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:19:40 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:19:40 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>i am, but now the window screens for audo and video are not coming up</body></message>
09/25/07 15:19:40 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i am, but now the window screens for audo and video are not coming up</body></message>
09/25/07 15:19:40 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:19:40 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:19:40 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:19:40 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:19:41 804 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190747981
09/25/07 15:19:41 804 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:20:12 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>click the enable/disable button to turn them on/offf</body></message>
09/25/07 15:20:12 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:20:12 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:20:12 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:20:12 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:20:17 6108 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748017
09/25/07 15:20:17 6108 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:20:19 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:20:19 2084 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:20:20 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:20:20 2424 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:20:20 4376 VenueClient venueclient.py:1651 ERROR Error enabling video
09/25/07 15:20:21 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:20:21 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:20:21 1336 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:20:22 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:20:22 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:20:22 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:20:22 1456 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:20:22 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:20:22 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:20:22 4376 NodeService agnodeservice.py:282 ERROR http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\AGNodeService.py", line 279, in SetServiceEnabled
AGServiceIW( serviceUri ).SetEnabled(enabled)
C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\AudioService.py:285:Start]
09/25/07 15:20:22 4376 VenueClient venueclient.py:1657 ERROR VenueClient.SetAudioEnabled: Error enabling audio
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\VenueClient.py", line 1655, in SetAudioEnabled
self.nodeService.SetServiceEnabledByMediaType("audio",enableFlag)
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\AGNodeService.py", line 295, in SetServiceEnabledByMediaType
self.SetServiceEnabled( service.uri, enableFlag)
09/25/07 15:20:26 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:20:26 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:20:26 1844 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:20:26 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:20:36 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:20:36 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:20:36 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>i tried</body></message>
09/25/07 15:20:36 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i tried</body></message>
09/25/07 15:20:36 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:20:36 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:20:36 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:20:36 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:20:53 6080 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748053
09/25/07 15:20:54 6080 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:21:16 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:21:16 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:21:16 5156 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:21:17 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:21:17 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:21:17 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:21:17 4376 NodeService agnodeservice.py:282 ERROR http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:21:17 4376 VenueClient venueclient.py:1657 ERROR VenueClient.SetAudioEnabled: Error enabling audio
09/25/07 15:21:25 4376 VenueClient venueclientui.py:1300 DEBUG VenueClientFrame.ManageNodeCB: open node management
09/25/07 15:21:25 4376 VenueClient venueclientui.py:1301 DEBUG nodeservice url: <AccessGrid.AGNodeService.AGNodeService instance at 0x02CFC5A8>
09/25/07 15:21:25 4376 NodeService agnodeservice.py:248 INFO NodeService.GetServiceManagers
09/25/07 15:21:25 5388 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:21:30 5484 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748090
09/25/07 15:21:30 5484 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:21:39 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:21:39 6064 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:21:40 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:21:40 4220 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:21:40 4376 VenueClient venueclient.py:1631 INFO Error enabling video
09/25/07 15:21:44 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:21:44 5536 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:21:44 4680 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:21:45 4376 VenueClient venueclient.py:1651 ERROR Error enabling video
09/25/07 15:21:57 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Goto Venue -> Properties -> and read me back the address listed</body></message>
09/25/07 15:21:57 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:21:57 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:21:57 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:21:57 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:22:06 4428 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748126
09/25/07 15:22:06 4428 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:22:42 2992 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748162
09/25/07 15:22:42 2992 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:23:18 3088 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748198
09/25/07 15:23:19 3088 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:23:22 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:23:22 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:23:22 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>224.2.124.15 video(multicast)</body></message>
09/25/07 15:23:22 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>224.2.124.15 video(multicast)</body></message>
09/25/07 15:23:22 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:23:22 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:23:22 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:23:22 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:23:48 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>okay, something must have happened to the bridge</body></message>
09/25/07 15:23:48 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:23:48 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:23:48 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:23:48 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:23:55 2236 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748235
09/25/07 15:23:55 2236 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:24:07 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:24:07 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:24:07 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>what should i do</body></message>
09/25/07 15:24:07 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>what should i do</body></message>
09/25/07 15:24:07 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:24:07 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:24:07 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:24:07 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:24:20 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>sec</body></message>
09/25/07 15:24:20 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:24:20 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:24:20 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:24:20 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:24:31 5476 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748271
09/25/07 15:24:31 5476 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:25:07 5640 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748307
09/25/07 15:25:08 5640 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:25:09 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Goto Tools -> Bridges -> SHARCNET</body></message>
09/25/07 15:25:09 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:25:09 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:25:09 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:25:09 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:25:30 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:25:30 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:25:30 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>i have selected SHARCNET under the bridges</body></message>
09/25/07 15:25:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i have selected SHARCNET under the bridges</body></message>
09/25/07 15:25:30 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:25:30 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:25:30 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:25:30 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:25:44 5548 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748344
09/25/07 15:25:44 5548 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:26:20 3092 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748380
09/25/07 15:26:20 3092 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:26:23 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Even if it is selected, try selecting it again</body></message>
09/25/07 15:26:23 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:26:23 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:26:23 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:26:23 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:26:29 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:26:29 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:26:29 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>i did</body></message>
09/25/07 15:26:29 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i did</body></message>
09/25/07 15:26:29 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:26:29 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:26:29 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:26:29 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:26:44 4376 VenueClient venueclient.py:1132 INFO ExitVenue
09/25/07 15:26:44 4376 VenueClient venueclient.py:1173 INFO ExitVenue: Stopping node services
09/25/07 15:26:44 4376 NodeService agnodeservice.py:301 INFO NodeService.StopServices
09/25/07 15:26:44 5760 ServiceManager agservicemanager.py:225 INFO AGServiceManager.StopServices
09/25/07 15:26:44 4376 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:26:44 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:26:44 3420 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:26:44 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:26:44 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:26:44 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:26:44 4376 VenueClient venueclient.py:1103 DEBUG ExitVenue: Stop event client obj
09/25/07 15:26:44 4376 VenueClient venueclient.py:1105 DEBUG ExitVenue: Remove event client reference
09/25/07 15:26:44 4376 VenueClient venueclient.py:1110 INFO ExitVenue: Stopping text client
09/25/07 15:26:44 4376 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'unavailable'...
09/25/07 15:26:44 4376 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="unavailable"><x /></presence>
09/25/07 15:26:44 4376 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:26:44 4376 VenueClientController venueclientcontroller.py:435 DEBUG VenueClientController calling Venue.EnterVenue
09/25/07 15:26:44 4376 VenueClient venueclient.py:1015 DEBUG EnterVenue; url=https://agvs.sharcnet.ca:8000/Venues/default
09/25/07 15:26:44 4376 NodeService agnodeservice.py:658 INFO NodeService.GetCapabilities
09/25/07 15:26:44 852 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:26:44 4376 VenueClient venueclient.py:1049 DEBUG calling __EnterVenue
09/25/07 15:26:44 4376 VenueClient venueclient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
09/25/07 15:26:44 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='unavailable' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='none'/></x></presence>
09/25/07 15:26:44 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:26:44 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:26:44 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:26:44 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:26:44 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:26:44 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:26:44 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:26:44 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:26:44 5428 JabberClient jabberclient.py:148 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is unavailable (None / None)
09/25/07 15:26:44 5428 VenueClient venueclientui.py:2322 DEBUG remove user: Kalpdrum Passi
09/25/07 15:26:44 4376 VenueClient venueclient.py:808 DEBUG after Venue.Enter
09/25/07 15:26:44 4376 VenueClient venueclient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
09/25/07 15:26:44 4376 VenueClient venueclient.py:812 DEBUG EnterVenue: done Venue.getstate
09/25/07 15:26:45 1912 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:26:45 4376 VenueClient venueclient.py:835 DEBUG Setting isInVenue flag.
09/25/07 15:26:45 3980 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748405
09/25/07 15:26:45 4376 VenueClient venueclient.py:1051 DEBUG after __EnterVenue
09/25/07 15:26:45 4376 VenueClient venueclientui.py:2586 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agvs.sharcnet.ca:8000/Venues/default
09/25/07 15:26:45 4376 VenueClient venueclientui.py:2699 DEBUG Entered venue
09/25/07 15:26:45 4376 VenueClientController venueclientcontroller.py:437 DEBUG VenueClientController after Venue.EnterVenue
09/25/07 15:26:45 4376 VenueClient venueclientui.py:3349 DEBUG ContentListPanel.RemoveParticipant: Remove participant
09/25/07 15:26:45 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kalpdrum Passi (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:26:45 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant UoGuelph-SHARCNET (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:26:45 3980 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:26:45 3980 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'available'...
09/25/07 15:26:45 3980 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="available"><x /></presence>
09/25/07 15:26:45 3980 VenueClient venueclient.py:951 INFO Beacon being reconfigured, stopping running beacon
09/25/07 15:26:45 3980 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:26:45 3980 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address 224.2.187.82/59698
09/25/07 15:26:45 3980 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:26:45 3980 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:26:45 3980 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50080
09/25/07 15:26:45 3980 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50122
09/25/07 15:26:45 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:26:45 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:26:45 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:26:45 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:26:45 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:26:45 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:26:45 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:26:45 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:26:45 3980 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50158
09/25/07 15:26:45 3980 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address agbs.sharcnet.ca/50122
09/25/07 15:26:45 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:26:45 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is available (None / None)
09/25/07 15:26:45 3980 VenueClient venueclient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
09/25/07 15:26:45 3980 VenueClient venueclient.py:1195 DEBUG Setting node service streams
09/25/07 15:26:45 3980 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:26:45 3980 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:26:45 1620 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:26:45 3980 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:26:45 4376 EventClient insecurevenueeventclient.py:77 INFO BaseVenueEventClient lost connection.
09/25/07 15:26:45 3980 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:26:45 3980 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:26:46 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kalpdrum Passi
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>sharcnet-venue-server-lobby(agvs.sharcnet.ca)</body></message>
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:26:46 3980 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:26:46 4376 GroupMsgClient groupmsgclient.py:112 INFO Connected. Connection ID: 42611a03611e3969e256a4c470cea3f6
09/25/07 15:26:46 4376 EventClient insecurevenueeventclient.py:60 INFO BaseVenueEventClient made connection.
09/25/07 15:26:46 3980 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:26:46 3980 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, video, 42611a040f043962becd9b9c9e410277, H261, 90000, 1, producer, video, 42611a040f043962becd9b9c9e410277, H261, 90000, 1]) to service: http://142.51.23.138:61497/Services/VideoService.8e33178a0ae8396909e275db018ebd21
09/25/07 15:26:46 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: sharcnet-venue-server-lobby(agvs.sharcnet.ca)
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><x/><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET' stamp='20070925T19:18:28'/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:26:46 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:26:46 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
09/25/07 15:26:46 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET is available (None / None)
09/25/07 15:26:46 5428 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><x/><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya' stamp='20070925T17:57:59'/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:26:46 3980 VenueClient venueclient.py:914 DEBUG Updating client profile cache.
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>no rat?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:44'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:46 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya is available (None / None)
09/25/07 15:26:46 4480 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:26:46 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kaizaad Bilimorya (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:26:46 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kaizaad Bilimorya
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>no</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:49'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I can't do much, have an hour-glass in my VenueClient config</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>killall -9 python</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:37'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>dave in the room?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:54'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>how did you know?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:51:02'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>Say something</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:52:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>hello?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:56:30'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>We can hear you</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:10'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:46 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>can you hear us?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:26:47 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:26:47 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I don't have a mic</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:58:41'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:26:47 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:26:47 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I am coming down</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:23'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>They are all encrypted except the nonEncrypted</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:51'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>did you go away. I can't see you in the lobby</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:12:59'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>can you hear me</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:14:19'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>ttps://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:49:20'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>https://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:02:56'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>:\Documents and Settings\Your_Windows_Login\Application Data\AccessGrid3\</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:06:16'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i cannot see the video or the audio</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:16:42'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>check that you are using the sharcnet bridge</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:19:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i am, but now the window screens for audo and video are not coming up</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:19:43'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:47 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>click the enable/disable button to turn them on/offf</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:20:15'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:48 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i tried</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:20:39'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:48 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:26:48 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:26:48 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:26:48 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:26:48 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:26:48 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:26:48 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Goto Venue -> Properties -> and read me back the address listed</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:22:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:48 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>224.2.124.15 video(multicast)</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:23:24'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:48 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>okay, something must have happened to the bridge</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:23:50'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:48 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>what should i do</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:24:10'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:48 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>sec</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:24:23'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:48 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Goto Tools -> Bridges -> SHARCNET</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:25:12'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:48 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i have selected SHARCNET under the bridges</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:25:33'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:48 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Even if it is selected, try selecting it again</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:26:26'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:48 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i did</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:26:32'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:26:49 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>Kalpdrum Passi has joined this session</body></message>
09/25/07 15:26:49 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:26:49 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:26:49 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:26:49 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:26:51 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: Kalpdrum Passi has joined this session
09/25/07 15:27:21 2264 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748441
09/25/07 15:27:24 2264 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:28:00 260 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748480
09/25/07 15:28:01 260 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:28:04 4376 VenueClient venueclient.py:1132 INFO ExitVenue
09/25/07 15:28:04 4376 VenueClient venueclient.py:1173 INFO ExitVenue: Stopping node services
09/25/07 15:28:04 4376 NodeService agnodeservice.py:301 INFO NodeService.StopServices
09/25/07 15:28:05 4704 ServiceManager agservicemanager.py:225 INFO AGServiceManager.StopServices
09/25/07 15:28:06 4376 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:28:06 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:28:06 5168 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:28:06 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:28:06 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:28:06 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:28:06 4376 VenueClient venueclient.py:1103 DEBUG ExitVenue: Stop event client obj
09/25/07 15:28:06 4376 VenueClient venueclient.py:1105 DEBUG ExitVenue: Remove event client reference
09/25/07 15:28:06 4376 VenueClient venueclient.py:1110 INFO ExitVenue: Stopping text client
09/25/07 15:28:06 4376 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'unavailable'...
09/25/07 15:28:06 4376 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="unavailable"><x /></presence>
09/25/07 15:28:06 4376 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:28:06 4376 VenueClientController venueclientcontroller.py:435 DEBUG VenueClientController calling Venue.EnterVenue
09/25/07 15:28:06 4376 VenueClient venueclient.py:1015 DEBUG EnterVenue; url=https://agvs.sharcnet.ca:8000/Venues/42611c8c20f11b5ccbcfc6b3dc40f3032e
09/25/07 15:28:06 4376 NodeService agnodeservice.py:658 INFO NodeService.GetCapabilities
09/25/07 15:28:06 5272 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:28:06 4376 VenueClient venueclient.py:1049 DEBUG calling __EnterVenue
09/25/07 15:28:06 4376 VenueClient venueclient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
09/25/07 15:28:06 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='unavailable' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='none'/></x></presence>
09/25/07 15:28:06 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:28:06 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:28:06 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:28:06 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:28:06 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:28:06 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:28:06 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:28:06 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:28:06 5428 JabberClient jabberclient.py:148 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is unavailable (None / None)
09/25/07 15:28:06 5428 VenueClient venueclientui.py:2322 DEBUG remove user: Kalpdrum Passi
09/25/07 15:28:06 4376 VenueClient venueclient.py:808 DEBUG after Venue.Enter
09/25/07 15:28:06 4376 VenueClient venueclient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
09/25/07 15:28:06 3612 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:28:07 4376 VenueClient venueclient.py:812 DEBUG EnterVenue: done Venue.getstate
09/25/07 15:28:07 4376 VenueClient venueclient.py:835 DEBUG Setting isInVenue flag.
09/25/07 15:28:07 5584 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748487
09/25/07 15:28:07 4376 VenueClient venueclient.py:1051 DEBUG after __EnterVenue
09/25/07 15:28:07 4376 VenueClient venueclientui.py:2586 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agvs.sharcnet.ca:8000/Venues/42611c8c20f11b5ccbcfc6b3dc40f3032e
09/25/07 15:28:07 4376 VenueClient venueclientui.py:2699 DEBUG Entered venue
09/25/07 15:28:07 4376 VenueClientController venueclientcontroller.py:437 DEBUG VenueClientController after Venue.EnterVenue
09/25/07 15:28:07 4376 VenueClient venueclientui.py:3349 DEBUG ContentListPanel.RemoveParticipant: Remove participant
09/25/07 15:28:07 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kalpdrum Passi (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:28:07 5584 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:28:07 5584 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'available'...
09/25/07 15:28:07 5584 bajjer.io io.py:122 DEBUG SEND: <presence to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="available"><x /></presence>
09/25/07 15:28:07 5584 VenueClient venueclient.py:951 INFO Beacon being reconfigured, stopping running beacon
09/25/07 15:28:07 5584 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:28:07 5584 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address 224.2.156.42/49654
09/25/07 15:28:07 5584 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:28:07 5584 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:28:07 5584 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50152
09/25/07 15:28:07 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item jid='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' affiliation='owner' role='moderator'/></x></presence>
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:28:07 5428 JabberClient jabberclient.py:145 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is available (None / None)
09/25/07 15:28:07 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kalpdrum Passi
09/25/07 15:28:07 5584 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50112
09/25/07 15:28:07 5584 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50066
09/25/07 15:28:07 5584 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address agbs.sharcnet.ca/50112
09/25/07 15:28:07 5584 VenueClient venueclient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
09/25/07 15:28:07 5584 VenueClient venueclient.py:1195 DEBUG Setting node service streams
09/25/07 15:28:07 5584 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:28:07 5584 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:28:07 124 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:28:07 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>siteleaders(agvs.sharcnet.ca)</body></message>
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:28:07 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:28:07 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: siteleaders(agvs.sharcnet.ca)
09/25/07 15:28:07 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
09/25/07 15:28:08 5584 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:28:08 4376 EventClient insecurevenueeventclient.py:77 INFO BaseVenueEventClient lost connection.
09/25/07 15:28:08 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:28:08 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>Kalpdrum Passi has joined this session</body></message>
09/25/07 15:28:08 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:28:08 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:28:08 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:28:08 5584 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:28:08 5584 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:28:08 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
09/25/07 15:28:08 4376 GroupMsgClient groupmsgclient.py:112 INFO Connected. Connection ID: 42611a03611e396a026d5bc6c4359825
09/25/07 15:28:08 4376 EventClient insecurevenueeventclient.py:60 INFO BaseVenueEventClient made connection.
09/25/07 15:28:08 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: Kalpdrum Passi has joined this session
09/25/07 15:28:08 5584 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:28:08 5584 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, video, 8e33178a01c0396193a106993fbe7dcd, H261, 90000, 1, producer, video, 8e33178a01c0396193a106993fbe7dcd, H261, 90000, 1]) to service: http://142.51.23.138:61497/Services/VideoService.8e33178a0ae8396909e275db018ebd21
09/25/07 15:28:08 1940 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:28:08 5584 VenueClient venueclient.py:914 DEBUG Updating client profile cache.
09/25/07 15:28:43 2148 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748523
09/25/07 15:28:44 2148 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:29:20 6076 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748560
09/25/07 15:29:20 6076 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:29:24 4376 VenueClient venueclient.py:1132 INFO ExitVenue
09/25/07 15:29:24 4376 VenueClient venueclient.py:1173 INFO ExitVenue: Stopping node services
09/25/07 15:29:24 4376 NodeService agnodeservice.py:301 INFO NodeService.StopServices
09/25/07 15:29:24 4656 ServiceManager agservicemanager.py:225 INFO AGServiceManager.StopServices
09/25/07 15:29:25 4376 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:29:25 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:29:25 5620 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:29:25 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:29:25 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:29:25 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:29:25 4376 VenueClient venueclient.py:1103 DEBUG ExitVenue: Stop event client obj
09/25/07 15:29:25 4376 VenueClient venueclient.py:1105 DEBUG ExitVenue: Remove event client reference
09/25/07 15:29:25 4376 VenueClient venueclient.py:1110 INFO ExitVenue: Stopping text client
09/25/07 15:29:25 4376 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'unavailable'...
09/25/07 15:29:25 4376 bajjer.io io.py:122 DEBUG SEND: <presence to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="unavailable"><x /></presence>
09/25/07 15:29:25 4376 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:29:25 4376 VenueClientController venueclientcontroller.py:435 DEBUG VenueClientController calling Venue.EnterVenue
09/25/07 15:29:25 4376 VenueClient venueclient.py:1015 DEBUG EnterVenue; url=https://agvs.sharcnet.ca:8000/Venues/42611c8c1fd71b5cc961de7d32e40d5f6b
09/25/07 15:29:25 4376 NodeService agnodeservice.py:658 INFO NodeService.GetCapabilities
09/25/07 15:29:25 252 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:29:25 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='unavailable' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item jid='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' affiliation='owner' role='none'/></x></presence>
09/25/07 15:29:25 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:29:25 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:29:25 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:29:25 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:29:25 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:29:25 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:29:25 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:29:25 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:29:25 5428 JabberClient jabberclient.py:148 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is unavailable (None / None)
09/25/07 15:29:25 4376 VenueClient venueclient.py:1049 DEBUG calling __EnterVenue
09/25/07 15:29:25 4376 VenueClient venueclient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
09/25/07 15:29:25 5428 VenueClient venueclientui.py:2322 DEBUG remove user: Kalpdrum Passi
09/25/07 15:29:26 4376 VenueClient venueclient.py:808 DEBUG after Venue.Enter
09/25/07 15:29:26 4376 VenueClient venueclient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
09/25/07 15:29:26 4376 VenueClient venueclient.py:812 DEBUG EnterVenue: done Venue.getstate
09/25/07 15:29:26 4764 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:29:26 4376 VenueClient venueclient.py:835 DEBUG Setting isInVenue flag.
09/25/07 15:29:26 4440 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748566
09/25/07 15:29:26 4376 VenueClient venueclient.py:1051 DEBUG after __EnterVenue
09/25/07 15:29:26 4376 VenueClient venueclientui.py:2586 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agvs.sharcnet.ca:8000/Venues/42611c8c1fd71b5cc961de7d32e40d5f6b
09/25/07 15:29:26 4376 VenueClient venueclientui.py:2699 DEBUG Entered venue
09/25/07 15:29:26 4376 VenueClientController venueclientcontroller.py:437 DEBUG VenueClientController after Venue.EnterVenue
09/25/07 15:29:26 4376 VenueClient venueclientui.py:3349 DEBUG ContentListPanel.RemoveParticipant: Remove participant
09/25/07 15:29:27 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant UoGuelph-SHARCNET (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:29:27 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kalpdrum Passi (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:29:27 4440 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:29:27 4440 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'available'...
09/25/07 15:29:27 4440 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="available"><x /></presence>
09/25/07 15:29:27 4440 VenueClient venueclient.py:951 INFO Beacon being reconfigured, stopping running beacon
09/25/07 15:29:27 4440 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:29:27 4440 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address 224.2.187.82/59698
09/25/07 15:29:27 4440 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:29:27 4440 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:29:27 4440 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50080
09/25/07 15:29:27 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:29:27 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:29:27 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:29:27 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:29:27 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:29:27 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:29:27 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:29:27 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:29:27 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:29:27 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is available (None / None)
09/25/07 15:29:27 4440 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50122
09/25/07 15:29:27 4440 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50158
09/25/07 15:29:27 4440 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address agbs.sharcnet.ca/50122
09/25/07 15:29:27 4440 VenueClient venueclient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
09/25/07 15:29:27 4440 VenueClient venueclient.py:1195 DEBUG Setting node service streams
09/25/07 15:29:27 4440 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:29:27 4440 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:29:27 4204 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:29:27 804 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:29:28 4440 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:29:28 4440 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:29:28 4440 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:29:28 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kalpdrum Passi
09/25/07 15:29:28 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>sharcnet-venue-server-lobby(agvs.sharcnet.ca)</body></message>
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:29:28 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: sharcnet-venue-server-lobby(agvs.sharcnet.ca)
09/25/07 15:29:28 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
09/25/07 15:29:28 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><x/><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET' stamp='20070925T19:18:28'/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:29:28 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:29:28 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
09/25/07 15:29:28 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET is available (None / None)
09/25/07 15:29:30 5428 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><x/><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya' stamp='20070925T17:57:59'/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:29:30 4376 EventClient insecurevenueeventclient.py:77 INFO BaseVenueEventClient lost connection.
09/25/07 15:29:30 4440 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>no rat?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:44'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:29:30 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:29:30 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya is available (None / None)
09/25/07 15:29:30 4376 GroupMsgClient groupmsgclient.py:112 INFO Connected. Connection ID: 42611a03611e396a2171909843ab28a3
09/25/07 15:29:30 4376 EventClient insecurevenueeventclient.py:60 INFO BaseVenueEventClient made connection.
09/25/07 15:29:30 4440 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:29:30 4440 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, video, 42611a040f043962becd9b9c9e410277, H261, 90000, 1, producer, video, 42611a040f043962becd9b9c9e410277, H261, 90000, 1]) to service: http://142.51.23.138:61497/Services/VideoService.8e33178a0ae8396909e275db018ebd21
09/25/07 15:29:30 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kaizaad Bilimorya (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:29:30 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kaizaad Bilimorya
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>no</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:49'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:30 4440 VenueClient venueclient.py:914 DEBUG Updating client profile cache.
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I can't do much, have an hour-glass in my VenueClient config</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>killall -9 python</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:37'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>dave in the room?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:54'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>how did you know?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:51:02'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>Say something</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:52:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>hello?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:56:30'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>We can hear you</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:10'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>can you hear us?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I don't have a mic</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:58:41'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:30 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I am coming down</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:23'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>They are all encrypted except the nonEncrypted</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:51'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:29:31 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:29:31 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:29:31 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:29:31 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:29:31 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>did you go away. I can't see you in the lobby</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:12:59'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>can you hear me</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:14:19'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>ttps://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:49:20'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>https://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:02:56'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>:\Documents and Settings\Your_Windows_Login\Application Data\AccessGrid3\</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:06:16'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i cannot see the video or the audio</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:16:42'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>check that you are using the sharcnet bridge</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:19:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i am, but now the window screens for audo and video are not coming up</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:19:43'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>click the enable/disable button to turn them on/offf</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:20:15'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i tried</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:20:39'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Goto Venue -> Properties -> and read me back the address listed</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:22:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>224.2.124.15 video(multicast)</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:23:24'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:31 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>okay, something must have happened to the bridge</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:23:50'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:32 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>what should i do</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:24:10'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:32 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:29:32 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:29:32 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:29:32 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:29:32 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:29:32 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:29:32 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>sec</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:24:23'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:32 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Goto Tools -> Bridges -> SHARCNET</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:25:12'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:32 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i have selected SHARCNET under the bridges</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:25:33'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:32 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Even if it is selected, try selecting it again</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:26:26'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:33 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:29:33 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:29:33 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:29:33 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:29:33 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:29:33 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:29:33 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i did</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:26:32'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:29:33 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>Kalpdrum Passi has joined this session</body></message>
09/25/07 15:29:36 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: Kalpdrum Passi has joined this session
09/25/07 15:30:03 5244 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748603
09/25/07 15:30:03 5244 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:30:22 4376 VenueClient venueclient.py:1132 INFO ExitVenue
09/25/07 15:30:22 4376 VenueClient venueclient.py:1173 INFO ExitVenue: Stopping node services
09/25/07 15:30:22 4376 NodeService agnodeservice.py:301 INFO NodeService.StopServices
09/25/07 15:30:22 252 ServiceManager agservicemanager.py:225 INFO AGServiceManager.StopServices
09/25/07 15:30:23 4376 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:30:23 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:30:23 5144 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:30:23 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:30:23 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:30:23 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:30:23 4376 VenueClient venueclient.py:1103 DEBUG ExitVenue: Stop event client obj
09/25/07 15:30:23 4376 VenueClient venueclient.py:1105 DEBUG ExitVenue: Remove event client reference
09/25/07 15:30:23 4376 VenueClient venueclient.py:1110 INFO ExitVenue: Stopping text client
09/25/07 15:30:23 4376 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'unavailable'...
09/25/07 15:30:23 4376 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="unavailable"><x /></presence>
09/25/07 15:30:23 4376 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:30:23 4376 VenueClientController venueclientcontroller.py:435 DEBUG VenueClientController calling Venue.EnterVenue
09/25/07 15:30:23 4376 VenueClient venueclient.py:1015 DEBUG EnterVenue; url=https://agvs.sharcnet.ca:8000/Venues/42611c8c20f11b5ccbcfc6b3dc40f3032e
09/25/07 15:30:23 4376 NodeService agnodeservice.py:658 INFO NodeService.GetCapabilities
09/25/07 15:30:23 4804 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:30:23 4376 VenueClient venueclient.py:1049 DEBUG calling __EnterVenue
09/25/07 15:30:23 4376 VenueClient venueclient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
09/25/07 15:30:23 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='unavailable' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='none'/></x></presence>
09/25/07 15:30:23 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:30:23 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:30:23 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:30:23 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:30:23 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:30:23 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:30:23 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:30:23 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:30:23 5428 JabberClient jabberclient.py:148 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is unavailable (None / None)
09/25/07 15:30:23 5428 VenueClient venueclientui.py:2322 DEBUG remove user: Kalpdrum Passi
09/25/07 15:30:23 5996 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:30:23 4376 VenueClient venueclient.py:808 DEBUG after Venue.Enter
09/25/07 15:30:23 4376 VenueClient venueclient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
09/25/07 15:30:24 4376 VenueClient venueclient.py:812 DEBUG EnterVenue: done Venue.getstate
09/25/07 15:30:24 4376 VenueClient venueclient.py:835 DEBUG Setting isInVenue flag.
09/25/07 15:30:24 6052 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748624
09/25/07 15:30:24 4376 VenueClient venueclient.py:1051 DEBUG after __EnterVenue
09/25/07 15:30:24 4376 VenueClient venueclientui.py:2586 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agvs.sharcnet.ca:8000/Venues/42611c8c20f11b5ccbcfc6b3dc40f3032e
09/25/07 15:30:24 4376 VenueClient venueclientui.py:2699 DEBUG Entered venue
09/25/07 15:30:24 4376 VenueClientController venueclientcontroller.py:437 DEBUG VenueClientController after Venue.EnterVenue
09/25/07 15:30:24 4376 VenueClient venueclientui.py:3349 DEBUG ContentListPanel.RemoveParticipant: Remove participant
09/25/07 15:30:24 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kalpdrum Passi (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:30:24 6052 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:30:24 6052 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'available'...
09/25/07 15:30:24 6052 bajjer.io io.py:122 DEBUG SEND: <presence to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="available"><x /></presence>
09/25/07 15:30:24 6052 VenueClient venueclient.py:951 INFO Beacon being reconfigured, stopping running beacon
09/25/07 15:30:24 6052 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:30:24 6052 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address 224.2.247.120/60920
09/25/07 15:30:24 6052 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:30:24 6052 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:30:25 4376 EventClient insecurevenueeventclient.py:77 INFO BaseVenueEventClient lost connection.
09/25/07 15:30:25 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item jid='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' affiliation='owner' role='moderator'/></x></presence>
09/25/07 15:30:25 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:30:25 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:30:25 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:30:25 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:30:25 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:30:25 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:30:25 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:30:25 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:30:25 5428 JabberClient jabberclient.py:145 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is available (None / None)
09/25/07 15:30:25 4376 GroupMsgClient groupmsgclient.py:112 INFO Connected. Connection ID: 42611a03611e396a380adf659bc0e037
09/25/07 15:30:25 4376 EventClient insecurevenueeventclient.py:60 INFO BaseVenueEventClient made connection.
09/25/07 15:30:26 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kalpdrum Passi
09/25/07 15:30:26 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>siteleaders(agvs.sharcnet.ca)</body></message>
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:30:26 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: siteleaders(agvs.sharcnet.ca)
09/25/07 15:30:26 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
09/25/07 15:30:26 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>Kalpdrum Passi has joined this session</body></message>
09/25/07 15:30:26 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
09/25/07 15:30:26 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item jid='42611a0360cd3962e6d25df40bbf910d at jabber.mcs.anl.gov/default' affiliation='none' role='participant'/></x></presence>
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:30:26 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:30:26 5428 JabberClient jabberclient.py:145 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET is available (None / None)
09/25/07 15:30:26 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant UoGuelph-SHARCNET (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:30:26 5428 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:30:26 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>UoGuelph-SHARCNET has joined this session</body></message>
09/25/07 15:30:26 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: Kalpdrum Passi has joined this session
09/25/07 15:30:26 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: UoGuelph-SHARCNET has joined this session
09/25/07 15:30:27 6052 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50152
09/25/07 15:30:27 6052 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:30:27 6052 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50052
09/25/07 15:30:27 6052 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50100
09/25/07 15:30:27 6052 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:30:27 6052 VenueClient venueclient.py:951 INFO Beacon being reconfigured, stopping running beacon
09/25/07 15:30:27 6052 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address agbs.sharcnet.ca/50052
09/25/07 15:30:27 6052 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:30:27 6052 VenueClient venueclient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
09/25/07 15:30:27 6052 VenueClient venueclient.py:1195 DEBUG Setting node service streams
09/25/07 15:30:27 6052 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:30:27 6052 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:30:27 5840 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:30:27 6052 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:30:27 6052 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:30:27 6052 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:30:28 5264 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:30:28 6052 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:30:28 6052 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:30:28 6052 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, video, 8e33178a01c0396193a106993fbe7dcd, H261, 90000, 1, producer, video, 8e33178a01c0396193a106993fbe7dcd, H261, 90000, 1]) to service: http://142.51.23.138:61497/Services/VideoService.8e33178a0ae8396909e275db018ebd21
09/25/07 15:30:28 6052 VenueClient venueclient.py:914 DEBUG Updating client profile cache.
09/25/07 15:30:57 4376 VenueClient venueclient.py:1132 INFO ExitVenue
09/25/07 15:30:57 4376 VenueClient venueclient.py:1173 INFO ExitVenue: Stopping node services
09/25/07 15:30:57 4376 NodeService agnodeservice.py:301 INFO NodeService.StopServices
09/25/07 15:30:57 3284 ServiceManager agservicemanager.py:225 INFO AGServiceManager.StopServices
09/25/07 15:30:58 4376 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:30:58 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:30:58 4684 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:30:58 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:30:58 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:30:58 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:30:58 4376 VenueClient venueclient.py:1103 DEBUG ExitVenue: Stop event client obj
09/25/07 15:30:58 4376 VenueClient venueclient.py:1105 DEBUG ExitVenue: Remove event client reference
09/25/07 15:30:58 4376 VenueClient venueclient.py:1110 INFO ExitVenue: Stopping text client
09/25/07 15:30:58 4376 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'unavailable'...
09/25/07 15:30:58 4376 bajjer.io io.py:122 DEBUG SEND: <presence to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="unavailable"><x /></presence>
09/25/07 15:30:58 4376 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:30:58 4376 VenueClientController venueclientcontroller.py:435 DEBUG VenueClientController calling Venue.EnterVenue
09/25/07 15:30:58 4376 VenueClient venueclient.py:1015 DEBUG EnterVenue; url=https://agvs.sharcnet.ca:8000/Venues/42611c8c1fd71b5cc961de7d32e40d5f6b
09/25/07 15:30:58 4376 NodeService agnodeservice.py:658 INFO NodeService.GetCapabilities
09/25/07 15:30:58 6000 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:30:58 4376 VenueClient venueclient.py:1049 DEBUG calling __EnterVenue
09/25/07 15:30:58 4376 VenueClient venueclient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
09/25/07 15:30:58 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='unavailable' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item jid='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' affiliation='owner' role='none'/></x></presence>
09/25/07 15:30:58 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:30:58 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:30:58 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:30:58 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:30:58 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:30:58 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:30:58 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:30:58 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:30:58 5428 JabberClient jabberclient.py:148 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is unavailable (None / None)
09/25/07 15:30:58 5428 VenueClient venueclientui.py:2322 DEBUG remove user: Kalpdrum Passi
09/25/07 15:30:58 4376 VenueClient venueclient.py:808 DEBUG after Venue.Enter
09/25/07 15:30:58 4376 VenueClient venueclient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
09/25/07 15:30:58 4376 VenueClient venueclient.py:812 DEBUG EnterVenue: done Venue.getstate
09/25/07 15:30:59 3208 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:30:59 4376 VenueClient venueclient.py:835 DEBUG Setting isInVenue flag.
09/25/07 15:30:59 2564 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748659
09/25/07 15:30:59 4376 VenueClient venueclient.py:1051 DEBUG after __EnterVenue
09/25/07 15:30:59 4376 VenueClient venueclientui.py:2586 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agvs.sharcnet.ca:8000/Venues/42611c8c1fd71b5cc961de7d32e40d5f6b
09/25/07 15:30:59 4376 VenueClient venueclientui.py:2699 DEBUG Entered venue
09/25/07 15:30:59 4376 VenueClientController venueclientcontroller.py:437 DEBUG VenueClientController after Venue.EnterVenue
09/25/07 15:30:59 4376 VenueClient venueclientui.py:3349 DEBUG ContentListPanel.RemoveParticipant: Remove participant
09/25/07 15:30:59 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kalpdrum Passi (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:30:59 2564 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:30:59 2564 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'available'...
09/25/07 15:30:59 2564 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="available"><x /></presence>
09/25/07 15:30:59 2564 VenueClient venueclient.py:951 INFO Beacon being reconfigured, stopping running beacon
09/25/07 15:30:59 2564 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:30:59 2564 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address 224.2.216.54/54676
09/25/07 15:30:59 2564 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:30:59 2564 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:30:59 2564 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50080
09/25/07 15:30:59 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:30:59 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is available (None / None)
09/25/07 15:30:59 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kalpdrum Passi
09/25/07 15:30:59 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>sharcnet-venue-server-lobby(agvs.sharcnet.ca)</body></message>
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:30:59 2564 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50106
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:30:59 4376 EventClient insecurevenueeventclient.py:77 INFO BaseVenueEventClient lost connection.
09/25/07 15:30:59 2564 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50006
09/25/07 15:30:59 2564 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address agbs.sharcnet.ca/50106
09/25/07 15:30:59 2564 VenueClient venueclient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
09/25/07 15:30:59 2564 VenueClient venueclient.py:1195 DEBUG Setting node service streams
09/25/07 15:30:59 2564 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:30:59 2564 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:30:59 5532 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:30:59 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: sharcnet-venue-server-lobby(agvs.sharcnet.ca)
09/25/07 15:30:59 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
09/25/07 15:30:59 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><x/><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya' stamp='20070925T17:57:59'/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:30:59 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:30:59 4376 GroupMsgClient groupmsgclient.py:112 INFO Connected. Connection ID: 42611a03611e396a45b1b687961504a8
09/25/07 15:30:59 4376 EventClient insecurevenueeventclient.py:60 INFO BaseVenueEventClient made connection.
09/25/07 15:30:59 2564 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:31:00 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
09/25/07 15:31:00 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya is available (None / None)
09/25/07 15:31:00 2564 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:31:00 2564 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:31:00 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kaizaad Bilimorya (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:31:00 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kaizaad Bilimorya
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>no rat?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:44'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:31:00 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:31:00 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:31:00 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:31:00 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:31:00 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:31:00 2564 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:31:00 2564 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:31:00 2564 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, video, 42611a040f043962becd9b9c9e410277, H261, 90000, 1, producer, video, 42611a040f043962becd9b9c9e410277, H261, 90000, 1]) to service: http://142.51.23.138:61497/Services/VideoService.8e33178a0ae8396909e275db018ebd21
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>no</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:49'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I can't do much, have an hour-glass in my VenueClient config</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>killall -9 python</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:37'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>dave in the room?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:54'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 2564 VenueClient venueclient.py:914 DEBUG Updating client profile cache.
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>how did you know?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:51:02'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>Say something</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:52:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5220 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>hello?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:56:30'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>We can hear you</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:10'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>can you hear us?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I don't have a mic</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:58:41'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I am coming down</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:23'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>They are all encrypted except the nonEncrypted</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:51'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>did you go away. I can't see you in the lobby</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:12:59'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:00 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>can you hear me</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:14:19'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>ttps://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:49:20'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:31:01 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:31:01 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:31:01 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:31:01 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:31:01 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>https://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:02:56'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>:\Documents and Settings\Your_Windows_Login\Application Data\AccessGrid3\</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:06:16'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i cannot see the video or the audio</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:16:42'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>check that you are using the sharcnet bridge</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:19:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i am, but now the window screens for audo and video are not coming up</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:19:43'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>click the enable/disable button to turn them on/offf</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:20:15'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i tried</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:20:39'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Goto Venue -> Properties -> and read me back the address listed</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:22:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>224.2.124.15 video(multicast)</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:23:24'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>okay, something must have happened to the bridge</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:23:50'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>what should i do</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:24:10'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:02 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>sec</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:24:23'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:02 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:31:02 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:31:02 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:31:02 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:31:02 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:31:02 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:31:02 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Goto Tools -> Bridges -> SHARCNET</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:25:12'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:02 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i have selected SHARCNET under the bridges</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:25:33'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:02 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Even if it is selected, try selecting it again</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:26:26'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:02 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i did</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:26:32'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:31:02 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>Kalpdrum Passi has joined this session</body></message>
09/25/07 15:31:05 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: Kalpdrum Passi has joined this session
09/25/07 15:31:13 4376 VenueClient venueclient.py:548 DEBUG AddUserEvent: Got Add User Event
09/25/07 15:31:13 4376 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:31:13 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant UoGuelph-SHARCNET (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:31:13 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:31:13 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:31:13 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:31:13 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:31:13 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:31:13 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:31:13 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:31:13 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:31:13 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:31:13 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET is available (None / None)
09/25/07 15:31:15 5428 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:31:15 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>UoGuelph-SHARCNET has joined this session</body></message>
09/25/07 15:31:15 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:31:15 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:31:15 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:31:15 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:31:15 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: UoGuelph-SHARCNET has joined this session
09/25/07 15:31:35 2424 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748695
09/25/07 15:31:35 2424 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:31:58 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:31:58 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:31:58 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>i can't hear you</body></message>
09/25/07 15:31:59 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i can't hear you</body></message>
09/25/07 15:31:59 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:31:59 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:31:59 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:31:59 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:32:11 4308 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748731
09/25/07 15:32:12 4308 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:32:48 4936 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748768
09/25/07 15:32:48 4936 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:33:09 4376 VenueClient venueclient.py:1132 INFO ExitVenue
09/25/07 15:33:09 4376 VenueClient venueclient.py:1173 INFO ExitVenue: Stopping node services
09/25/07 15:33:09 4376 NodeService agnodeservice.py:301 INFO NodeService.StopServices
09/25/07 15:33:09 3540 ServiceManager agservicemanager.py:225 INFO AGServiceManager.StopServices
09/25/07 15:33:10 4376 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:33:10 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:33:10 4108 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:33:10 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:33:11 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:33:11 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:33:11 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:33:11 4376 VenueClient venueclient.py:1103 DEBUG ExitVenue: Stop event client obj
09/25/07 15:33:11 4376 VenueClient venueclient.py:1105 DEBUG ExitVenue: Remove event client reference
09/25/07 15:33:11 4376 VenueClient venueclient.py:1110 INFO ExitVenue: Stopping text client
09/25/07 15:33:11 4376 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'unavailable'...
09/25/07 15:33:11 4376 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="unavailable"><x /></presence>
09/25/07 15:33:11 4376 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:33:11 4376 VenueClientController venueclientcontroller.py:435 DEBUG VenueClientController calling Venue.EnterVenue
09/25/07 15:33:11 4376 VenueClient venueclient.py:1015 DEBUG EnterVenue; url=https://agvs.sharcnet.ca:8000/Venues/42611c8c20f11b5ccbcfc6b3dc40f3032e
09/25/07 15:33:11 4376 NodeService agnodeservice.py:658 INFO NodeService.GetCapabilities
09/25/07 15:33:11 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:33:11 1660 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:33:11 4392 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:33:11 4376 VenueClient venueclient.py:1049 DEBUG calling __EnterVenue
09/25/07 15:33:11 4376 VenueClient venueclient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
09/25/07 15:33:11 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='unavailable' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='none'/></x></presence>
09/25/07 15:33:11 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:33:11 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:33:11 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:33:11 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:33:11 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:33:11 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:33:11 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:33:11 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:33:11 5428 JabberClient jabberclient.py:148 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is unavailable (None / None)
09/25/07 15:33:11 5428 VenueClient venueclientui.py:2322 DEBUG remove user: Kalpdrum Passi
09/25/07 15:33:11 4376 VenueClient venueclient.py:808 DEBUG after Venue.Enter
09/25/07 15:33:11 4376 VenueClient venueclient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
09/25/07 15:33:11 4376 VenueClient venueclient.py:812 DEBUG EnterVenue: done Venue.getstate
09/25/07 15:33:12 4376 VenueClient venueclient.py:835 DEBUG Setting isInVenue flag.
09/25/07 15:33:12 4256 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748792
09/25/07 15:33:12 4376 VenueClient venueclient.py:1051 DEBUG after __EnterVenue
09/25/07 15:33:12 4376 VenueClient venueclientui.py:2586 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agvs.sharcnet.ca:8000/Venues/42611c8c20f11b5ccbcfc6b3dc40f3032e
09/25/07 15:33:12 4376 VenueClient venueclientui.py:2699 DEBUG Entered venue
09/25/07 15:33:12 4376 VenueClientController venueclientcontroller.py:437 DEBUG VenueClientController after Venue.EnterVenue
09/25/07 15:33:12 4376 VenueClient venueclientui.py:3349 DEBUG ContentListPanel.RemoveParticipant: Remove participant
09/25/07 15:33:12 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kalpdrum Passi (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:33:12 4256 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:33:12 4256 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'available'...
09/25/07 15:33:12 4256 bajjer.io io.py:122 DEBUG SEND: <presence to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="available"><x /></presence>
09/25/07 15:33:12 4256 VenueClient venueclient.py:951 INFO Beacon being reconfigured, stopping running beacon
09/25/07 15:33:12 4256 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:33:12 4256 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address 224.2.207.15/62052
09/25/07 15:33:12 4256 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:33:12 4256 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:33:12 4256 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50152
09/25/07 15:33:12 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item jid='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' affiliation='owner' role='moderator'/></x></presence>
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:33:12 5428 JabberClient jabberclient.py:145 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is available (None / None)
09/25/07 15:33:12 4256 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50180
09/25/07 15:33:12 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kalpdrum Passi
09/25/07 15:33:12 4256 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50008
09/25/07 15:33:12 4256 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address agbs.sharcnet.ca/50180
09/25/07 15:33:12 4256 VenueClient venueclient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
09/25/07 15:33:12 4256 VenueClient venueclient.py:1195 DEBUG Setting node service streams
09/25/07 15:33:12 4256 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:33:12 4256 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:33:12 4872 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:33:12 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>siteleaders(agvs.sharcnet.ca)</body></message>
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:33:12 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:33:12 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: siteleaders(agvs.sharcnet.ca)
09/25/07 15:33:12 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
09/25/07 15:33:12 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>Kalpdrum Passi has joined this session</body></message>
09/25/07 15:33:12 4256 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:33:12 4256 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:33:12 4256 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:33:12 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
09/25/07 15:33:12 4376 EventClient insecurevenueeventclient.py:77 INFO BaseVenueEventClient lost connection.
09/25/07 15:33:12 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: Kalpdrum Passi has joined this session
09/25/07 15:33:12 4376 GroupMsgClient groupmsgclient.py:112 INFO Connected. Connection ID: 42611a03611e396a799ea8dd081fb890
09/25/07 15:33:12 4376 EventClient insecurevenueeventclient.py:60 INFO BaseVenueEventClient made connection.
09/25/07 15:33:13 4256 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:33:13 4256 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, video, 8e33178a01c0396193a106993fbe7dcd, H261, 90000, 1, producer, video, 8e33178a01c0396193a106993fbe7dcd, H261, 90000, 1]) to service: http://142.51.23.138:61497/Services/VideoService.8e33178a0ae8396909e275db018ebd21
09/25/07 15:33:13 1604 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:33:13 4256 VenueClient venueclient.py:914 DEBUG Updating client profile cache.
09/25/07 15:33:40 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:33:40 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:33:40 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>i am in siteleaders room</body></message>
09/25/07 15:33:40 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i am in siteleaders room</body></message>
09/25/07 15:33:40 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:33:40 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:33:40 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:33:40 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:33:48 5536 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748828
09/25/07 15:33:48 5536 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:34:08 4376 VenueClient venueclient.py:548 DEBUG AddUserEvent: Got Add User Event
09/25/07 15:34:08 4376 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:34:08 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant UoGuelph-SHARCNET (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:34:09 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item jid='42611a0360cd3962e6d25df40bbf910d at jabber.mcs.anl.gov/default' affiliation='none' role='participant'/></x></presence>
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:34:09 5428 JabberClient jabberclient.py:145 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET is available (None / None)
09/25/07 15:34:09 5428 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:34:09 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>UoGuelph-SHARCNET has joined this session</body></message>
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:34:09 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:34:09 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: UoGuelph-SHARCNET has joined this session
09/25/07 15:34:24 5944 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748864
09/25/07 15:34:25 5944 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:34:29 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:34:29 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:34:29 4876 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:34:29 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:34:30 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:34:30 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:34:30 2504 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:34:30 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:34:30 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:34:30 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:34:30 4376 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:34:38 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>I have turned off my audio</body></message>
09/25/07 15:34:38 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:34:38 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:34:38 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:34:38 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:34:58 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:34:58 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:34:58 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>can you hear me</body></message>
09/25/07 15:34:58 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>can you hear me</body></message>
09/25/07 15:34:58 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:34:58 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:34:58 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:34:58 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:35:01 3292 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748901
09/25/07 15:35:01 3292 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:35:17 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Is your RAT still running?</body></message>
09/25/07 15:35:17 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:35:17 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:35:17 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:35:17 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:35:37 5228 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748937
09/25/07 15:35:38 5228 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:36:08 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:36:08 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:36:08 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>it crashed but then i disabled and renabled again and it came up again</body></message>
09/25/07 15:36:08 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>it crashed but then i disabled and renabled again and it came up again</body></message>
09/25/07 15:36:08 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:36:08 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:36:08 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:36:08 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:36:14 1620 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190748974
09/25/07 15:36:14 1620 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:36:21 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>So it is running now?</body></message>
09/25/07 15:36:21 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:36:21 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:36:21 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:36:21 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:36:50 1684 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749010
09/25/07 15:36:50 1684 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:36:53 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:36:53 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:36:53 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>somehow when i go to siteleaders room, it starts showing lot of entries below my names.</body></message>
09/25/07 15:36:53 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>somehow when i go to siteleaders room, it starts showing lot of entries below my names.</body></message>
09/25/07 15:36:53 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:36:53 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:36:53 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:36:53 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:37:01 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:37:01 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:37:01 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>yes it is running</body></message>
09/25/07 15:37:01 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>yes it is running</body></message>
09/25/07 15:37:01 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:37:01 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:37:01 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:37:01 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:37:04 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Okay, I am enabling my RAT...</body></message>
09/25/07 15:37:04 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:37:04 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:37:04 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:37:04 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:37:26 2564 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749046
09/25/07 15:37:26 2564 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:37:34 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:37:34 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:37:34 3612 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:37:34 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:37:35 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:37:35 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:37:35 5980 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:37:35 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:37:35 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:37:35 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:37:35 4376 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:37:35 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>my RAT is enabled now</body></message>
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:37:35 5428 bajjer.io io.py:161 DEBUG RECV: <presence type='unavailable' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><status>Disconnected</status><x xmlns='http://jabber.org/protocol/muc#user'><item jid='42611a0360cd3962e6d25df40bbf910d at jabber.mcs.anl.gov/default' affiliation='none' role='none'/></x></presence>
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}status> level=2
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}status> level=2
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:37:35 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:37:35 5428 JabberClient jabberclient.py:148 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET is unavailable (None / Disconnected)
09/25/07 15:37:35 4376 VenueClient venueclientui.py:3349 DEBUG ContentListPanel.RemoveParticipant: Remove participant
09/25/07 15:37:35 5428 VenueClient venueclientui.py:2322 DEBUG remove user: UoGuelph-SHARCNET
09/25/07 15:37:35 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>UoGuelph-SHARCNET has left: Disconnected</body></message>
09/25/07 15:37:36 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: UoGuelph-SHARCNET has left: Disconnected
09/25/07 15:38:02 4652 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749082
09/25/07 15:38:03 4652 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:38:12 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:38:12 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:38:12 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>as soon as you enabled it started showing many entries below my name and then crashed</body></message>
09/25/07 15:38:12 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>as soon as you enabled it started showing many entries below my name and then crashed</body></message>
09/25/07 15:38:12 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:38:12 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:38:12 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:38:12 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:38:18 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:38:18 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:38:18 2156 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:38:18 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:38:18 4108 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:38:19 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:38:19 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:38:19 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:38:19 4376 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:38:39 5024 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749119
09/25/07 15:38:39 5024 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:38:51 4376 JabberClient jabberclient.py:55 DEBUG currentRoom inside sendMessage(): 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov'
09/25/07 15:38:51 4376 JabberClient jabberclient.py:63 DEBUG Sending message to jabber server ...
09/25/07 15:38:51 4376 bajjer.io io.py:122 DEBUG SEND: <message to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov" type="groupchat"><body>it crashes when you enable your RAT</body></message>
09/25/07 15:38:52 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>it crashes when you enable your RAT</body></message>
09/25/07 15:38:52 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:38:52 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:38:52 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:38:52 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:39:02 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:39:02 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:39:02 4180 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:39:03 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:39:03 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:39:03 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:39:03 4536 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:39:03 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:39:03 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:39:03 4376 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:39:10 4376 VenueClient venueclient.py:561 DEBUG RemoveUserEvent: Got Remove User Event
09/25/07 15:39:10 4376 VenueClient venueclientui.py:2322 DEBUG remove user: UoGuelph-SHARCNET
09/25/07 15:39:10 4376 VenueClient venueclient.py:580 DEBUG RemoveUserEvent: Got Remove User Event...done
09/25/07 15:39:10 4376 VenueClient venueclientui.py:3349 DEBUG ContentListPanel.RemoveParticipant: Remove participant
09/25/07 15:39:10 4376 VenueClient venueclientui.py:3352 DEBUG ContentListPanel.RemoveParticipant: Found participant in tree
09/25/07 15:39:10 4376 VenueClient venueclientui.py:3356 DEBUG ContentListPanel.RemoveParticipant: Removed participant from tree
09/25/07 15:39:10 4376 VenueClient venueclientui.py:3359 DEBUG ContentListPanel.RemoveParticipant: Delete participant from dictionary
09/25/07 15:39:15 5996 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749155
09/25/07 15:39:16 5996 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:39:52 3284 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749192
09/25/07 15:39:55 3284 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:40:31 2504 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749231
09/25/07 15:40:31 2504 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:40:37 4376 VenueClient venueclient.py:548 DEBUG AddUserEvent: Got Add User Event
09/25/07 15:40:37 4376 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:40:37 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant UoGuelph-SHARCNET (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:40:37 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item jid='42611a03611e396b20ca40ff99bdd7d2 at jabber.mcs.anl.gov/default' affiliation='none' role='participant'/></x></presence>
09/25/07 15:40:37 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:40:37 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:40:37 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:40:37 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:40:37 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:40:37 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:40:37 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:40:37 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:40:37 5428 JabberClient jabberclient.py:145 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET is available (None / None)
09/25/07 15:40:37 5428 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:40:38 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>UoGuelph-SHARCNET has joined this session</body></message>
09/25/07 15:40:38 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:40:38 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:40:38 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:40:38 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:40:38 5428 JabberClient jabberclient.py:133 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.go: UoGuelph-SHARCNET has joined this session
09/25/07 15:40:55 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:40:55 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:40:55 3540 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:40:55 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:40:56 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:40:56 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:40:56 4068 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:40:56 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:40:56 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:40:56 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:40:56 4376 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:41:07 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Goto Lobby</body></message>
09/25/07 15:41:07 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:41:07 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:41:07 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:41:07 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:41:07 2324 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749267
09/25/07 15:41:08 2324 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:41:10 4376 VenueClient venueclient.py:1132 INFO ExitVenue
09/25/07 15:41:10 4376 VenueClient venueclient.py:1173 INFO ExitVenue: Stopping node services
09/25/07 15:41:10 4376 NodeService agnodeservice.py:301 INFO NodeService.StopServices
09/25/07 15:41:10 5644 ServiceManager agservicemanager.py:225 INFO AGServiceManager.StopServices
09/25/07 15:41:11 4376 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:41:11 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:41:11 5164 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:41:11 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:41:11 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:41:11 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:41:11 4376 VenueClient venueclient.py:1103 DEBUG ExitVenue: Stop event client obj
09/25/07 15:41:11 4376 VenueClient venueclient.py:1105 DEBUG ExitVenue: Remove event client reference
09/25/07 15:41:11 4376 VenueClient venueclient.py:1110 INFO ExitVenue: Stopping text client
09/25/07 15:41:11 4376 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'unavailable'...
09/25/07 15:41:11 4376 bajjer.io io.py:122 DEBUG SEND: <presence to="SiteLeaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="unavailable"><x /></presence>
09/25/07 15:41:11 4376 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:41:11 4376 VenueClientController venueclientcontroller.py:435 DEBUG VenueClientController calling Venue.EnterVenue
09/25/07 15:41:11 4376 VenueClient venueclient.py:1015 DEBUG EnterVenue; url=https://agvs.sharcnet.ca:8000/Venues/42611c8c1fd71b5cc961de7d32e40d5f6b
09/25/07 15:41:11 4376 NodeService agnodeservice.py:658 INFO NodeService.GetCapabilities
09/25/07 15:41:11 1492 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:41:11 876 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:41:11 4376 VenueClient venueclient.py:1049 DEBUG calling __EnterVenue
09/25/07 15:41:11 4376 VenueClient venueclient.py:806 DEBUG EnterVenue: Invoke Venue.Enter
09/25/07 15:41:11 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='unavailable' from='siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item jid='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' affiliation='owner' role='none'/></x></presence>
09/25/07 15:41:11 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:41:11 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:41:11 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:41:11 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:41:11 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:41:11 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:41:11 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:41:11 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:41:11 5428 JabberClient jabberclient.py:148 DEBUG siteleaders(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is unavailable (None / None)
09/25/07 15:41:11 5428 VenueClient venueclientui.py:2322 DEBUG remove user: Kalpdrum Passi
09/25/07 15:41:12 4376 VenueClient venueclient.py:808 DEBUG after Venue.Enter
09/25/07 15:41:12 4376 VenueClient venueclient.py:810 DEBUG EnterVenue: Invoke Venue.getstate
09/25/07 15:41:12 4376 VenueClient venueclient.py:812 DEBUG EnterVenue: done Venue.getstate
09/25/07 15:41:12 4376 VenueClient venueclient.py:835 DEBUG Setting isInVenue flag.
09/25/07 15:41:12 880 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749272
09/25/07 15:41:12 4376 VenueClient venueclient.py:1051 DEBUG after __EnterVenue
09/25/07 15:41:12 4376 VenueClient venueclientui.py:2586 DEBUG bin.VenueClient::EnterVenue: Enter venue with url: https://agvs.sharcnet.ca:8000/Venues/42611c8c1fd71b5cc961de7d32e40d5f6b
09/25/07 15:41:12 4376 VenueClient venueclientui.py:2699 DEBUG Entered venue
09/25/07 15:41:12 4376 VenueClientController venueclientcontroller.py:437 DEBUG VenueClientController after Venue.EnterVenue
09/25/07 15:41:12 4376 VenueClient venueclientui.py:3349 DEBUG ContentListPanel.RemoveParticipant: Remove participant
09/25/07 15:41:12 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kalpdrum Passi (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:41:12 4376 EventClient insecurevenueeventclient.py:77 INFO BaseVenueEventClient lost connection.
09/25/07 15:41:13 880 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:41:13 880 JabberClient jabberclient.py:73 DEBUG Sending the presence to 'SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi' of type 'available'...
09/25/07 15:41:13 880 bajjer.io io.py:122 DEBUG SEND: <presence to="SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi" type="available"><x /></presence>
09/25/07 15:41:13 880 VenueClient venueclient.py:951 INFO Beacon being reconfigured, stopping running beacon
09/25/07 15:41:13 880 RTPBeacon rtpbeacon.py:296 DEBUG Called Stop.
09/25/07 15:41:13 880 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address 224.2.243.114/55670
09/25/07 15:41:13 880 RTPBeacon rtpbeacon.py:278 DEBUG Called Start.
09/25/07 15:41:13 880 VenueClient venueclient.py:1231 INFO In UpdateStream: transport=unicast
09/25/07 15:41:13 4376 GroupMsgClient groupmsgclient.py:112 INFO Connected. Connection ID: 42611a03611e396b357ef18da76b37e8
09/25/07 15:41:13 4376 EventClient insecurevenueeventclient.py:60 INFO BaseVenueEventClient made connection.
09/25/07 15:41:13 880 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50080
09/25/07 15:41:13 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:41:13 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi is available (None / None)
09/25/07 15:41:13 880 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50020
09/25/07 15:41:13 880 VenueClient venueclient.py:1260 DEBUG Got location from bridge: unicast agbs.sharcnet.ca 50156
09/25/07 15:41:13 880 VenueClient venueclient.py:959 INFO VenueClient.StartBeacon: Address agbs.sharcnet.ca/50020
09/25/07 15:41:13 880 VenueClient venueclient.py:1190 DEBUG UpdateNodeService: Method UpdateNodeService called
09/25/07 15:41:13 880 VenueClient venueclient.py:1195 DEBUG Setting node service streams
09/25/07 15:41:13 880 NodeService agnodeservice.py:328 INFO NodeService.SetStreams
09/25/07 15:41:13 880 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:41:13 1092 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:41:13 880 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:41:13 880 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:41:13 880 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:41:13 2256 RTPBeacon rtpbeacon.py:289 INFO RTPBeacon.UpdateThread exiting
09/25/07 15:41:13 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kalpdrum Passi
09/25/07 15:41:13 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>sharcnet-venue-server-lobby(agvs.sharcnet.ca)</body></message>
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:41:13 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: sharcnet-venue-server-lobby(agvs.sharcnet.ca)
09/25/07 15:41:13 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov'><body>This room supports the MUC protocol.</body></message>
09/25/07 15:41:13 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><x/><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya' stamp='20070925T17:57:59'/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:41:13 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:41:14 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: This room supports the MUC protocol.
09/25/07 15:41:14 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya is available (None / None)
09/25/07 15:41:14 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant Kaizaad Bilimorya (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:41:14 5428 VenueClient venueclientui.py:2308 DEBUG add user: Kaizaad Bilimorya
09/25/07 15:41:14 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>no rat?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:44'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:14 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:41:14 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:41:14 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:41:14 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:41:14 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:41:14 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:41:14 880 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:41:14 880 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1, producer, video, 8e33178a0ae8396909ad069941034ff2, H261, 90000, 1]
09/25/07 15:41:14 880 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, video, 42611a040f043962becd9b9c9e410277, H261, 90000, 1, producer, video, 42611a040f043962becd9b9c9e410277, H261, 90000, 1]) to service: http://142.51.23.138:61497/Services/VideoService.8e33178a0ae8396909e275db018ebd21
09/25/07 15:41:14 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>no</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:49:49'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:14 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I can't do much, have an hour-glass in my VenueClient config</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:14 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>killall -9 python</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:37'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:14 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>dave in the room?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:50:54'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:14 4376 VenueClient venueclient.py:548 DEBUG AddUserEvent: Got Add User Event
09/25/07 15:41:14 4376 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:41:14 4376 VenueClient venueclientui.py:3333 DEBUG ContentListPanel.AddParticipant:: AddParticipant UoGuelph-SHARCNET (called from ('C:\\Python23\\Lib\\site-packages\\wx-2.6-msw-unicode\\wx\\_core.py', 13469, '<lambda>', 'lambda event: event.callable(*event.args, **event.kw) )'))
09/25/07 15:41:14 880 VenueClient venueclient.py:914 DEBUG Updating client profile cache.
09/25/07 15:41:14 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>how did you know?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:51:02'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:14 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>Say something</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:52:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:14 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>hello?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:56:30'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:14 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>We can hear you</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:10'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:14 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Fanshawe-SHARCNET'><body>can you hear us?</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:57:18'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:14 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I don't have a mic</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:58:41'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>I am coming down</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:23'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:41:15 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:41:15 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:41:15 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:41:15 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:41:15 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kaizaad Bilimorya'><body>They are all encrypted except the nonEncrypted</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T17:59:51'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>did you go away. I can't see you in the lobby</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:12:59'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>can you hear me</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:14:19'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>ttps://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T18:49:20'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>https://venueserver.westgrid.ca:8000/Venues/default</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:02:56'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>:\Documents and Settings\Your_Windows_Login\Application Data\AccessGrid3\</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:06:16'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i cannot see the video or the audio</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:16:42'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>check that you are using the sharcnet bridge</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:19:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i am, but now the window screens for audo and video are not coming up</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:19:43'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>click the enable/disable button to turn them on/offf</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:20:15'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i tried</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:20:39'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Goto Venue -> Properties -> and read me back the address listed</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:22:00'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>224.2.124.15 video(multicast)</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:23:24'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>okay, something must have happened to the bridge</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:23:50'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:15 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>what should i do</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:24:10'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:16 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>sec</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:24:23'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:x:delay}x> level=2
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:x:delay}x> level=2
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:41:16 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Goto Tools -> Bridges -> SHARCNET</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:25:12'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:16 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i have selected SHARCNET under the bridges</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:25:33'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:16 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><body>Even if it is selected, try selecting it again</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:26:26'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:16 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i did</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:26:32'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:16 5428 bajjer.io io.py:161 DEBUG RECV: <message to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/Kalpdrum Passi'><body>i can't hear you</body><x xmlns='jabber:x:delay' from='SHARCNET-Venue-Server-Lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' stamp='20070925T19:32:01'>sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov</x></message>
09/25/07 15:41:16 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>Kalpdrum Passi has joined this session</body></message>
09/25/07 15:41:16 5428 bajjer.io io.py:161 DEBUG RECV: <presence to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET'><x/><x xmlns='http://jabber.org/protocol/muc#user'><item affiliation='none' role='participant'/></x></presence>
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}presence> level=1
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}x> level=2
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}x> level=2
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:72 DEBUG start <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}item> level=3
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:86 DEBUG end <{http://jabber.org/protocol/muc#user}x> level=2
09/25/07 15:41:16 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}presence> level=1
09/25/07 15:41:17 5428 JabberClient jabberclient.py:145 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov/UoGuelph-SHARCNET is available (None / None)
09/25/07 15:41:17 5428 VenueClient venueclientui.py:2308 DEBUG add user: UoGuelph-SHARCNET
09/25/07 15:41:17 5428 bajjer.io io.py:161 DEBUG RECV: <message type='groupchat' from='sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.gov' to='42611a03611e3969120684ddd0b4b5df at jabber.mcs.anl.gov/default'><body>UoGuelph-SHARCNET has joined this session</body></message>
09/25/07 15:41:17 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}message> level=1
09/25/07 15:41:17 5428 bajjer.serialize serialize.py:72 DEBUG start <{jabber:client}body> level=2
09/25/07 15:41:17 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}body> level=2
09/25/07 15:41:17 5428 bajjer.serialize serialize.py:86 DEBUG end <{jabber:client}message> level=1
09/25/07 15:41:21 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: Kalpdrum Passi has joined this session
09/25/07 15:41:21 5428 JabberClient jabberclient.py:133 DEBUG sharcnet-venue-server-lobby(agvs.sharcnet.ca)@conference.mcs.anl.go: UoGuelph-SHARCNET has joined this session
09/25/07 15:41:49 5556 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749309
09/25/07 15:41:49 5556 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:42:25 4636 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749345
09/25/07 15:42:25 4636 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:42:27 4376 VenueClient venueclientui.py:1300 DEBUG VenueClientFrame.ManageNodeCB: open node management
09/25/07 15:42:27 4376 VenueClient venueclientui.py:1301 DEBUG nodeservice url: <AccessGrid.AGNodeService.AGNodeService instance at 0x02CFC5A8>
09/25/07 15:42:27 4376 NodeService agnodeservice.py:248 INFO NodeService.GetServiceManagers
09/25/07 15:42:27 1840 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:42:55 4376 NodeService agnodeservice.py:635 INFO NodeService.GetConfigurations
09/25/07 15:43:01 3284 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749381
09/25/07 15:43:02 3284 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:43:10 4376 NodeService agnodeservice.py:525 INFO NodeService.StoreConfiguration
09/25/07 15:43:10 2504 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:43:10 4376 NodeService agnodeservice.py:592 DEBUG No resource specified
09/25/07 15:43:10 4376 NodeService agnodeservice.py:584 DEBUG Storing resource: Logitech QuickCam Chat
09/25/07 15:43:10 4376 VenueClient preferences.py:157 DEBUG Preferences.StorePreferences: open file
09/25/07 15:43:10 4376 NodeService agnodeservice.py:635 INFO NodeService.GetConfigurations
09/25/07 15:43:20 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:43:20 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:43:20 4740 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:43:21 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:43:25 4376 NodeService agnodeservice.py:289 INFO NodeService.SetServiceEnabledByMediaType
09/25/07 15:43:25 4376 NodeService agnodeservice.py:257 INFO NodeService.GetServices
09/25/07 15:43:25 5856 ServiceManager agservicemanager.py:218 INFO AGServiceManager.GetServices
09/25/07 15:43:25 4376 NodeService agnodeservice.py:275 INFO NodeService.SetServiceEnabled
09/25/07 15:43:25 4376 NodeService agnodeservice.py:695 INFO NodeService.__SendStreamsToService
09/25/07 15:43:25 4376 NodeService agnodeservice.py:699 DEBUG service capabilities: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]
09/25/07 15:43:25 4376 NodeService agnodeservice.py:713 INFO Sending stream (type=[consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1]) to service: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:43:38 5144 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749418
09/25/07 15:43:38 5144 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:44:14 5600 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749454
09/25/07 15:44:14 5600 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:44:50 4204 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749490
09/25/07 15:44:51 4204 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:45:27 4208 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749527
09/25/07 15:45:27 4208 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:46:03 1912 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749563
09/25/07 15:46:03 1912 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:46:39 5412 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749599
09/25/07 15:46:49 5412 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:47:25 5932 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749645
09/25/07 15:47:25 5932 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:48:01 4660 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749681
09/25/07 15:48:02 4660 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:48:38 3612 VenueClient venueclient.py:450 DEBUG Calling Heartbeat, time now: 1190749718
09/25/07 15:48:38 3612 VenueClient venueclient.py:474 DEBUG Next Heartbeat needed within 36s
09/25/07 15:13:43 1268 Toolkit config.py:563 ERROR Error setting hostname.
Traceback (most recent call last):
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Config.py", line 557, in SetHostname
sock.bind((hostname, 0))
File "<string>", line 1, in bind
gaierror: (7, 'getaddrinfo failed')
09/25/07 15:13:43 1268 Toolkit config.py:575 DEBUG retrieved local IP address 142.51.23.138
09/25/07 15:13:43 1268 Toolkit toolkit.py:111 DEBUG Initializing AG Toolkit version 3.0.2
09/25/07 15:13:43 1268 Toolkit toolkit.py:112 INFO Command and arguments: ['C:\\Documents and Settings\\kpassi\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', '51529', '--serviceManagerUri', 'http://142.51.23.138:11000/ServiceManager', '--token', '8e33178a147c3968ae7586edebfdbdd4']
09/25/07 15:13:43 1268 VenueClient preferences.py:180 DEBUG Preferences.LoadPreferences: open file
09/25/07 15:13:43 1268 Toolkit toolkit.py:161 INFO Logfile Name: AudioService.log
09/25/07 15:13:43 1268 Toolkit toolkit.py:650 INFO Service init: have profile None
09/25/07 15:13:43 1268 Toolkit toolkit.py:675 INFO Service Initialization Complete.
09/25/07 15:13:43 1268 Toolkit agservice.py:363 INFO Starting Service URI: http://142.51.23.138:51529/Services/AudioService.8e33178a12843968aed75eaba471797c
09/25/07 15:13:43 1268 Toolkit agservice.py:373 DEBUG Registering with service manager; url=http://142.51.23.138:11000/ServiceManager
09/25/07 15:13:44 4500 Toolkit audioservice.py:349 INFO SetIdentity: Kalpdrum Passi kpassi at cs.laurentian.ca
09/25/07 15:13:46 6020 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 1
09/25/07 15:14:04 4128 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L16, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, L8, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, PCMU, 8000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 16000, 1, consumer, audio, 8e33178a12843968aeb1071b328e8126, GSM, 8000, 1, producer, audio, 8e33178a12843968aeb1071b328e8126, L16, 16000, 1] agbs.sharcnet.ca 50116
09/25/07 15:14:04 4128 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:14:04 4128 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:14:04 4128 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:14:04 4128 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:14:04 4128 Toolkit audioservice.py:280 INFO options = ['-C', u'SHARCNET Venue Server Lobby', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', u'agbs.sharcnet.ca/50116']
09/25/07 15:14:04 4128 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C "SHARCNET Venue Server Lobby" -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono agbs.sharcnet.ca/50116
09/25/07 15:14:04 4128 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:748>, <PyHANDLE:756>, 5632, 5316)
09/25/07 15:14:28 4504 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:14:28 4504 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:14:28 4504 ProcessManager processmanager.py:136 WARNING Couldn't terminate process <PyHANDLE:748> cleanly (258)
09/25/07 15:15:33 428 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:15:33 428 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:17:25 1172 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:17:25 1172 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:17:26 2784 Toolkit agservice.py:238 INFO Shut service down
09/25/07 15:17:26 2784 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:17:26 2784 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:17:35 4288 Toolkit config.py:563 ERROR Error setting hostname.
09/25/07 15:17:35 4288 Toolkit config.py:575 DEBUG retrieved local IP address 142.51.23.138
09/25/07 15:17:35 4288 Toolkit toolkit.py:111 DEBUG Initializing AG Toolkit version 3.0.2
09/25/07 15:17:35 4288 Toolkit toolkit.py:112 INFO Command and arguments: ['C:\\Documents and Settings\\kpassi\\Application Data\\AccessGrid3\\local_services\\AudioService\\AudioService.py', '--port', '63525', '--serviceManagerUri', 'http://142.51.23.138:11000/ServiceManager', '--token', '8e33178a0648396908f6c6c4cd630043']
09/25/07 15:17:35 4288 VenueClient preferences.py:180 DEBUG Preferences.LoadPreferences: open file
09/25/07 15:17:35 4288 Toolkit toolkit.py:161 INFO Logfile Name: AudioService.log
09/25/07 15:17:35 4288 Toolkit toolkit.py:650 INFO Service init: have profile None
09/25/07 15:17:35 4288 Toolkit toolkit.py:675 INFO Service Initialization Complete.
09/25/07 15:17:35 4288 Toolkit agservice.py:363 INFO Starting Service URI: http://142.51.23.138:63525/Services/AudioService.8e33178a094039690952da71ace564e1
09/25/07 15:17:35 4288 Toolkit agservice.py:373 DEBUG Registering with service manager; url=http://142.51.23.138:11000/ServiceManager
09/25/07 15:17:35 5228 Toolkit audioservice.py:349 INFO SetIdentity: Kalpdrum Passi kpassi at cs.laurentian.ca
09/25/07 15:17:37 4968 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 1
09/25/07 15:20:22 1216 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 0
09/25/07 15:20:22 1216 Toolkit agservice.py:220 INFO Stopping service
09/25/07 15:20:22 1216 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:20:22 1216 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:20:22 5524 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 1
09/25/07 15:20:22 5524 Toolkit agservice.py:223 INFO Starting service
09/25/07 15:20:22 5524 Toolkit audioservice.py:284 ERROR Exception in AudioService.Start
File "C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\AudioService.py", line 239, in Start
if self.streamDescription.name and \
AttributeError: 'int' object has no attribute 'name'
09/25/07 15:20:22 5524 Hosting servicecontainer.py:16 ERROR Processing Failure
exceptions:Exception
Failed to start service
[trace: C:\Python23\lib\site-packages\ZSI\ServiceContainer.py:107:_Dispatch
C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\interfaces\AGService_interface.py:1212:soap_SetEnabled
C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\AGService.py:224:SetEnabled
C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\AudioService.py:285:Start]
09/25/07 15:20:26 5660 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 0
09/25/07 15:21:17 1268 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 1
09/25/07 15:21:17 1268 Toolkit agservice.py:223 INFO Starting service
09/25/07 15:21:17 1268 Toolkit audioservice.py:284 ERROR Exception in AudioService.Start
09/25/07 15:21:17 1268 Hosting servicecontainer.py:16 ERROR Processing Failure
09/25/07 15:26:44 5024 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:26:44 5024 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:26:46 5380 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50158
09/25/07 15:26:46 5380 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:26:46 5380 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:26:46 5380 Toolkit audioservice.py:280 INFO options = ['-C', u'SHARCNET Venue Server Lobby', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', u'agbs.sharcnet.ca/50158']
09/25/07 15:26:46 5380 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C "SHARCNET Venue Server Lobby" -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono agbs.sharcnet.ca/50158
09/25/07 15:26:46 5380 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:748>, <PyHANDLE:756>, 1812, 4464)
09/25/07 15:28:05 1228 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:28:05 1228 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:28:05 1228 ProcessManager processmanager.py:136 WARNING Couldn't terminate process <PyHANDLE:748> cleanly (258)
09/25/07 15:28:08 5908 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50066
09/25/07 15:28:08 5908 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:28:08 5908 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:28:08 5908 Toolkit audioservice.py:280 INFO options = ['-C', u'SiteLeaders', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', '-crypt', u'Rijndael/58a7010f0f682b07', u'agbs.sharcnet.ca/50066']
09/25/07 15:28:08 5908 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C SiteLeaders -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono -crypt Rijndael/58a7010f0f682b07 agbs.sharcnet.ca/50066
09/25/07 15:28:08 5908 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:720>, <PyHANDLE:712>, 3076, 4028)
09/25/07 15:29:24 4428 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:29:24 4428 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:29:24 4428 ProcessManager processmanager.py:136 WARNING Couldn't terminate process <PyHANDLE:720> cleanly (258)
09/25/07 15:29:29 4140 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50158
09/25/07 15:29:29 4140 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:29:29 4140 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:29:29 4140 Toolkit audioservice.py:280 INFO options = ['-C', u'SHARCNET Venue Server Lobby', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', u'agbs.sharcnet.ca/50158']
09/25/07 15:29:30 4140 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C "SHARCNET Venue Server Lobby" -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono agbs.sharcnet.ca/50158
09/25/07 15:29:30 4140 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:756>, <PyHANDLE:748>, 424, 5164)
09/25/07 15:30:22 1092 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:30:22 1092 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:30:22 1092 ProcessManager processmanager.py:136 WARNING Couldn't terminate process <PyHANDLE:756> cleanly (258)
09/25/07 15:30:28 2144 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50100
09/25/07 15:30:28 2144 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:30:28 2144 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:30:28 2144 Toolkit audioservice.py:280 INFO options = ['-C', u'SiteLeaders', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', '-crypt', u'Rijndael/58a7010f0f682b07', u'agbs.sharcnet.ca/50100']
09/25/07 15:30:28 2144 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C SiteLeaders -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono -crypt Rijndael/58a7010f0f682b07 agbs.sharcnet.ca/50100
09/25/07 15:30:28 2144 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:712>, <PyHANDLE:728>, 4124, 300)
09/25/07 15:30:57 4764 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:30:57 4764 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:30:57 4764 ProcessManager processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:712>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Platform\win32\ProcessManager.py", line 131, in TerminateProcess
win32api.PostThreadMessage(self.threadid[pid], 18, 0, 0)
error: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
09/25/07 15:30:57 4764 ProcessManager processmanager.py:145 ERROR couldn't terminate process <PyHANDLE:712>: (5, 'TerminateProcess', 'Access is denied.')
File "C:\Python23\lib\site-packages\AccessGrid3\AccessGrid\Platform\win32\ProcessManager.py", line 142, in TerminateProcess
win32process.TerminateProcess(pid, 0)
error: (5, 'TerminateProcess', 'Access is denied.')
09/25/07 15:31:00 5680 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50006
09/25/07 15:31:00 5680 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:31:00 5680 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:31:00 5680 Toolkit audioservice.py:280 INFO options = ['-C', u'SHARCNET Venue Server Lobby', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', u'agbs.sharcnet.ca/50006']
09/25/07 15:31:00 5680 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C "SHARCNET Venue Server Lobby" -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono agbs.sharcnet.ca/50006
09/25/07 15:31:00 5680 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:748>, <PyHANDLE:756>, 4680, 1672)
09/25/07 15:33:09 2984 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:33:09 2984 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:33:10 2984 ProcessManager processmanager.py:136 WARNING Couldn't terminate process <PyHANDLE:748> cleanly (258)
09/25/07 15:33:12 5148 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50008
09/25/07 15:33:12 5148 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:33:12 5148 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:33:12 5148 Toolkit audioservice.py:280 INFO options = ['-C', u'SiteLeaders', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', '-crypt', u'Rijndael/58a7010f0f682b07', u'agbs.sharcnet.ca/50008']
09/25/07 15:33:12 5148 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C SiteLeaders -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono -crypt Rijndael/58a7010f0f682b07 agbs.sharcnet.ca/50008
09/25/07 15:33:12 5148 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:728>, <PyHANDLE:712>, 5144, 1684)
09/25/07 15:34:29 3120 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 0
09/25/07 15:34:29 3120 Toolkit agservice.py:220 INFO Stopping service
09/25/07 15:34:29 3120 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:34:29 3120 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:34:29 3120 ProcessManager processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:728>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
09/25/07 15:34:29 3120 ProcessManager processmanager.py:145 ERROR couldn't terminate process <PyHANDLE:728>: (5, 'TerminateProcess', 'Access is denied.')
09/25/07 15:34:31 4764 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50008
09/25/07 15:34:31 4764 Toolkit agservice.py:182 INFO SetStream: ignoring trivial re-configuration
09/25/07 15:34:31 5436 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 1
09/25/07 15:34:31 5436 Toolkit agservice.py:223 INFO Starting service
09/25/07 15:34:31 5436 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:34:31 5436 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:34:31 5436 Toolkit audioservice.py:280 INFO options = ['-C', u'SiteLeaders', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', '-crypt', u'Rijndael/58a7010f0f682b07', u'agbs.sharcnet.ca/50008']
09/25/07 15:34:31 5436 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C SiteLeaders -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono -crypt Rijndael/58a7010f0f682b07 agbs.sharcnet.ca/50008
09/25/07 15:34:31 5436 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:712>, <PyHANDLE:736>, 2148, 4684)
09/25/07 15:37:34 2280 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 0
09/25/07 15:37:34 2280 Toolkit agservice.py:220 INFO Stopping service
09/25/07 15:37:34 2280 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:37:34 2280 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:37:34 2280 ProcessManager processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:712>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
09/25/07 15:37:34 2280 ProcessManager processmanager.py:145 ERROR couldn't terminate process <PyHANDLE:712>: (5, 'TerminateProcess', 'Access is denied.')
09/25/07 15:37:35 5812 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50008
09/25/07 15:37:35 5812 Toolkit agservice.py:182 INFO SetStream: ignoring trivial re-configuration
09/25/07 15:37:35 6108 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 1
09/25/07 15:37:35 6108 Toolkit agservice.py:223 INFO Starting service
09/25/07 15:37:35 6108 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:37:35 6108 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:37:35 6108 Toolkit audioservice.py:280 INFO options = ['-C', u'SiteLeaders', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', '-crypt', u'Rijndael/58a7010f0f682b07', u'agbs.sharcnet.ca/50008']
09/25/07 15:37:35 6108 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C SiteLeaders -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono -crypt Rijndael/58a7010f0f682b07 agbs.sharcnet.ca/50008
09/25/07 15:37:35 6108 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:744>, <PyHANDLE:716>, 888, 5988)
09/25/07 15:38:18 4204 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 0
09/25/07 15:38:18 4204 Toolkit agservice.py:220 INFO Stopping service
09/25/07 15:38:18 4204 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:38:18 4204 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:38:18 4204 ProcessManager processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:744>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
09/25/07 15:38:18 4204 ProcessManager processmanager.py:145 ERROR couldn't terminate process <PyHANDLE:744>: (5, 'TerminateProcess', 'Access is denied.')
09/25/07 15:38:19 2144 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50008
09/25/07 15:38:19 2144 Toolkit agservice.py:182 INFO SetStream: ignoring trivial re-configuration
09/25/07 15:38:19 5320 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 1
09/25/07 15:38:19 5320 Toolkit agservice.py:223 INFO Starting service
09/25/07 15:38:19 5320 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:38:19 5320 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:38:19 5320 Toolkit audioservice.py:280 INFO options = ['-C', u'SiteLeaders', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', '-crypt', u'Rijndael/58a7010f0f682b07', u'agbs.sharcnet.ca/50008']
09/25/07 15:38:19 5320 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C SiteLeaders -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono -crypt Rijndael/58a7010f0f682b07 agbs.sharcnet.ca/50008
09/25/07 15:38:19 5320 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:708>, <PyHANDLE:756>, 5316, 2336)
09/25/07 15:39:03 4928 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 0
09/25/07 15:39:03 4928 Toolkit agservice.py:220 INFO Stopping service
09/25/07 15:39:03 4928 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:39:03 4928 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:39:03 4928 ProcessManager processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:708>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
09/25/07 15:39:03 4928 ProcessManager processmanager.py:145 ERROR couldn't terminate process <PyHANDLE:708>: (5, 'TerminateProcess', 'Access is denied.')
09/25/07 15:39:03 5816 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50008
09/25/07 15:39:03 5816 Toolkit agservice.py:182 INFO SetStream: ignoring trivial re-configuration
09/25/07 15:39:03 1336 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 1
09/25/07 15:39:03 1336 Toolkit agservice.py:223 INFO Starting service
09/25/07 15:39:03 1336 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:39:03 1336 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:39:03 1336 Toolkit audioservice.py:280 INFO options = ['-C', u'SiteLeaders', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', '-crypt', u'Rijndael/58a7010f0f682b07', u'agbs.sharcnet.ca/50008']
09/25/07 15:39:04 1336 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C SiteLeaders -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono -crypt Rijndael/58a7010f0f682b07 agbs.sharcnet.ca/50008
09/25/07 15:39:04 1336 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:720>, <PyHANDLE:752>, 4192, 1912)
09/25/07 15:40:55 4108 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 0
09/25/07 15:40:55 4108 Toolkit agservice.py:220 INFO Stopping service
09/25/07 15:40:55 4108 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:40:55 4108 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:40:55 4108 ProcessManager processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:720>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
09/25/07 15:40:55 4108 ProcessManager processmanager.py:145 ERROR couldn't terminate process <PyHANDLE:720>: (5, 'TerminateProcess', 'Access is denied.')
09/25/07 15:40:56 1720 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50008
09/25/07 15:40:56 1720 Toolkit agservice.py:182 INFO SetStream: ignoring trivial re-configuration
09/25/07 15:40:56 6004 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 1
09/25/07 15:40:56 6004 Toolkit agservice.py:223 INFO Starting service
09/25/07 15:40:56 6004 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:40:56 6004 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:40:56 6004 Toolkit audioservice.py:280 INFO options = ['-C', u'SiteLeaders', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', '-crypt', u'Rijndael/58a7010f0f682b07', u'agbs.sharcnet.ca/50008']
09/25/07 15:40:56 6004 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C SiteLeaders -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono -crypt Rijndael/58a7010f0f682b07 agbs.sharcnet.ca/50008
09/25/07 15:40:56 6004 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:712>, <PyHANDLE:756>, 3112, 5944)
09/25/07 15:41:10 316 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:41:10 316 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:41:10 316 ProcessManager processmanager.py:138 ERROR couldn't shutdown process <PyHANDLE:712>: (1444, 'PostThreadMessage', 'Invalid thread identifier.')
09/25/07 15:41:10 316 ProcessManager processmanager.py:145 ERROR couldn't terminate process <PyHANDLE:712>: (5, 'TerminateProcess', 'Access is denied.')
09/25/07 15:41:14 252 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50156
09/25/07 15:41:14 252 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:41:14 252 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:41:14 252 Toolkit audioservice.py:280 INFO options = ['-C', u'SHARCNET Venue Server Lobby', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', u'agbs.sharcnet.ca/50156']
09/25/07 15:41:14 252 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C "SHARCNET Venue Server Lobby" -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono agbs.sharcnet.ca/50156
09/25/07 15:41:14 252 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:724>, <PyHANDLE:720>, 4680, 1460)
09/25/07 15:43:21 5600 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 0
09/25/07 15:43:21 5600 Toolkit agservice.py:220 INFO Stopping service
09/25/07 15:43:21 5600 Toolkit audioservice.py:292 INFO Stop service
09/25/07 15:43:21 5600 Toolkit audioservice.py:307 INFO rat-kill not found; rat may not die completely
09/25/07 15:43:21 5600 ProcessManager processmanager.py:136 WARNING Couldn't terminate process <PyHANDLE:724> cleanly (258)
09/25/07 15:43:26 4660 Toolkit agservice.py:171 INFO SetStream: [consumer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L16, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, L8, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, PCMU, 8000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 16000, 1, consumer, audio, 8e33178a094039690933069941213d2c, GSM, 8000, 1, producer, audio, 8e33178a094039690933069941213d2c, L16, 16000, 1] agbs.sharcnet.ca 50156
09/25/07 15:43:26 4660 Toolkit agservice.py:182 INFO SetStream: ignoring trivial re-configuration
09/25/07 15:43:26 4972 Toolkit agservice.py:214 INFO AGService.SetEnabled : enabled = 1
09/25/07 15:43:26 4972 Toolkit agservice.py:223 INFO Starting service
09/25/07 15:43:26 4972 Toolkit audioservice.py:277 INFO Starting AudioService
09/25/07 15:43:26 4972 Toolkit audioservice.py:278 INFO executable = C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe
09/25/07 15:43:26 4972 Toolkit audioservice.py:280 INFO options = ['-C', u'SHARCNET Venue Server Lobby', '-S', u'8e33178a0a9c14d81e9ec1936368541e', '-f', 'L16-16K-Mono', u'agbs.sharcnet.ca/50156']
09/25/07 15:43:26 4972 ProcessManager processmanager.py:62 DEBUG Creating process: C:\Documents and Settings\kpassi\Application Data\AccessGrid3\local_services\AudioService\rat.exe -C "SHARCNET Venue Server Lobby" -S 8e33178a0a9c14d81e9ec1936368541e -f L16-16K-Mono agbs.sharcnet.ca/50156
09/25/07 15:43:26 4972 ProcessManager processmanager.py:75 DEBUG Create process returns: (<PyHANDLE:716>, <PyHANDLE:756>, 3888, 1228)
