[AG-TECH] NAT and bridge traffic
Thomas D. Uram
turam at mcs.anl.gov
Tue Sep 11 14:11:19 CDT 2007
You can use a narrowed port range by looking at the port range used by
the bridge
you want to use. This is found in the VenueClient under
Tools->Preferences->Bridging;
each bridge is listed with its related port range (the rightmost column
in the list, you may
need to stretch the preferences window to see it).
The default port range for unicast bridges is 50000-52000, but some
bridges do use
alternate port ranges so you should check.
Tom
On 9/11/07 10:13 AM, Jeremy Mann wrote:
> George, I've used AG from home several times and I'm behind a Linksys
> router. All that you have to do is forward the bridge ports of the
> Bridge Server to your internal IP. Generally, I forward 30000 to 65535
> to my internal IP. Now if you're behind NAT in a campus environment it
> may be a bit tricky to get the networking folks to forward those ports
> to your machine.
> On 9/11/07, George Estes <gestes at ncsa.uiuc.edu> wrote:
>> Hello,
>> Could someone with experience in this area tell me the issues/problems with receiving traffic from a bridge server if I'm behind a NAT. I've looked through the ag-tech mailing list and there's talk of problems but I can't find specifics.
>> Thanks,
>> George
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070911/09b013a9/attachment.htm>
