[AG-TECH] /usr/bin/VenueServer error
Ben Green
Ben.Green at manchester.ac.uk
Tue Oct 23 04:27:20 CDT 2007
ProgId Word.Document Generator Microsoft Word 11 Originator Microsoft Word 11 Thanks Douglas, that seems OK now.
I don' t think the earlier AG3 repository links to a VPCScreen download. I had to install VPCScreen manually before installing AG3.1 (it was failing on
|=============================| | Ben Green | | Access Grid Support Centre | | Room G49-H | | Research Computing Services | | Kilburn Building | | University of Manchester | | Oxford Road | | Manchester | | M13 9PL | |-----------------------------| | Tel. 0161 306 6621 | | Fax. 0161 275 0637 | | ben.green at manchester.ac.uk | | http://www.agsc.ja.net | |=============================|
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Douglas Kosovic Sent: 23 October 2007 05:58 To: Ben.Green at manchester.ac.uk; ag-tech at mcs.anl.gov Subject: RE: [AG-TECH] /usr/bin/VenueServer error
Hi Ben,
You have the wrong version of VPCScreen installed, it should be VPCScreen-0.2-1.fc7 (from the Fedora7 AG3 yum repository) which doesn' t have any conflicts.
yum update VPCScreen
should fix it.
Forgot to mention, you can see VenueServer error logs in
~ /.AccessGrid3/Logs/VenueServer.log
Cheers,
Doug
From: Ben Green [mailto:Ben.Green at manchester.ac.uk] Sent: Monday, 22 October 2007 11:53 PM To: Douglas Kosovic; ag-tech at mcs.anl.gov Subject: RE: [AG-TECH] /usr/bin/VenueServer error
Hi Douglas,
No luck I' m afraid - a different error message this time:
Transaction Check Error:
file /etc/AccessGrid3/NodeServices/VPCScreenProducerService.zip from install of AccessGrid-3.1-0.3.beta2.fc7 conflicts with file from package VPCScreen-0.2-1
Error Summary
[root at coppi ag]#
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf Of Douglas Kosovic Sent: 20 October 2007 03:51 To: Ben.Green at manchester.ac.uk; ag-tech at mcs.anl.gov Subject: RE: [AG-TECH] /usr/bin/VenueServer error
Hi Ben, > Recently installed v3.1 but cannot get it to start: > > ---------------------------------------------- > /usr/lib/python2.5/site-packages/AccessGrid3/AccessGrid/InsecureVenueEventClient.py:404: > DeprecationWarning: The wxPython compatibility package is no longer automatically generated > or actively maintained. Please switch to the wx package as soon as possible. > > from wxPython.wx import * > ---------------------------------------------- > > Any ideas what this means? You have v3.1 Beta 1 installed which is importing the wxPython package. The new v3.1 Beta 2 now imports the wx package, so doesn't produce the deprecation warning. Try installing the new AccessGrid 3.1 Beta 2 and then post any error message you might get. Doug
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20071023/6bfb77f1/attachment.htm>
