[AG-TECH] Necessary AG3.0.2 RPM update for Fedora 7
Douglas Kosovic
douglask at itee.uq.edu.au
Thu Oct 11 00:30:54 CDT 2007
Due to Fedora 7 Updates recently causing the python-twisted-core RPM to be
updated from 2.4 to 2.5, I've had to create a new AccessGrid-3.0.2-10.fc7
RPM that is compatible with Twisted 2.5 (the Twisted 2.5 code was back
ported from AG 3.1 beta2).
I've also created a new python-twisted-core-2.5.0-3.fc7 RPM that contains a
one line fix necessary for AG3.x VenueClient to be able to add and remove
files to the data section.
So if you are having an issue with the VenueClient not starting up, or not
being able to add/remove data to the data section, as root issue:
yum update AccessGrid python-twisted-core
Doug
