[AG-TECH] Audio freezes on WinXP x64 with RealTek AC97
Jon Johansson
jon.johansson at ualberta.ca
Thu May 31 13:02:14 CDT 2007
For what it's worth I'll reply to myself on this:
I've downloaded the Sumover rat code from
http://mediatools.cs.ucl.ac.uk/nets/mmedia/wiki/SvnDev
and compiled eveything using Visual Studio 8. One thing fails -
the ratui link gets errors because the tk library contains X
functions. Rather than spend any more time I replaced the the AG
executables: rat.exe and ratmedia.exe, with the newly compiled
versions.
The result is that the same problem exists - rat still freezes
after a bit of time, it may however, be a bit better, but my
perception is probably just colored by putting some time into
the build.
Would anyone have experience with external (USB or firewire) sound
cards on 64-bit Windows? I see that the Creative SoundBlaster Live!
24-bit External has 64-bit drivers and for about $50 it might be
worth a try.
Jon.
~~ Jon I Johansson, Ph.D. * Tel.: (780) 492-9304 ~~
~~ jon.johansson at ualberta.ca * Fax.: (780) 492-1729 ~~
~~ * Office: G.S.B. 323C ~~
~~ Programmer/Analyst http://sciviz.aict.ualberta.ca ~~
~~ Research Computing Support ~~
~~ Room 352, General Services Building ~~
~~ Academic Information and Communication Technologies (AICT) ~~
~~ University of Alberta ~~
~~ Edmonton, Alberta, CANADA, T6G 2H1 ~~
! "This communication is intended for the use of the recipient to !
! which it is addressed, and may contain confidential, personal, !
! and/or privileged information. Please contact us immediately !
! if you are not the intended recipient of this communication. !
! If you are not the intended recipient of this communication, !
! do not copy, distribute, or take action on it. Any !
! communication received in error, or subsequent reply, should !
! be deleted or destroyed." !
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Jon Johansson
Sent: Wednesday, May 30, 2007 10:37 AM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Audio freezes on WinXP x64 with RealTek AC97
I'm trying to get AG working on a 64 bit Windows XP system. The 64
windows drivers for the USB cameras (Creative and Logitech) I'm using
are working great. My only problem is with the audio - PCI cards
have given me nothing but grief. The onboard audio does work
briefly, but after about a minute rat freezes. I can restart rat
and it will work again for a short time. Would anyone have a new
build of the Sumover rat that I can just drop in to replace the
existing rat for AG 3.0.2 (build 1)? A 32 bit build should be just
fine.
Jon.
~~ * Office: G.S.B 323C ~~
