[AG-TECH] Errors in install Bonjour python moudle.
刘冠强
liugq at vrlab.buaa.edu.cn
Thu May 24 03:10:43 CDT 2007
Hi:
I have installed Bonjour and Bonjour SDK.
Buti when I run "python setup.py build " in dir bonjour.
There are errors:
E:\eclipse-project\bonjour>python setup.py build
incDirList = ['c:\\program files\\bonjour sdk\\include']
Running swig with: |['swig', '-python', '-outdir', 'bonjour', '-new_repr', '-IC:
\\Python23\\include', '-o', 'bonjour_wrap.c', 'bonjour.i']|
running build
running build_py
copying bonjour\__init__.py -> build\lib.win32-2.3\bonjour
running build_ext
building 'bonjour._bonjour' extension
D:\Program Files\Microsoft Visual Studio\VC98\BIN\cl.exe /c /nologo /Ox /MD /W3
/GX /DNDEBUG "-Ic:\program files\bonjour sdk\include" -IC:\Python23\include -IC:
\Python23\PC /Tcbonjour_wrap.c /Fobuild\temp.win32-2.3\Release\bonjour_wrap.obj
/DWIN32
bonjour_wrap.c
c:\program files\bonjour sdk\include\dns_sd.h(67) : error C2061: syntax error :
identifier 'uint8_t'
c:\program files\bonjour sdk\include\dns_sd.h(67) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(68) : error C2061: syntax error :
identifier 'int8_t'
c:\program files\bonjour sdk\include\dns_sd.h(68) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(69) : error C2061: syntax error :
identifier 'uint16_t'
c:\program files\bonjour sdk\include\dns_sd.h(69) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(70) : error C2061: syntax error :
identifier 'int16_t'
c:\program files\bonjour sdk\include\dns_sd.h(70) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(653) : error C2146: syntax error :
missing ')' before identifier 'port'
c:\program files\bonjour sdk\include\dns_sd.h(653) : error C2081: 'uint16_t' : n
ame in formal parameter list illegal
c:\program files\bonjour sdk\include\dns_sd.h(653) : error C2061: syntax error :
identifier 'port'
c:\program files\bonjour sdk\include\dns_sd.h(653) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(658) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(697) : error C2146: syntax error :
missing ')' before identifier 'rrtype'
c:\program files\bonjour sdk\include\dns_sd.h(697) : error C2081: 'uint16_t' : n
c:\program files\bonjour sdk\include\dns_sd.h(697) : error C2061: syntax error :
identifier 'rrtype'
c:\program files\bonjour sdk\include\dns_sd.h(697) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(701) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(737) : error C2146: syntax error :
missing ')' before identifier 'rdlen'
c:\program files\bonjour sdk\include\dns_sd.h(737) : error C2081: 'uint16_t' : n
c:\program files\bonjour sdk\include\dns_sd.h(737) : error C2061: syntax error :
identifier 'rdlen'
c:\program files\bonjour sdk\include\dns_sd.h(737) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(740) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(930) : error C2146: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(930) : error C2081: 'uint16_t' : n
c:\program files\bonjour sdk\include\dns_sd.h(930) : error C2061: syntax error :
identifier 'port'
c:\program files\bonjour sdk\include\dns_sd.h(930) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(934) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(983) : error C2146: syntax error :
missing ')' before identifier 'callBack'
c:\program files\bonjour sdk\include\dns_sd.h(983) : error C2081: 'DNSServiceRes
olveReply' : name in formal parameter list illegal
c:\program files\bonjour sdk\include\dns_sd.h(983) : error C2061: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(983) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(985) : error C2059: syntax error :
c:\program files\bonjour sdk\include\dns_sd.h(1100) : error C2146: syntax error
: missing ')' before identifier 'rrtype'
c:\program files\bonjour sdk\include\dns_sd.h(1100) : error C2081: 'uint16_t' :
c:\program files\bonjour sdk\include\dns_sd.h(1100) : error C2061: syntax error
: identifier 'rrtype'
c:\program files\bonjour sdk\include\dns_sd.h(1100) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1107) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1154) : error C2146: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1154) : error C2081: 'uint16_t' :
c:\program files\bonjour sdk\include\dns_sd.h(1154) : error C2061: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1154) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1160) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1207) : error C2146: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1207) : error C2081: 'uint16_t' :
c:\program files\bonjour sdk\include\dns_sd.h(1207) : error C2061: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1207) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1211) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1245) : error C2146: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1245) : error C2081: 'uint16_t' :
c:\program files\bonjour sdk\include\dns_sd.h(1245) : error C2061: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1245) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1249) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1367) : error C2146: syntax error
: missing ')' before identifier 'bufferLen'
c:\program files\bonjour sdk\include\dns_sd.h(1367) : error C2081: 'uint16_t' :
c:\program files\bonjour sdk\include\dns_sd.h(1367) : error C2061: syntax error
: identifier 'bufferLen'
c:\program files\bonjour sdk\include\dns_sd.h(1367) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1369) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1429) : error C2146: syntax error
: missing ')' before identifier 'valueSize'
c:\program files\bonjour sdk\include\dns_sd.h(1429) : error C2081: 'uint8_t' : n
c:\program files\bonjour sdk\include\dns_sd.h(1429) : error C2061: syntax error
: identifier 'valueSize'
c:\program files\bonjour sdk\include\dns_sd.h(1429) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1431) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1469) : error C2143: syntax error
: missing '{' before '__stdcall'
c:\program files\bonjour sdk\include\dns_sd.h(1544) : error C2146: syntax error
: missing ')' before identifier 'txtLen'
c:\program files\bonjour sdk\include\dns_sd.h(1544) : error C2061: syntax error
: identifier 'txtLen'
c:\program files\bonjour sdk\include\dns_sd.h(1544) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1547) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1573) : error C2146: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1573) : error C2061: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1573) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1577) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1593) : error C2143: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1595) : error C2146: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1595) : error C2061: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1595) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1597) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1640) : error C2146: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1640) : error C2061: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1640) : error C2059: syntax error
c:\program files\bonjour sdk\include\dns_sd.h(1647) : error C2059: syntax error
bonjour_wrap.c(2673) : error C2146: syntax error : missing ')' before identifier
'port'
bonjour_wrap.c(2673) : error C2081: 'uint16_t' : name in formal parameter list i
llegal
bonjour_wrap.c(2673) : error C2061: syntax error : identifier 'port'
bonjour_wrap.c(2673) : error C2059: syntax error : ';'
bonjour_wrap.c(2673) : error C2059: syntax error : ','
bonjour_wrap.c(2673) : fatal error C1003: error count exceeds 100; stopping comp
ilation
error: command '"D:\Program Files\Microsoft Visual Studio\VC98\BIN\cl.exe"' fail
ed with exit status 2
thanks!
刘冠强
2007-05-24
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070524/b56f93cc/attachment.htm>
