[AG-TECH] Rat and MBUS problems
Colin Perkins
csp at csperkins.org
Wed May 23 10:28:57 CDT 2007
On 23 May 2007, at 14:27, Jeremy Mann wrote:
> On 5/22/07, Douglas Kosovic <douglask at itee.uq.edu.au> wrote:
>> I assume you mean Linux AG 2.4 client rather than Linux kernel 2.4
>> clients.
> Yes, I meant 2.4 client.
>> You didn't have a USB webcam plugged in during the power up? It
>> may have
>> become your primary audio device. Try running alsamixer on the
>> command-line to see what it thinks is the primary audio device.
> I have the cameras microphone disabled. I've tried using the onboard
> sound (which used to work) and a USB audio device as well. Both have
> the same problem.
>> Try switching from ALSA to OSS in rat and see if that helps.
> I could if RAT would load, it doesn't even come up.
>> If it is only happening to AG 2.4 rat and not AG 3.0.2 rat, copy
>> the new
>> rat binary, e.g:
>> cp -p .AccessGrid3/local_services/AudioService/rat* \
>> .AccessGrid/local_services/AudioService/
> Its affecting both versions.
Mbus problems are often due to a host firewall blocking UDP port
47000. Did you enable a different firewall configuration when rebooting?
Colin Perkins
http://csperkins.org/
