[AG-TECH] Tabletop-Room mic with integrated echo canceling
Derek Piper
dcpiper at indiana.edu
Wed May 23 09:24:34 CDT 2007
AccuMicPCs are great :) .. I've used them in a number of tabletop mic
applications where there's just one microphone. They work well for round
tables (where people are roughly equidistant from it). The 'PC' version
does indeed come with cabling to connect direct to a PC, i.e. 3.5mm jack.
The only problem is I've seen is if I am working and not directly
speaking at the mic, it might not pick up as well but that's the same
for about any microphone, you have to have the coverage for the area you
want to serve. For most conference table environments they work quite well.
Derek
Michael Braitmaier wrote:
> Hello everyone!
> I am a bit in trouble as I need to order a tabletop mic with integrated
> echo cancelation quite fast, however don't have experience with them. So
> I would like to rely on your experiences.
> So can anyone recommend one or two of such mics, which work fine and
> produce good results, for direct connection into a 3.5mm PC-Audio-in?
> I have just had a look at the follwoing Clearone Mic (
> http://www.clearone.com/products/product.php?cat=4&prod=17 ),
> which seems to be able to work on PCs directly. Does anyone of you
> already have experience with this one?
> Thanks in advance
> Michael
Derek Piper - dcpiper at indiana.edu - (812) 856 0111
IRI 323, School of Informatics
Indiana University, Bloomington, Indiana
