[AG-TECH] AG3 Bridge Problem [nclassified]
Kivshar, Boris (Contractor)
Boris.Kivshar at dsto.defence.gov.au
Thu May 3 19:20:33 CDT 2007
Hey all,
In our organisation we have in one location a Venue Server, Bridge, and
a Bridge Registry which all works fine. In another location I am setting
up another venue server. So far I have successfully installed the
VenueServer, but my Bridge is not working. I run the Bridge server via a
batch file with the name, location and the bridge registry path of the
first Bridge Registry.
The script that I am running is:
Cd "C:\Program Files\AGTk-3\bin"
C:\Python23\python.exe Bridge3.py
--registryUrl=http://mybridgeregistryserver:8080/AGBridgeRegistry/peers.
txt --name=MyBridgeName
--location="My Location" --qbexec=./QuickBridge.exe
All the Venue Clients are able to see my new bridge but all get an error
message when they try and use it.
"Connection to the bridge <name> failed. Please use a different bridge"
The Bridge is being run on the same machine as the Venue server, and
even the client on that same machine comes up with that same error.
All the machine do not have connectivity to the internet.
Any advice would be much appriciated.
Boris
IMPORTANT: This email remains the property of the Australian Defence Organisation and is subject to the jurisdiction of section 70 of the CRIMES ACT 1914. If you have received this email in error, you are requested to contact the sender and delete the email.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20070504/fa348c92/attachment.htm>
