[AG-TECH] building AG3 on ubuntu edgy
Eric Olson eolson at mcs.anl.gov
Thu Mar 8 17:54:08 CST 2007
Just a minor clarification.  You wrote:
 > I've updated zsi to the head and figured out the problem with the path.
The ZSI "head"/trunk code is being restructured so it won't work at the
moment.  You probably meant the branch that I pasted, but I just wanted
to be extra clear.
Here is the branch url again.
svn co
https://pywebsvcs.svn.sourceforge.net/svnroot/pywebsvcs/branches/ZSI_v2_0_0
   zsi_2_0
Also, it should work fine with AG 3.0.x releases and AG 3 cvs.
Eric
Brad Langhorst wrote:
> On Thu, 2007-03-08 at 14:12 -0600, Eric Olson wrote:
>> The error you're getting:
>>  > ImportError: No module named AccessGrid.Toolkit
>> means python can't find the 3.0 "AccessGrid" or "AccessGrid.Toolkit"
>> module(s).  It is likely that your PYTHONPATH is not set correctly.  The
>> env-init.sh is supposed to set it.  You can do "echo ${PYTHONPATH}" to
>> see what its value is and then correct it.  If you need more help with
>> that part, let me know.
>> Yes, a debian/ubuntu package is definitely needed.  It's been worked on
>> but not finished.
>> If you have any more problems, please send mail.
>> Eric
> Well, I think I'm making progress with the help you've given me.
> Now I get a new error : No module named OpenSSL_AG.crypto
> I don't find anything similarly named in AccessGrid or in ag-media.
> I do have the openssl 0.9.8 and it's -dev package installed , though
> none of the configure scripts seemed to look for ssl headers.
> I thought maybe it was related to m2crypto... i had 0.16, so i upgraded
> to the 0.17 mentioned at
> http://www-new.mcs.anl.gov/fl/research/accessgrid/software/cvs.html
> but that did not seem to help.
> I couldn't figure out how to do the equivalent of make clean in
> AccessGrid so I just re-checked everything out and rebuilt, no change.
> What am I missing?
> Brad
> full details below:
> bwlang at upup:/usr/src$ python AccessGrid/bin/VenueClient.py
> --personalNode
> Traceback (most recent call last):
>   File "AccessGrid/bin/VenueClient.py", line 30, in ?
>     from AccessGrid.VenueClientUI import VenueClientUI
>   File "/usr/src/AccessGrid/AccessGrid/VenueClientUI.py", line 47, in ?
>     from AccessGrid.Security.wxgui.AuthorizationUI import
> AuthorizationUIDialog
>   File
> "/usr/src/AccessGrid/AccessGrid/Security/wxgui/AuthorizationUI.py", line
> 30, in ?
>     from AccessGrid.interfaces.AuthorizationManager_client import
> AuthorizationManagerIW
>   File
> "/usr/src/AccessGrid/AccessGrid/interfaces/AuthorizationManager_client.py", line 7, in ?
>     from AuthorizationManager_messages import *
>   File
> "/usr/src/AccessGrid/AccessGrid/interfaces/AuthorizationManager_messages.py", line 29, in ?
>     AddSubjectToRoleRequest =
> www_accessgrid_org_v3_0_authorizationmanager.AddSubjectToRoleRequest().pyclass
>   File
> "/usr/src/AccessGrid/AccessGrid/interfaces/AG_AuthorizationManager_Types.py", line 692, in __init__
>     TClist =
> [GTD("http://www.accessgrid.org/v3.0","X509Subject",lazy=False)(pname=(ns,"subject"), aname="subject", minOccurs=1, maxOccurs=1, nillable=False, typed=False, encoded=kw.get("encoded")), GTD("http://www.accessgrid.org/v3.0","Role",lazy=False)(pname=(ns,"role"), aname="role", minOccurs=1, maxOccurs=1, nillable=False, typed=False, encoded=kw.get("encoded"))]
>   File
> "/usr/src/AccessGrid/AccessGrid/interfaces/AG_NodeService_Types.py",
> line 479, in __init__
>     import AccessGrid.Security.X509Subject
>   File "/usr/src/AccessGrid/AccessGrid/Security/X509Subject.py", line
> 20, in ?
>     from OpenSSL_AG.crypto import X509NameType
> ImportError: No module named OpenSSL_AG.crypto
More information about the ag-tech mailing list
