[AG-TECH] multimachine node problem...
Porfirio Gaona Gonzalez
pgg at ixtli.unam.mx
Mon Jun 11 11:49:45 CDT 2007
I changed my display machine. My new machine is an Opteron 64 bits, but
I have a problem when I've tried to communicate with my audio and video
machine. When I try to configurate my Access Grid Node Management,
there's no communicantion with audio and video PC's.
I read that the possible reasons are:
- my clock is not synched to an NTP.
- Certificate expired
- I should have the CA certificates to supor the certificate I'm using.
According my configuration :
- I have clock synched to an NTP.
- My certificate has expired, but I'm usign AG3 and certicificate is not
needed if I use Venue Client.
When I try to communicate from Display PC to Audio Machine, the log file
in audio says:
06/11/07 11:45:50 -1226474592 Hosting ServiceContainer.py:16 ERROR
Processing Failure
ZSI.ServiceContainer:NoSuchService
No service(NodeService) in ServiceContainer
[trace:
/usr/lib/python2.4/site-packages/ZSI/ServiceContainer.py:351:do_POST
/usr/lib/python2.4/site-packages/ZSI/ServiceContainer.py:70:_Dispatch
/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/hosting/ZSI/ServiceContainer.py:100:getNode
/usr/lib/python2.4/site-packages/AccessGrid3/AccessGrid/hosting/ZSI/ServiceContainer.py:44:getNode]
If I reconnect my old dislpay machine, everything works fine.
Do you have any suggestion?
Thanks in advance
Porfirio Gaona
UNAM Mexico
