[AG-TECH] Audio Reflector room
Markus Buchhorn
Markus.Buchhorn at anu.edu.au
Tue Jul 17 02:26:17 CDT 2007
You should also run the audio reflector controller application (which is normally stored in the venue data - I can't check or test right now). That has the option to play back standard sounds stored in the reflector, so you can test inbound paths separately from outbound.
Cheers,
Markus
At 10:35 AM 17/07/2007, Christoph Willing wrote:
>On 16/07/2007, at 8:26 PM, Samuel Gundry wrote:
>>Hi,
>>The audio reflector and the second participant of me don't appear when I visit the "Audio Reflector" venue (for AG 3.0.2), as per the instructions here: <http://www.accessgrid.org/node/354>http://www.accessgrid.org/node/354
>>Does the room work for anyone else? Or is the room broken?
>I used it successfully yesterday when testing a laptop node in the Library and again just now from our lab node.
>>I'm using this address: <https://vv3.ap-accessgrid.org:8000/Venues/00000103104e90bd0081004e009d00a8bbc>https://vv3.ap-accessgrid.org:8000/Venues/00000103104e90bd0081004e009d00a8bbc
>>I want to test out my sound (obviously), the bars in RAT are moving but I don't have any way to test the sound...
>Perhaps your signal isn't reaching the reflector. When you're in that venue, you should see the "APAG AudioReflector" entry in rat itself. You should also see 2 entries for your own node. If you don't see all those entries then your traffic isn't being seen (and audio reflection can't work) - therefore check your firewalls, multicast etc.
>chris
>Christoph Willing +61 7 3365 8350
>QCIF Access Grid Manager
>University of Queensland
