[AG-TECH] Can't contact VenueServer on Fedora 7
Michael Miller
mimiller at ncsa.uiuc.edu
Fri Jul 6 12:00:23 CDT 2007
Tom,
No, the hostname was not what I expected, so I went and checked the
network config and set that up correctly(AFAIK). But the URL still
showed localhost.localdomain. So I rebooted. That still didn't
solve the problem, so I opened a root shell and set the hostname with:
hostname roeshamboe.ncsa.uiuc.edu
and that did the trick.
Thanks for the pointer...
myk
At 11:04 AM 7/6/2007, Thomas D. Uram wrote:
>When you start the server, it reports the URL of the server. Is the
>hostname in the URL what you would expect for the server ?
>On 7/6/07 9:41 AM, Michael Miller wrote:
>>Hello,
>>I installed fedora 7 and enabled SELinux and the firewall. Then
>>opened the appropriate ports 8000 8002 8004 8006. Looking at the
>>config file 8004 doesn't appear to be used anymore, but I'll close
>>that later. As I was unable to connect, I checked the
>>VenueClient.log and found nothing written referring to my attempt
>>to connect. Looking at the VenueServer log, I find nothing as
>>well. So suspecting SELinux or the firewall, I set SELinux to
>>Permissive and turned off the firewall. But I'm still getting
>>connection refused.
>>What else should I look at?
>>thanks
>>myk
