[AG-TECH] Realtek and rat crashing
Thomas D. Uram
turam at mcs.anl.gov
Thu Jan 11 14:29:22 CST 2007
Commenting that out will not cause any problems (yet), as I don't know of
any applications that use the site id yet. Eventually it will likely be
used for
associating video streams and audio streams with a site, at which time
commenting that out would cause a problem.
Tom
On 1/11/07 2:18 PM, George Estes wrote:
> When I try to run the UCL 4.3 RAT from 3.0 I get an address error related to -S. If we comment out the "pass public id as site id" section in AudioService.py the 4.3 RAT runs fine. Do bad things happen elsewhere when we comment out that section?
> George
> At 11:26 AM 1/11/2007 -0600, Thomas D. Uram wrote:
>> A couple comments below...
>> On 1/11/07 8:38 AM, Tom Coffin wrote:
>>> so - yesterday the soundblaster pcmcia card came and
>>> I installed it and am testing it out. Initially, everything
>>> was working great - so I left it up over night. When I
>>> came in, in the morning, rat had frozen again - as it was
>>> doing with the realtech card - I disabled and re-enabled and
>>> the freeze came much faster. I then noted that I was
>>> still using the rat 4.22... I thought I had copied the latest rat
>>> into bin and the zip folder.
>>> So, I tried the latest UCL Rat 4.3 solo - when I run that by itself
>>> (connecting to one of the NCSA ag3 venues) it works fine
>>> so I tried to copy over the rats in bin and in the zip folder again
>>> but the venue still starts up a 4.2 version of rat - is
>>> there another instance somewhere which I need to copy
>>> the new rats into?
>> The rat executables are in your ~/.AccessGrid3/local_services/AudioService
>> directory (or c:\documents and settings\<you>\accessgrid3\local_services\AudioService.
>> There is a command-line compatibility issue between the AG
>> rat and the UCL rat, so you can't just drop the UCL rat into
>> place. They are planning to fix that by supporting the new option
>> in a future release.
>>> Also, I notice that the default configuration always lists
>>> my video service but it always comes up as disabled - no matter
>>> how many times i save the config after enabling
>> That setting is in user preferences (tools->preferences->mynode).
>> You may have to stretch the window larger, but at the bottom, you'll
>> see a checkbox for 'enable video'. Check it and save preferences.
>>> At 10:47 AM 1/9/2007, you wrote:
>>>>> At 09:57 AM 1/9/2007, George Estes wrote:
>>>>>> Thanks Tom,
>>>>>> I'm looking at trying a PCI-X card, since I do have an empty PCI-X slot. Either the Sound Blaster X-Fi or the M-Audio card look like possibilities. Although I'm not either will work with RAT.
>>>>>> George
>>>>>> At 08:45 AM 1/9/2007 -0600, Tom Coffin wrote:
>>>>>>> hi George - I had the same problms...
>>>>>>> am going to try out the new soundblaster
>>>>>>> pcmcia card - if that doesn't work I was
>>>>>>> going to try the soundblaster external card which connects
>>>>>>> by usb.
>>>>>>> I tried updating the rat from UCL and that didn't help
>>>>>>> not sure why rat and realtek don't work together
>>>>>>> the audio works fine on other apps
>>>>>>> On Mon, 8 Jan 2007, George Estes wrote:
>>>>>>> > Anyone,
>>>>>>> > I see an old thread about RAT crashing with Realtek drivers. Does anyone know if that problem has been fixed? I have a new machine with the latest drivers for an onboard Realtek card and after a period of time RAT becomes unresponsive. Changing venues causes it to become responsive again. Of course it's been running for two hours now without hanging. Has anyone found a solution other than adding another sound card? Or does anyone know of an affordable PCI-X sound card?
>>>>>>> > Thanks,
>>>>>>> > George
>>>>> ___________________________________________________________
>>>>> Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
>>>>> NCSA-ACCESS cel: 703-477-5948
>>>>> 901 North Stuart Street, #800 tel: 703-248-0105
>>>>> Arlington, Virginia 22203 fax: 703-248-0100
>>>>> _________________________ http://www.ncsa.uiuc.edu/~tcoffin
